Hello guys,
I was searching how to make multi layer arduino solution in Visual Studio 2017 and I decided to ask to forum.arduino.cc . While I writing a question topic , I found the solution
Now, this is not a question. This is a learn topic.
Layers like this:
---> MySeatSolution(Solution)
-------> MySeatProject.Core (Library Project)
-------> MySeatProject.Model1 (Sketch1)
-------> MySeatProject.Model2 (Sketch2)
I tried some things. My step :
1) Create New Arduino Library Project
formula weight of aluminum sulfate
2) Add Two Sketch Projects to Solution
now, my solution looks like :
3) Creating a "SerialConsole" Common Class To CoreLibrary Project
4) SerialConsole.h
#pragma once
class SerialConsole
public:
SerialConsole();
~SerialConsole();
void TestPrint();
5) SerialConsole.cpp
#include "SerialConsole.h"
SerialConsole::SerialConsole()
SerialConsole::~SerialConsole()
void SerialConsole::TestPrint()
Serial.println("Test Message");
If you saw it, there's a problem. "Serial" is undefined. But I'll solve this problem at next steps.
6) Adding as a reference to Sketch1 Project
7) Now, problem in step 5 is solved
8 ) Time To Build !
**ERROR
SerialConsole.cpp: 11:2: error: 'Serial' was not declared in this scope
Error compiling libraries
Build failed for project 'Sketch1'
9 ) Add (#include "ESP8266WiFi.h") To SerialConsole.cpp and h
and happy end
Build Success...
Compiling 'Sketch1' for 'NodeMCU 1.0 (ESP-12E Module)'
Program size: 249.059 bytes (used 24% of a 1.044.464 byte maximum) (2,63 secs)
Minimum Memory Usage: 33084 bytes (40% of a 81920 byte maximum)
