Can anyone help please? Fighting with this all evening!!! >:(
#1 Using one sketch I'm Happily reading a string of 6 characters from an RF receiver, using the Virtualwire library and outputting to Serial Monitor. (RX port changed to 9 to avoid LCD connector)
#2 Using another Sketch I'm Happily Displaying "hello world" on an LCD screen.
Therefore separately at least my hardware connections appear ok.
When I try to combine #1 and #2......
Not changed any connections from the first 2 tests...
LCD Printing doesn't work.
- To begin my troubleshooting I stripped out all of the RF code and just printed 123456 on the LCD screen.
That's all it does - all in void Setup (for the test)
lcd.clear();
lcd.print("123456");
123456 appears no problem.
- Added the VirtualWire libray call and it still printed to screen
#include <VirtualWire.h>
- vw_rx_pin(9) and vx_rx_start put back in and still prints
vw_set_rx_pin(9); //change the RX pin out of the way of LCD pins
vw_rx_start(); // Start the receiver PLL running
- readded the vw_setup(2000) line and the lcd just stays blank???
vw_setup(2000); // Bits per sec
Arduino is Duemilanove 328 and I'm working on a prototype shield.
Anyone know why the vw_setup(2000) should prevent me printing to the LCD ![]()
Code in order as it sits in the test sketch is..
lcd.clear();
If I move the LCD code above the vw code it does print and stay on the screen but I can't change it to something else afterwards.
Any pointers would be much appreciated
