Virtualwire not working with NODEMCU 12E
Hi ALL,
I’m doing project involving nodemcu 12e and virtual wire. When i compile the coding,there are some error that i couldn’t solve. Could anyone help me please??
The error is :-
C:\Program Files (x86)\Arduino\libraries\VirtualWire\VirtualWire.cpp:16:24: fatal error: util/crc16.h: No such file or directory
#include <util/crc16.h>
Below is my coding:
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h>
#include <ThingSpeak.h>
#include <VirtualWire.h>
SoftwareSerial NodeSerial(D2, D3); // RX | TX
WiFiClient client;
const char* ssid = "**";
const char
password = “********”;
const char
host = “ESP8266”;
int ledpin = 13;
uint8_t data[1];
int i;
pinMode(D2, INPUT);
pinMode(D3, OUTPUT);
NodeSerial.begin(9600);
Serial.println("Connecting to wifi: ");
Serial.println(ssid);
Serial.flush();
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println(" IP address: ");
pinMode(13, OUTPUT);
vw_set_ptt_inverted(true);
vw_set_tx_pin(36);// DATA tranmitter connect to pin dig. 36
vw_setup(2000);
while (NodeSerial.available() > 0) {
int BufferA = NodeSerial.parseInt();
Serial.println(BufferA);
i = (ThingSpeak.readIntField(,1,"*"));
if (i==1){
data[0] = 1;
digitalWrite(ledpin, HIGH);
vw_send(data, sizeof(data)); //Send data
vw_wait_tx();
//if (snap==0){
if (i==0){
data[0] = 0;
digitalWrite(ledpin,LOW);
TQ in advance.
Below is my coding:
Incorrectly posted, and it is NOT where the error is.
The compiler told you where the problem is. You need to investigate that code.
Does the VirtualWire folder contain a util folder? Does the util folder contain a crc.h file?
Why do you assume that the VirtualWire library (obsolete) will work on your not-really-an-Arduino?
