Hi all,
bit of an epic but I've tried to include all relevant info.
I bought a 4800bps 315Mhz RF link to have a play with..
http://www.coolcomponents.co.uk/catalog/product_info.php?cPath=25&products_id=186
Connecting one side to an Arduino Duemilanove and the other to an Arduino Nano - both 328
Assumed it was broken and was about to give up when I tried the VirtualWire Library http://www.open.com.au/mikem/arduino/ copied over the example code and got the things talking. ![]()
My pleasure was somewhat diminished by my inability to understand the code or the helpfile.
This is the example sending code loop...
const char *msg = "hello";
vw_send((uint8_t *)msg, strlen(msg));
delay(400);
Which from what I can piece together from forum and doc surfing sets the multi character constant called msg to have the string value hello and then uses the vw_send command from the library to send that text with a length of 5?
What does the (uint8_t *) part mean? Is it just standard for the send command? Multi-byte?
The receive loop code is...
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
// Message with a good checksum received, dump HEX
Serial.print("Got: ");
for (i = 0; i < buflen; i++)
Serial.print(buf[i], HEX);
Serial.print(" ");
Serial.println("");
uint8_t is new to me (as is most of this I'm afraid) Again, reading into it, it seems to be saying define a byte array with the length being the length of the string sent.
Then define another for the length itself.
Then checks to see if there is a message....
if there is, it runs through the array and displays it as a series of HEX characters.
(Actually it has helped to type this out so hopefully I have some of it correct!) ![]()
Would appreciate if someone could check my understanding and comment please.
To take it a step further, I wanted to replace the HELLO message with the output from a pot connected to A0 (+5V and GND)
I mapped the reading to between 0 and 255 ...
analogValue = analogRead(0); Â
analogValue = map(analogValue, 0, 1023, 0, 255);
...but then got completely confused when trying to amend the code to send this data.
It did give me some readings but these tended to be 0, 8 a few other randoms or 255. Also when the pot was turned all the way the output stopped completely so I guess that tx wasn't sending.
I'm using the default send and receive port for VirtualWire (12,11).
Should I have had a resistor connected to the pot?
Tried this as a send command...
vw_send((uint8_t *)analogValue, 1);
Where analogValue was the mapped int reading from the pot.
Then left most of the original code in the receive end but replaced the print line with.
Serial.println(buf[0], INT);
and took out the 'for' loop. Clearly wrong as it isn't giving me correct results.
Could someone assist please?
Many thanks in advance
