Hello, I'm trying to do this ...
From the keypad I'd like to read the value for example one, assign it like a message and then send this value with virtual wire ... should be quite easy ... but I receive this error ... error: invalid conversion from 'char' to 'const char*'
do you know the ways guys how to fix that ? I think is something related to the conversion but I don't know how to fix it ... this the code
#include <VirtualWire.h> // include la libreria per la comunicazione
#include <Keypad.h>
// definizione del Keypad
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {8, 7, 6, 5}; //Righe collegate ai PIN 8,7,6,5
byte colPins[COLS] = {4, 3, 2}; //Colonne collegate ai PIN 4,3,2
// byte buttonState = LOW;
// Inizializzazione del Keypad
Keypad customKeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
// vw_set_ptt_inverted(true); // Required for DR3100
vw_setup(1200); // setta la velocità di trasmissione a 1200 Bits per sec
void loop() // loop del micro controllore
// Leggo il Keypad
char customKey = customKeypad.getKey();
if (customKey != NO_KEY){
// the issues is in the next row const char *msg = customKey;
digitalWrite(13, true); // Flash a light to show transmitting
vw_send((uint8_t *)msg, strlen(msg)); // invia la lettera a
digitalWrite(13, false); // spegni il led quando ha finito di trasmettere
// aspetta 400 ms prima di andare avanti
Serial.println(customKey);
delay(50);
Thanks in advance for the help ![]()
