VirtualWire Library not being properly recognized
Hey I’m really hoping someone can help me out.
I’m trying to operate an RF transceiver pair that uses the VirtualWire.h library.
Every time I try to compile my code including the library, I get the errors shown below.
I have looked up this issue and people have posted similar problems online. The typical reason for the error is that the VirtualWire library was out of date. I happen to be using the most up-to-date VirtualWire library(downloaded from here: VirtualWire Library, for very cheap wireless communication) and I am also using the latest version of Arduino Studio.
If anyone could give me some pointers, I would be eternally grateful, because this is maddening. :frowning:
ERRORS
Command failed: C:\Users\Michael\AppData\Local\Temp\build1460164726850\receiver.cpp.o: In function setup': C:\Users\Michael\AppData\Local\Temp\build1460164726850/receiver.cpp:28: undefined reference to vw_set_tx_pin’
C:\Users\Michael\AppData\Local\Temp\build1460164726850/receiver.cpp:29: undefined reference to vw_set_rx_pin' C:\Users\Michael\AppData\Local\Temp\build1460164726850/receiver.cpp:30: undefined reference to vw_set_ptt_pin’
C:\Users\Michael\AppData\Local\Temp\build1460164726850/receiver.cpp:31: undefined reference to vw_set_ptt_inverted' C:\Users\Michael\AppData\Local\Temp\build1460164726850/receiver.cpp:32: undefined reference to vw_setup’
C:\Users\Michael\AppData\Local\Temp\build1460164726850/receiver.cpp:34: undefined reference to vw_rx_start' C:\Users\Michael\AppData\Local\Temp\build1460164726850\receiver.cpp.o: In function loop’:
C:\Users\Michael\AppData\Local\Temp\build1460164726850/receiver.cpp:45: undefined reference to `vw_get_message’
collect2.exe: error: ld returned 1 exit status
CODE
#include <VirtualWire.h>
const int led_pin = 13;
const int transmit_pin = 12;
const int receive_pin = 11;
const int transmit_en_pin = 3;
Serial.begin(9600); // Debugging only
Serial.println(“setup”);
// Initialise the IO and ISR
vw_set_tx_pin(transmit_pin);
vw_set_rx_pin(receive_pin);
vw_set_ptt_pin(transmit_en_pin);
vw_set_ptt_inverted(true); // Required for DR3100
vw_setup(2000); // Bits per sec
vw_rx_start(); // Start the receiver PLL running
pinMode(led_pin, OUTPUT);
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
digitalWrite(led_pin, HIGH); // Flash a light to show received good message
// Message with a good checksum received, dump it.
Serial.print("Got: ");
for (i = 0; i < buflen; i++)
Serial.print(buf*, HEX);*
  • Serial.print(’ ');*
  • Serial.println();*
  • digitalWrite(led_pin, LOW);*
    [/quote]
    VirtualWire.h
    > #ifndef VirtualWire_h
    > #define VirtualWire_h
    > #include <stdlib.h>
    > #if defined(ARDUINO)
    > #if ARDUINO >= 100
    > #include <Arduino.h>
    > #else
    > #include <wiring.h>
    > #endif
    > #elif defined(MSP430G2452) || defined(MSP430G2553) // LaunchPad specific
    > #include “legacymsp430.h”
    > #include “Energia.h”
    > #else // error
    > #error Platform not defined
    > #endif
    > // These defs cause trouble on some versions of Arduino
    > #undef abs
    > #undef double
    > #undef round
    > /// Maximum number of bytes in a message, counting the byte count and FCS
    > #define VW_MAX_MESSAGE_LEN 30
    > /// The maximum payload length
    > #define VW_MAX_PAYLOAD VW_MAX_MESSAGE_LEN-3
    > /// The size of the receiver ramp. Ramp wraps modulu this number
    > #define VW_RX_RAMP_LEN 160
    > /// Number of samples per bit
    > #define VW_RX_SAMPLES_PER_BIT 8
    > // Ramp adjustment parameters
    > // Standard is if a transition occurs before VW_RAMP_TRANSITION (80) in the ramp,
    > // the ramp is retarded by adding VW_RAMP_INC_RETARD (11)
    > // else by adding VW_RAMP_INC_ADVANCE (29)
    > // If there is no transition it is adjusted by VW_RAMP_INC (20)
    > /// Internal ramp adjustment parameter
    > #define VW_RAMP_INC (VW_RX_RAMP_LEN/VW_RX_SAMPLES_PER_BIT)
    > #define VW_RAMP_TRANSITION VW_RX_RAMP_LEN/2
    > #define VW_RAMP_ADJUST 9
    > #define VW_RAMP_INC_RETARD (VW_RAMP_INC-VW_RAMP_ADJUST)
    > #define VW_RAMP_INC_ADVANCE (VW_RAMP_INC+VW_RAMP_ADJUST)
    > /// Outgoing message bits grouped as 6-bit words
    > /// 36 alternating 1/0 bits, followed by 12 bits of start symbol
    > /// Followed immediately by the 4-6 bit encoded byte count,
    > /// message buffer and 2 byte FCS
    > /// Each byte from the byte count on is translated into 2x6-bit words
    > /// Caution, each symbol is transmitted LSBit first,
    > /// but each byte is transmitted high nybble first
    > #define VW_HEADER_LEN 8
    > // Cant really do this as a real C++ class, since we need to have
    > // an ISR
    > extern “C”
    > /// Set the digital IO pin to be for transmit data.
