I ordered a few RF Link modules and I have been working with VirtualWire recently. I have had some fun making a chat program and just some other fun stuff. I have been trying to use the VirtualWire library to send a value I get from one arduino to another. I just keep getting errors trying to do it.
I have read the documentation many times, it doesn't help much. I have looked through the library source, nothing. Finally giving in, hoping someone here will help.
P.S. The number I will be sending will be somewhere between 0 and 480.
Thanks in advance.
I've had good luck with VirtualWire. Tell us a bit more. It is usually best to paste the code that you're having trouble with in your post (use the # icon in the forum editor) and tell us what error that you're getting.
#include <VirtualWire.h> // you must download and install the VirtualWire.h to your hardware/libraries folder
#undef int
#undef abs
#undef double
#undef float
#undef round
// Initialise the IO and ISR
vw_set_ptt_inverted(true); // Required for RX Link Module
vw_setup(2000); // Bits per sec
vw_set_rx_pin(2); // We will be receiving on pin 23 (Mega) ie the RX pin from the module connects to this pin.
vw_rx_start(); // Start the receiver
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // check to see if anything has been received
int i, d;
d = buflen -1;
// Message with a good checksum received.
char string[d];
for (i = 0; i < buflen; i++)
string[i] == buf[i];
for (i = 0; i < buflen; i++) {
Serial.print(string[i]);
Transmitter:
#undef int
#undef abs
#undef double
#undef float
#undef round
vw_set_ptt_inverted(true); // Required for RF Link module
vw_set_tx_pin(3); // pin 3 is used as the transmit data out into the TX Link module, change this to suit your needs.
const char *msg = "1010"; // this is your message to send
vw_send((uint8_t *)msg, strlen(msg));
vw_wait_tx(); // Wait for message to finish
delay(200);
All I am trying to do right now is getting them to send an integer.
Geeko,
I modified that code to send an array of integers. You can modify the number of elements and assign whatever values to them. Don't forget to change the loop bounds if you change the number of array elements.
I commented out vw_set_tx_pin(3) and vw_set_rx_pin(2) because I do not have a Mega. I use the default Digital pin 12 for transmit, and pin 11 for receive.
I lowered speed too just to make sure it works, you're welcome to experiment and set them higher.
PS: I learned a new command while helping you: word(hi,low) combines two bytes into an integer. A bit easier to read than bitshifts.
Good luck with your project!
// TRANSMITTER
int numbers[3]; // Change 3 to number of integers you wish to send.
vw_setup(1000); // Bits per sec
//vw_set_tx_pin(3); // pin 3 is used as the transmit data out into the TX Link module, change this to suit your needs.
// Initialize to some sample values
numbers[0] = 32767;
numbers[1] = -2;
numbers[2] = 0;
vw_send( (uint8_t *)numbers, sizeof(numbers));
numbers[0]--; // decrement
numbers[1]++; // increment
numbers[2]++; // increment
// RECEIVER
Serial.begin(4800);
//vw_set_rx_pin(2); // We will be receiving on pin 23 (Mega) ie the RX pin from the module connects to this pin.
Serial.println("Receiver ready!");
Serial.print(buflen, DEC);
Serial.println(" bytes received!");
for (int i = 0; i < buflen; i++)
Serial.print("buf[");
Serial.print(i, DEC);
Serial.print("]=");
Serial.print(buf[i], DEC);
Serial.print(" ");
//memcpy(buf, numbers, buflen);
for (int i = 0; i < 3; i++)
numbers[i] = word(buf[i*2+1], buf[i*2]);
Serial.print("numbers[");
Serial.print("]=");
Serial.print(numbers[i], DEC);
Serial.print(" ");
delay(50);
