Visual Studio Code and a portable Arduino IDE
I picked up a nice trick on these fora wherein one can safely and easily run different versions of the IDE by setting each up as a "portable" installation.
Now I would like to try Visual Studio Code as a step up from the Arduino IDE, but I stick at a very early move, which states that I need to have "the" Arduino IDE installed.
I'll keep googling, but so far I cannot find if and how if it is possible to use VSC hooked up to a "portable" IDE.
If you have done this, how? If you know this is not possible tell me! I'll have to weigh going un-portable with the Arduino IDE, TBH I mostly use just one anyway, against the benefits of the VSC.
Mostly I am OK with the Arduino IDE, but I do understand the criticisms and comments that appear from time to time and thought I would see about something more whatever.
TIA
a7
You can configure the path to the Arduino IDE installation in the VS Code extension's section of settings.json:
Option Description
arduino.path Path to Arduino, you can use a custom version of Arduino by modifying this setting to include the full path. Example: C:\Program Files\Arduino for Windows, /Applications for Mac, /home//Downloads/arduino-1.8.1 for Linux. (Requires a restart after change). The default value is automatically detected from your Arduino IDE installation path.
THX and a tip o’ the hat @pert.
a7
