Virtual Wire - Noobie problem
Hello,
First time putting a message up so I hope this is all in the right place. Yes I’m a complete noobie.
Ok, so I picked up a cheap 433.92MHz transmitter and receiver pair
Rx = ZABR1-01
http://www.alibaba.com/product-gs/283516522/Super_regenerative_RF_Wireless_Receiver_Module.html
Tx = NT-T02B
http://www.alibaba.com/product-gs/298268955/NT_T02B_RF_transmitter.html
The way I have set them up is similar to the attached image (I wasn’t sure how to put it in the message). In reality I am using two boards with the Tx on a battery and the Rx connected to my computer. Also I tried the Rx data wire in 11 as per the Virtual Wire pdf.
I have tried the Virtual Wire approach and scanned the forums here for examples and similar problems.
This is the Transmitter code I tried:
#include <VirtualWire.h>
#undef round
    vw_setup(2000); // Bits per sec
    const char *msg = "Hello my friends, this is earth calling.  We hope you are all well :)";
    vw_send((uint8_t *)msg, strlen(msg));
    delay(400);
And this is the Receiver code:
#undef round
    Serial.println("setup");
    vw_rx_start();    // Start the receiver PLL running
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
// Message with a good checksum received, dump HEX
Serial.print("Got: ");
for (i = 0; i < buflen; i++)
    Serial.print(buf[i], HEX);
    Serial.print(" ");
Serial.println("");
I get the ‘setup’ line appear in the serial monitor but that is all that seems to be happening.
Is my wiring up wrong?
Is the code I am using wrong?
Are the components simply not working?
Is it a mixture of the above?
Or something else altogether?
Help and pointers appreciated.
Check the VirtualWire documentation.
"Messages of up to VW_MAX_PAYLOAD (27) bytes can be sent"
4.12 vw_send extern uint8_t vw_send(uint8_t* buf, uint8_t len); Send a message with the given length. Returns almost immediately, and the message will be sent at the right timing by interrupts. Returns true if the message was accepted for transmission. Returns false if the message is too long (>VW_MAX_PAYLOAD).
VW is refusing to send the too-long message.
Oh my!!!
Thank you so very much maniacbug.
I somehow missed a big chunk of section 6 in the documentation when I was looking through it.
Thank you again.
Now to look at ways of enabling longer messages with the constraint in place :)
did you manage to get this to work ?
i have a zabr1-01 wired as in the image and using this code to read the rx
#undef int
#undef abs
#undef double
#undef float
#undef round
    Serial.begin(9600);	// Debugging only
    // Initialise the IO and ISR
    vw_set_ptt_inverted(true); // Required for DR3100
	int i;
        digitalWrite(13, true); // Flash a light to show received good message
	// Message with a good checksum received, dump it.
	    Serial.print(" ");
	Serial.println("");
        digitalWrite(13, false);
i want to use it to read the output of some oregon scientific weather transmitters that are 433 mhz
can’t seem to get it to work
Do you need PTT code in a receiver?
this is where i got the idea from
http://www.practicalarduino.com/projects/weather-station-receiver
AWOL: Do you need PTT code in a receiver?
i have no idea - it is the sample code you get when you download virtualwire - i will rem it out and see what happens
ty
@gadget99 - Thats a pretty cool project! I’m working on a temp/light/humidty sensor using 433 links. Great little things!
One thing that comes to mind is that the weather station may only be transmitting small packets every 1/2 hour or so? Possibly try leaving your arduino hooked up for a few hours?
Are you using the default v_w pins?
Not sure why you have those #undef statements, I’ve never used them and everything seems fine.
Possibly a loop to try all baud rates the units support?
This sounds like a great project - gots to find me a weather station now! :slight_smile:
the weatherstation transmitter flashes an led when it transmits so i can see when a packet of data is being sent
the oregon rx displays the data correctly so i know the tranmission is happening
i am using pin 11 to collect the data as in the drawing above
i think later today i will set up another arduino to do a tx and then see if i can find the problem
Arduino is soooooo much fun - i should have got into this years ago !
best of luck with your own project
i go the TX module wired up and with 2 arduino's have had the system sending and recieving messages
however have been unable to get it to read the messages that the weatherstaions transmit - i guess they must be in some other form of data transmission format
i will do a some research and see if i can find out how the data is formatted
Hi all, i’m a real noob in using arduino and electronics but i want to try hard to build my personal oregon scientific receiver with an arduino to log and plot my weather data on pc. Since now i have an arduino UNO and a ASK recevier shield @ 433 MHz (from freetronics). Now i would like to get data from my temperature sensor but… i can’t found any nice tutorial to start with, maybe a sketch. I really don’t know how to start.
Any advice?
Thank you in advance,
Andrea
