VirtualWire/RF Link problems
I got the 315MHZ receiver and transmitter from sparkfun.
But when I use the VirtualWire library I get a blank serial monitor.
Here is my code for receiver:
#include <VirtualWire.h>  // you must download and install the VirtualWire.h to your hardware/libraries folder
#undef int
#undef abs
#undef double
#undef float
#undef round
// Initialise the IO and ISR
    vw_set_ptt_inverted(true);    // Required for RX Link Module
    vw_setup(2000);              // Bits per sec
    vw_set_rx_pin(3);           // We will be receiving on pin 3 () ie the RX pin from the module connects to this pin.
    vw_rx_start();             // Start the receiver
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // check to see if anything has been received
    int i;
     // Message with a good checksum received.
    for (i = 0; i < buflen; i++)
        Serial.print(buf[i]);  // the received data is stored in buffer
    Serial.println("");
Code for transmitter:
#undef int
#undef abs
#undef double
#undef float
#undef round
    vw_set_ptt_inverted(true);        // Required for RF Link module
    vw_set_tx_pin(3);                // pin 3 is used as the transmit data out into the TX Link module, change this to suit your needs.
    const char *msg = "Hello, wireless World!";       // this is your message to send
   vw_send((uint8_t *)msg, strlen(msg));
   vw_wait_tx();                                          // Wait for message to finish
   delay(200);
At first i thought maybe my RF modules were bad, so I tried it using
the SoftwareSerial library, but that works.
I had my transmitter send a bunch of 7's to the receiver and the serial monitor displayed the 7's, plus a some other numbers, figure
that was just noise.
So my modules are fine, but I don't understand why using the VirtualWire library doesn't work.
I don't get any compiling error's, I have my serial monitor set to 2400.
I've tried other baud rates but I still get nothing.
This one has me stumped. I pretty much copied and pasted the code from here:http://letsmakerobots.com/node/12336
I just changed the pin numbers since Im not using a mega.
I'm using a Duemilanove w/328 as the receiver and a BBB from Modern devices as transmitter.
Ok I got this to work, this is how I did it in case anyone else has problems.
I set the vw_setup() to 1200 not 2000, and I set my serial monitor to 9600, the actual monitor, the code is already set to 9600.
Serial.begin(9600).
I don't know why the say to set your monitor to 2400 in that link I posted.
Do this for both the receiver and transmitter code.
Also if I have the RF pair more than a foot apart the signal drops
and I get nothing, this is without an antenna of course.
I 'll try with one and see if my range improves.
Download link ?