    > /// This pin will only be accessed if
    > /// the transmitter is enabled
    > /// \param[in] pin The Arduino pin number for transmitting data. Defaults to 12.
    > extern void vw_set_tx_pin(uint8_t pin);
    > /// Set the digital IO pin to be for receive data.
    > /// the receiver is enabled
    > /// \param[in] pin The Arduino pin number for receiving data. Defaults to 11.
    > extern void vw_set_rx_pin(uint8_t pin);
    > // Set the digital IO pin to enable the transmitter (press to talk, PTT)’
    > /// \param[in] pin The Arduino pin number to enable the transmitter. Defaults to 10.
    > extern void vw_set_ptt_pin(uint8_t pin);
    > /// By default the PTT pin goes high when the transmitter is enabled.
    > /// This flag forces it low when the transmitter is enabled.
    > /// \param[in] inverted True to invert PTT
    > extern void vw_set_ptt_inverted(uint8_t inverted);
    > /// Initialise the VirtualWire software, to operate at speed bits per second
    > /// Call this one in your setup() after any vw_set_* calls
    > /// Must call vw_rx_start() before you will get any messages
    > /// \param[in] speed Desired speed in bits per second
    > extern void vw_setup(uint16_t speed);
    > /// Start the Phase Locked Loop listening to the receiver
    > /// Must do this before you can receive any messages
    > /// When a message is available (good checksum or not), vw_have_message();
    > /// will return true.
    > extern void vw_rx_start();
    > /// Stop the Phase Locked Loop listening to the receiver
    > /// No messages will be received until vw_rx_start() is called again
    > /// Saves interrupt processing cycles
    > extern void vw_rx_stop();
    > /// Returns the state of the
    > /// transmitter
    > /// \return true if the transmitter is active else false
    > extern uint8_t vx_tx_active();
    > /// Block until the transmitter is idle
    > /// then returns
    > extern void vw_wait_tx();
    > /// Block until a message is available
    > /// then returns
    > extern void vw_wait_rx();
    > /// Block until a message is available or for a max time
    > /// \param[in] milliseconds Maximum time to wait in milliseconds.
    > /// \return true if a message is available, false if the wait timed out.
    > extern uint8_t vw_wait_rx_max(unsigned long milliseconds);
    > /// Send a message with the given length. Returns almost immediately,
    > /// and message will be sent at the right timing by interrupts
    > /// \param[in] buf Pointer to the data to transmit
    > /// \param[in] len Number of octetes to transmit
    > /// \return true if the message was accepted for transmission, false if the message is too long (>VW_MAX_MESSAGE_LEN - 3)
    > extern uint8_t vw_send(uint8_t* buf, uint8_t len);
    > // Returns true if an unread message is available
    > /// \return true if a message is available to read
    > extern uint8_t vw_have_message();
    > // If a message is available (good checksum or not), copies
    > // up to *len octets to buf.
    > /// \param[in] buf Pointer to location to save the read data (must be at least *len bytes.
    > /// \param[in,out] len Available space in buf. Will be set to the actual number of octets read
    > /// \return true if there was a message and the checksum was good
    > extern uint8_t vw_get_message(uint8_t* buf, uint8_t* len);
    > /// @example client.pde
    > /// Client side of simple client/server pair using VirtualWire
    > /// @example server.pde
    > /// Server side of simple client/server pair using VirtualWire
    > /// @example transmitter.pde
    > /// Transmitter side of simple one-way transmitter->receiver pair using VirtualWire
    > /// @example receiver.pde
    > #endif
The library is not properly installed. On my system, it is in Desktop/Arduino/libraries
Please use code tags for error messages/warnings and code, not quote tags.
I don’t know how you managed to copy the example wrong but you need to change line 42 of your code from
      Serial.print(buf, HEX);
to
      Serial.print(buf[i], HEX);
as in the receive example on the pjrc.com page.
With that change the code compiles for Uno without errors on Arduino IDE 1.6.8.
Which board are you using?
So I suspect the problem is caused by Arduino Studio which I would guess most people on this forum have little experience with. I would recommend you to try it with the arduino.cc IDE.
