I am trying to setup a connection between VB Studio and my arduino so that I can eventually make an HMI, however, things are not going well. I am quite new to arduinos and have been looking around the forums to find an explanation or a tutorial for how to connect the two.
I have a VB form open, and my arduino connected via USB and a serial port is placed on the form (configured to COM6, same as the arduino). Basically all I am trying to do is just get some type of feedback in the way of VB output so I know that it is working.
I can show you the Arduino code. I don't know VB but I know C#.
int ledPin = 13; // select the pin for the LED
int val = 0; // variable to store the data from the serial port
pinMode(ledPin,OUTPUT); // declare the LED's pin as output
Serial.begin(9600); // connect to the serial port
void loop (){
if( Serial.available()>0){
val = Serial.read(); // read the serial port
if(val==1) //checks the value
digitalWrite(ledPin, HIGH); //if the value from serial port is 1 then turn LED on
if(val==0)
digitalWrite(ledPin, LOW); //if the value from serial port is 0 then turn LED off
Serial.println("Error");
The code is simplest. You read the string value from serial port and if it's 1 it turns LED on pin 13 on, or if it's 0 it turns LED off. In VB you need two buttons (On button and Off button) and each of them sends strings 1 or 0 with serial write.
