Virtual Wire - Send More byte like Number
Good Afternoon Friend,
I'm working with virtual wire library this is my scenario :
Device Address:
Byte
001 - Led1 --> Connected to Arduino
002 - Led2 --> Connected to another arduino
003 - Led3 --> Connected to another arduino
Command List:
Byte
001 - Turn On
002 - Turn Off
State List:
001 - Turned On
002 - Turned Off
003 - Bad State
My Message Structure will Be:
Destination Address + Command
then I'll have
003 001
How I can do for send out this message ?
is there a protocol that i can use ? :slight_smile:
Thanks in advance,
Andrea
VirtualWire is no longer supported. You should probably try to use the RadioHead library that replaced it.
http://www.airspayce.com/mikem/arduino/RadioHead/
Thanks I will have a look :slight_smile:
Regards,
Andrea
Ciao where i can found the connection schema ?
Thanks
Andrea
You will need to provide more information on your TX, RX hardware.
Could kindly someone explain me how to inizialize …
baud rate
tx pin
rx pin
in ask with new radio head library ?
thansk
Andrea
gnusso:
Could kindly someone explain me how to inizialize ...
baud rate
tx pin
rx pin
thansk
Andrea
You should probably look at the library examples:
ask_reliable_datagram_client
ask_reliable_datagram_server
It you are confused by the examples johnwasser suggested you can get going with the more simple examples in the library ask_receiver and ask_transmitter.
The library will use default values of 2000 bps, rx pin 11, and tx pin 12.
You can confirm that the software is running by connecting pin 11 on the RX Arduino to pin 12 of your TX Arduino and bypassing the radios to start.
You have still not confirmed what hardware you are using. Not all modules use RadioHead or VirtualWire.
Thanks I’ve done a first test
with this simple sketch:
#include <RH_ASK.h>
#include <SPI.h> // Not actually used but needed to compile
RH_ASK driver;
    Serial.begin(9600);	  // Debugging only
    if (!driver.init())
         Serial.println("init failed");
    const char *msg = "hello";
    driver.send((uint8_t *)msg, strlen(msg));
    driver.waitPacketSent();
    delay(200);
Receive code:
#include <RH_ASK.h>
#include <SPI.h> // Not actualy used but needed to compile
RH_ASK driver(2000,8,9);
    Serial.println("Ricevitore");
    if (!driver.init())
    uint8_t buf[RH_ASK_MAX_MESSAGE_LEN];
    uint8_t buflen = sizeof(buf);
    if (driver.recv(buf, &buflen)) // Non-blocking
	//int i;
	// Message with a good checksum received, dump it.
	driver.printBuffer("Got:", buf, buflen);
ok on the receiver I receive this:
Got:
68 65 6C 6C 6F
Ok now I would lke from sender staind point send-out the message “hello” in this way
104 101 108 108 111
that looking the ascii table
http://arduino.cc/en/Reference/ASCIIchart
should be hello but where i sendout byte in stead of character is possible ?
Thanks
Andrea
Here is some code to send and receive a byte array.
//Send Byte Array
#include <RH_ASK.h>
//RH_ASK driver;//using defaults
  driver.init();
  byte data[] = {104, 101, 108, 108, 111};
  long interval = 2000; //send every 2 seconds
  static unsigned long millisLast = millis();
  if(millis() - millisLast > interval){
    driver.send(data, sizeof(data));
    delay(200);
//Receive Byte Array
#include <RH_ASK.h>
RH_ASK driver(2000,8,9;
 driver.init();
  byte Data[5] = {};
  if (driver.recv(buf, &buflen)) // Non-blocking  Data is sent every minute
    Serial.println("Received");
    memcpy (&Data, buf, buflen);
    for (int i=0; i<5; i++){
      Serial.println(Data[i]);
On the RX I use memcpy to get the data into the sending format and then use it from there.
Thanks :slight_smile: I've done,
could I'm checking documentation and I'm trying like in virtual wire to wait until message is avaiable function ... but I'm not find it :frowning: do you know how is named the function ?
thanks
Andrea
These are the VirtualWire RX functions. Which one are you trying to match? And Why?
Reception Functions
vw_rx_start()
Activate the receiver process. You must call this function before any reception can occur. An interrupt-based background process is started which monitors the reception of data.
vw_have_message()
Returns true if message has been received. This is similar to the "available" function of most other libraries.
vw_wait_rx()
Wait for a message to be received. This will only return when a message has been received, otherwise it will wait forever.
vw_wait_rx_max(timeout_ms)
Wait for a message, but give up after "timeout_ms". Returns true if a message was received, or false if the timeout period elapsed.
vw_get_message(buf, &buflen))
Read the last received message. This should be called only when a message is known to be received with any of the 3 functions above. "buf" is an array where the message is copied. "buflen" should have the array's maximum size upon input, and upon return the number of bytes actually copied is retured. The function itself returns true if the message was verified correct, or false if a message was received but appears to have been corrupted.
vw_rx_stop()
Disable the receiver process.
ok thanks but I'm using the new RadioHead Version :frowning: ...
I understand that you are using RadioHead. Which VW function are you trying to replace with an equivalent RadioHead function?
