Virtual wire problem
hi... My VirtualWire examples gives de error again and again In file included from transmitter.cpp:11: C:\Users\Administrator\Desktop\my project\arduino-1.0-windows\arduino-1.0\libraries\VirtualWire/VirtualWire.h:15:20: error: wiring.h: No such file or directory In file included from transmitter.cpp:11: VirtualWire.h:60: error: variable or field 'vw_set_tx_pin' declared void VirtualWire.h:60: error: 'uint8_t' was not declared in this scope VirtualWire.h:64: error: variable or field 'vw_set_rx_pin' declared void VirtualWire.h:64: error: 'uint8_t' was not declared in this scope VirtualWire.h:68: error: variable or field 'vw_set_ptt_pin' declared void VirtualWire.h:68: error: 'uint8_t' was not declared in this scope CVirtualWire.h:72: error: variable or field 'vw_set_ptt_inverted' declared void VirtualWire.h:72: error: 'uint8_t' was not declared in this scope VirtualWire.h:77: error: variable or field 'vw_setup' declared void VirtualWire.h:77: error: 'uint16_t' was not declared in this scope VirtualWire.h:91: error: 'uint8_t' does not name a type VirtualWire.h:99: error: 'uint8_t' does not name a type VirtualWire.h:105: error: 'uint8_t' does not name a type VirtualWire.h:108: error: 'uint8_t' does not name a type VirtualWire.h:113: error: 'uint8_t' does not name a type transmitter.cpp: In function 'void setup()': transmitter:26: error: 'vw_set_tx_pin' was not declared in this scope transmitter:27: error: 'vw_set_rx_pin' was not declared in this scope transmitter:28: error: 'vw_set_ptt_pin' was not declared in this scope transmitter:29: error: 'vw_set_ptt_inverted' was not declared in this scope transmitter:30: error: 'vw_setup' was not declared in this scope transmitter.cpp: In function 'void loop()': transmitter:41: error: 'vw_send' was not declared in this scope
can anyone help??
Did you include the library header? Did you select the correct board?
Post a code example that causes the errors...
Near the start of the VirtualWire.h file you should see this:
#include <stdlib.h>
#if ARDUINO >= 100
  #include <Arduino.h>
#else
  #include <wiring.h>
#endif
If you only see:
#include <stdlib.h>
#include <wiring.h>
Then replace that by the lines above.
thanks a lot.. wen i replaced with those lines it worked fine.. can u help me how to transmit bit by bit data that is available in my serial port to the transmitter?? i actually connected my webcam to arduino and got the digital output serially now gotta transmit through RF
hii.. i used the following code to get digital output from my webcamera..now i need to transmit the data serially to an RF transmitter.. how to do it??
int ledPin=9; int digPin=3; int digiPin=10;
void setup() { Serial.begin(9600); pinMode(ledPin,OUTPUT); pinMode(digPin,INPUT); pinMode(digiPin,OUTPUT); }
void loop() { int value; value= digitalRead(digPin); Serial.println(value); if(value==0) digitalWrite(ledPin,LOW); else digitalWrite(ledPin,HIGH);
Do you!! How does that work then?
i am getting serial data output from my digital webam… my prob is how to transmit it to an RF transmitter?
Topics merged. They seem to me to be on the same subject.
may i know how to transmit digital data from one arduino to another via RF?? should i store the digital values in a buffer and transmit? if so how to do it??
I don't understand that, sorry. Perhaps if you described your hardware...
It would help to know what kind of rf module you are using, maybe with a datasheet link, and what are you going to do with that data? It maybe a bit hard to do much with just two arduinos
i am using RF433Mhz transmitter and receiver..
i dunno how to transmit integer values that appear in my serial port via RF.. there are many examples on how to transmit msgs only.. i think we have to store the integer values in an buffer and send it.. do we have to use a serial buffer?? if so how?? how to set the buffer size??
one byte after byte transfer happens to whatever you write on Serial there is no special system about it. for example when you type "Nishant" (N-i-s-h-a-n-t and not Nishant in one go)it goes through Serial RX/TX pins of your arduino to which the transmitter may be connected and if its there then information flows one by one.
so I was running into same problem and tried replacing said lines, however I get a new error:
error: WProgram.h: No such file or directory
I followed these instructions:::::
and replaced the library but it is still not working.
I found another 2 different VirtualWire libraries in the discussion thread on this tutorial
One of them contains already the additional instructions on the h file but I am still getting the same library error.
I already tried different codes that include this library so this must not be it. I have also previously added libraries to mi IDE folder so I know Im doing it right,
What else can it possibly be?
