visit web
i am trying to save my external IP to my web page at my domain using arduino
this is my php script for save IP at xxxx.net
<html>
  </head>
  <body>
  <?php
        $data = $_SERVER['REMOTE_ADDR'];
        $file = "ip.txt";
        $file = fopen($file, "wa+");
        fwrite($file, $data);
        fclose($file);
  </body>
</html>
for arduino i use
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {  0x00, 0xAB, 0xCB, 0xCD, 0xDE, 0x02 };
IPAddress ip(192,168,1,43);
IPAddress server(0,0,0,0);
EthernetClient client;
void connect(){
  if (client.connect(server, 80)) {
      Serial.print("Make a HTTP request ... ");
      client.println("HOST: xxxx.net/xxx.php");
      client.println();
      Serial.println("ok");
    else {
      // kf you didn't get a connection to the server:
      Serial.println("connection failed");
  Serial.print("Setup LAN ... ");
  // give the Ethernet shield a second to initialize:
  Ethernet.begin(mac, ip);
  connect();
void loop(){
if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    delay(3000);
    connect();
and this is answer
<title>400 Bad Request</title>
</head><body>
<h1>Bad Request</h1>
<p>Your browser sent a request that this server could not understand.
</p>
i dont understand arduino. please help
That doesn’t make any sense.
The PHP script just logs the IP addresses of all HTTP requests to a file.
The Arduino script sends “HOST: xxxx.net - This website is for sale! - xxxx Resources and Information.” over a TCP connection to the server.
Your server is expecting an HTTP request, and you’re just sending text that it doesn’t understand, so it sends a 400 error.
Read up on the HTTP protocol.
Pieter
ok. i found this one. and it works
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char server[] = "www.xxxx.net";
// Set the static IP address to use if the DHCP fails to assign
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("SERIAL: Failed to configure Ethernet using DHCP");
  Serial.println("SERIAL: connecting...");
  // if you get a connection, report back via serial:
     client.print("GET /run.php");
     client.println(" HTTP/1.1");
     client.println("Host: www.xxxx.net");
     client.println("User-Agent: Arduino");
     client.println("Accept: text/html");
     client.println("Connection: close");
     client.println();
  else {
    // if you didn't get a connection to the server:
    Serial.println("SERIAL: connection failed");
  // if there are incoming bytes available, print them
    Serial.print(c);
    client.stop();
    // do nothing forevermore:
    while(true);
now, i have problem how to repeat it every hour
mato85: now, i have problem how to repeat it every hour
I'm going to let you figure that out by yourself.
