virtualwire.h with wire.h, cannot receive the data at the slave using I2C
Hey guys! This is my second post here,Sorry to disturb you all again.
I'm using 3 Arduino UNOs in this project.
#1 Arduino UNO which is collecting the analog values and digital values from Accelerometer and ultrasonic sensor and transmitting it using 433Mhz radio sensor using VirtualWire.h Library.
#2 Arduino UNO which is receiving the analog and digital values transmitted by the #1 Arduino UNO & Sending these values to another #3 Arduino by using I2C, I'm using wire.h Library here.
#3 Arduino UNO which is receiving the analog and digital values from #2 Arduino UNO and i want to work here on those analog and digital values.
The problem that arrives here is
I'm unable to receive the values at #3 Arduino UNO, whereas i can clearly receive it at Arduino UNO #2
At #1 Arduino UNO i can see the values in Serial Monitor.
At #2 Arduino UNO i can see the values in Serial Monitor.
At #3 Arduino UNO i cannot see the values in Serial Monitor.
I made three sketches,Here they are.
Code of #1 Arduino UNO
#include <VirtualWire.h>
const int transmit_pin = 12;
#define echoPin 7
#define trigPin 8
const int xPin = A0;
const int yPin = A1;
const int zPin = A2;
int maximumRange = 200;
int minimumRange = 0;
int duration;
int minVal = 265;
int maxVal = 402;
int x;
int y;
int z;
int distance;
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  vw_set_tx_pin(transmit_pin);
  vw_setup(2000);
  int xRead = analogRead(xPin);
  int yRead = analogRead(yPin);
  int zRead = analogRead(zPin);
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  int xAng = map(xRead, minVal, maxVal, -90, 90);
  int yAng = map(yRead, minVal, maxVal, -90, 90);
  int zAng = map(zRead, minVal, maxVal, -90, 90);
  x = RAD_TO_DEG * (atan2(-yAng, -zAng) + PI);
  y = RAD_TO_DEG * (atan2(-xAng, -zAng) + PI);
  z = RAD_TO_DEG * (atan2(-yAng, -xAng) + PI);
  distance = duration / 58.2;
  Serial.print("X: ");
  Serial.print(x);
  Serial.print("  Y: ");
  Serial.print(y);
  Serial.print("  Z:");
  Serial.print(z);
  Serial.print("   Distance");
  Serial.println(distance);
  int sensorArray[] = {x, y, z, distance};
  digitalWrite(13, true);
  vw_send((uint8_t *)sensorArray, sizeof(sensorArray));
  vw_wait_tx();
  delay(50);
Code of #2 Aduino UNO
#include <Wire.h>
int ledPin = 13;
int x, y, z, distance;
int sensorArray[4] = {};
const int receive_pin = 3;
  pinMode(ledPin, OUTPUT);
  vw_set_rx_pin(receive_pin);
  vw_setup(2000);
  vw_rx_start();
  uint8_t buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  if (vw_get_message(buf, &buflen))
    memcpy(sensorArray, buf, buflen);
    x = sensorArray[0];
    y = sensorArray[1];
    z = sensorArray[2];
    distance = sensorArray[3];
    Serial.print(x);
    Serial.print(y);
    Serial.print("  z: ");
    Serial.print(z);
    Serial.print("  Distance: ");
    Serial.print(distance);
    int data[4];
    data[0] = x;
    data[1] = y;
    data[2] = z;
    data[3] = distance;
    Wire.beginTransmission(4); // transmit to device #4
    Wire.write ( (byte *) data , 8 ) ;
    Wire.endTransmission();
    delay(100);
Sketch of #3 Arduino
#include <Wire.h>
volatile int data[4];     // received data for x, y, z,Distance.
volatile boolean
validData = false; // flag to indicate that something is received.
  Wire.begin(4);                // join i2c bus with address #4
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);           // start serial for output
  // The loop does not contain a delay(), since the 'validData' is checked as many times as possible
  if (validData)
    // It is best to make a copy of the data while interrupts are disabled, but for now they are used directly.
    Serial.print("x=");
    Serial.print(data[0]);
    Serial.print(", y=");
    Serial.print(data[1]);
    Serial.print(", z=");
    Serial.print(data[2]);
    Serial.print(", Distance=");
    Serial.print(data[3]);
    // Now that the data is used, reset the flag for new data.
    validData = false;
void receiveEvent(int howMany)
  // 8 bytes are expected.
  // If not 8 bytes received, then ignore everything.
  if ( howMany == 8)
    // extra safety check. If the flag is clear, fill a new value.
    if ( !validData)
      Wire.readBytes( (byte *) data, 8);
      validData = true;
Please help me.
Thanks..
Could you add all the things that I wrote about here ? Add more serial messages; Assign all three pins for VirtualWire (rx,tx,ptt); Do a test with dummy data; Blink a led in the onReceive handler; Check the return value of Wire.endTransmission();
Setup or Arduino #2 needs to have a Wire.begin() statement
  vw_setup(2000);
  vw_rx_start();
You are awesome cattledog :smiley: I missed that :frowning:
You both guys are amazing, Thank you sir
Thank you very much Peter_n (Specially) and thank you Cattledog.
It's working now. :slight_smile: :slight_smile: :slight_smile: :slight_smile: :slight_smile:
