Visual C for create DAQ system
Dear All,
I would like to create a GUI which can be plot the sensor datas ( like DAQ systems).
I think the microsoft visual studio is good choice for this project, but i don't understand how can i create a program which communicate my arduino uno.
On the internet, the most popular answer for my question is that "why don't you use serial port?"
But I would like plot 3 or more sensors datas and I don't understand how can it be possible, how can I separate the datas (which the 1. sensor value which the 2. sensor value etc...)
How are you doing? How are you solving this problem?
Best regards,
Thuugo
Visual Studio is a program development product that allows you to develop applications in a variety of languages, including C++ and C#.
In C++, it's not a trivial process to correctly configure the serial port, and it is not a trivial process to get serial data to the thread managing the UI.
In C#, it's a trivial process to correctly configure the serial port, and it is a trivial process to get serial data to the thread managing the UI.
You choose.
That's because it's the only answer.
Have you ever been to a party with 3 friends? How do you know which friend is talking?
Suppose that the data arriving on the serial port looked like "Howard: It's 37 degrees out" or "Sam: It's 89% humidity out here" or "Thomas: Its blowing 3 mph out here". Would you have any trouble separating temperature, humidity, and wind speed?
Can you imagine how to make the Arduino send data that way? Can you imagine a simpler way?
This Python - Arduino demo may give you some ideas. The same basic principles apply whichever language you use.
This Python GUI demo may be of interest.
...R
Thanks for the answer.
No i can't imagine a simpler way, just in case people are experienced in the subject than I do.
I will keep trying to understand how this communicate works.
As I guess, I will send the datas in one line with separating caracters to the serial port and I will create a protocol in c# which spearate the datas (using the special caracters) then put the correct data to a variable.
Is it able to a correct solution?
Best regards,
Thuugo
How about "1:37", "2:89", "3:3"?
