VirtualWire VS liquid Crystal, Bad idea ?
Hi guys !
I'm working on little project with virtualWire to create 433 mhz command.
To test it i use another Arduino with LCD Keypad Shield of Saint Smart.
But i got issue when i try to use the LCD with VirtualWire.
The backlight stay black ..
I've already read some topic about this probleme before so i've tried to change the RX and TX pin of virtualWire but it's dont work.
I need to connect GND on the K pin of my Shield to have backlight works..
Here is my code :
#include <LiquidCrystal.h>
#include <VirtualWire.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);// Liquid Crystal setup
lcd.begin(16, 2); // start the LCD
Serial.begin(9600); // strart Serial
vw_set_rx_pin(11); // Set different RX PIN
vw_setup(2000); // set Bits per sec
vw_rx_start(); // Start the receiver
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
// Message with a good checksum received, dump it.
Serial.print("Got: ");
lcd.clear();//Clear LCD before print new char
lcd.setCursor(0,0);//Set cursor tu line 1
lcd.print("RECEPTION : ");
lcd.setCursor(0,1);// Set cursor to line 2
for (i = 0; i < buflen; i++)
Serial.print(buf*, HEX);*
_ lcd.print(buf*, HEX);_
_ Serial.print(" ");_
_
}_
_ Serial.println("");_
_
}_
_
}_
_
[/quote]_
The receiver is connected to pin 11 ( not used by the shield )
Sorry for my bad english.
_
.Ju*_
In the Sainsmart lcd shield, the backlight is on pin 10.
I believe, even though you have the lcd shield on the receiver, and have an RX sketch, there could be a conflict with the the PTT (Push to Talk) transmit enable pin 10 default setting of Virtual Wire library.
Use the setup command vw_set_ptt_pin(some unused pin number) and see if the backlight comes back.
Why not use RadioHead instead?
