Visual Studio Code mit Platform-IO-Plugin neu eingerichtet. ESP8266 Blinkdemo-Code wird nicht neu compiliert
Hat funktioniert.
Und da fangen die Probleme an.
ESP8266 gen DEV module eingestellt.
Diesen Demo-Code geflasht.
#include "Arduino.h"
const byte OnBoard_LED = 2;
  Serial.begin(74880);
  delay(2000);
  Serial.println("Setup-Start");
  // initialize LED digital pin as an output.
  pinMode(OnBoard_LED, OUTPUT);
  digitalWrite(OnBoard_LED, HIGH);
  Serial.println("LED HIGH");
  digitalWrite(OnBoard_LED, LOW);
  Serial.println("LED LOW");
PIO meldet "success"
Details aus dem Log
Executing task in folder myESP8266-Test: C:\Users\dipl-\.platformio\penv\Scripts\platformio.exe run --target upload
Processing esp07s (platform: espressif8266; board: esp07s; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp07s.html
PLATFORM: Espressif 8266 (4.2.1) > Espressif Generic ESP8266 ESP-07S
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
PACKAGES:
 - framework-arduinoespressif8266 @ 3.30102.0 (3.1.2)
 - tool-esptool @ 1.413.0 (4.13)
 - tool-esptoolpy @ 1.30000.201119 (3.0.0)
 - tool-mklittlefs @ 1.203.210628 (2.3)
 - tool-mkspiffs @ 1.200.0 (2.0)
 - toolchain-xtensa @ 2.100300.220621 (10.3.0)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 37 compatible libraries
Scanning dependencies...
No dependencies
Building in release mode
Retrieving maximum program size .pio\build\esp07s\firmware.elf
Checking size .pio\build\esp07s\firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM:   [===       ]  34.2% (used 28008 bytes from 81920 bytes)
Flash: [==        ]  24.9% (used 260411 bytes from 1044464 bytes)
Configuring upload protocol...
AVAILABLE: espota, esptool
CURRENT: upload_protocol = esptool
Looking for upload port...
Auto-detected: COM7
Uploading .pio\build\esp07s\firmware.bin
esptool.py v3.0
Serial port COM7
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 5c:cf:7f:0b:9b:26
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Compressed 264560 bytes to 195063...
Writing at 0x00000000... (8 %)
Writing at 0x00004000... (16 %)
Writing at 0x00008000... (25 %)
Writing at 0x0000c000... (33 %)
Writing at 0x00010000... (41 %)
Writing at 0x00014000... (50 %)
Writing at 0x00018000... (58 %)
Writing at 0x0001c000... (66 %)
Writing at 0x00020000... (75 %)
Writing at 0x00024000... (83 %)
Writing at 0x00028000... (91 %)
Writing at 0x0002c000... (100 %)
Wrote 264560 bytes (195063 compressed) at 0x00000000 in 17.2 seconds (effective 123.3 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
=========================================== [SUCCESS] Took 21.33 seconds ===========================================
 *  Terminal will be reused by tasks, press any key to close it.
 *  Executing task in folder myESP8266-Test: C:\Users\dipl-\.platformio\penv\Scripts\platformio.exe run --target upload
PACKAGES:
No dependencies
Auto-detected: COM7
esptool.py v3.0
Serial port COM7
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
Leaving...
=========================================== [SUCCESS] Took 21.29 seconds
ESP8266 sollte eigentlich die Onboard LED blinken aber nix passiert.
Genau den gleichen Code in die Arduino-IDE
flashen => Onboard-LED blinkt plus serielle Ausgabe
Das Tutorial ist so "quick" das da überhaupt nichts steht weswegen jetzt das Log zwar anzeigt es hätte den Code erfolgreich hochgeladen aber auf dem ESP8266 die LED nicht blinkt.
Ich habe den Eindruck es wurde überhaupt nicht neu compiliert obwohl ich auf den Build-Button geklickt habe.
Und jetzt geht diese elende Sucherei los:
  • welcher Konfigurations-Schalter ist da falsch gesetzt?
  • wo muss man anstatt auf "build" hinklicken ??
  • welche Angaben werden jetzt von den Experten benötigt um verschiedene Sachen zu überprüfen.
    usw. usw. usf. usf.
Mann EY ! grmbll!
Die Zauberei geht so:
Mal ein Geschwindigkeitsvergleich zur (alten) Arduino IDE
Verstehe ich jetzt nicht, er hat doch einen Sketch kompiliert und hochgeladen.
Der funktioniert nur nicht ....
cu
Noch ergänzend zum ersten Video.
Wenn man mal in Ruhe die Punkte bei PlatformIO links in der Befehlsleiste durchgeht, wird einem schon vieles klarer. Bevor man das wie in dem gezeigten Video machen kann, muss man erst mal die Plattform installieren. In der Arduino IDE frickelt man dazu einen Link bei den Einstellungen an der richtigen Platz.
Bei PlatformIO wählt man die Plattform halt unter dem Punkt Platforms aus. Analog dazu kann man über Libraries die Bibliotheken suchen und zum jeweiligen Projekt installieren. Diese gelten nicht für alle Projekte sondern nur für das, für das sie auch installiert wurden. So wird "Library-Salat" vermieden und man wundert sich nicht, warum nach einem Update einer Bibliothek bei dem einem Projekt, das "andere" nicht mehr funktioniert, weil die Bibliothek dafür plötzlich "zu neu" ist
Er sagte:
Im Video sieht man wie es aussieht, wenn compiliert und hochgeladen wird.
Und die Onboard LED blinkt dann auch. Muss man mir jetzt so glauben, auch wenn ich den Beweis schuldig bleibe. Da mach ich kein extra Video für.
Noch einmal:
Ich habe die Visual Studio Code setup-exe durchlaufen lassen
Ich habe nach Anleitung Das platformIO-plugin installiert.
Die Unterschiede zwischen deinem Video und dem was bei mir passiert sind folgende
Details hier aufklappen
nach dem Neustart von Visual Studio-Code sehe ich diesen Fensterinhalt
Durch herumklicken habe ich dann herausgefunden dass ich auf diesen Refresh-Button klicken muss.
Dann wird für eine halbe Sekunde dein Fensterinhalt angezeigt
Nach einer halben Sekunde verschwindet das sofort wieder
Nun ja. Ich habe es geschafft schnell genug zu klicken und diese Eintragungen in
neues Projekt gemacht
Project-"Wizard" arbeitet
Fragt mich dann
ich klicke auf "yes"
Ich klicke auf src - main.cpp
code per copy - mark-all - paste einfügen
compilieren hat funktioniert
Executing task in folder my3rdESP8266-Testproject: C:\Users\dipl-\.platformio\penv\Scripts\platformio.exe run
PACKAGES:
No dependencies
Compiling .pio\build\esp07s\src\main.cpp.o
Generating LD script .pio\build\esp07s\ld\local.eagle.app.v6.common.ld
Archiving .pio\build\esp07s\libFrameworkArduinoVariant.a
Compiling .pio\build\esp07s\FrameworkArduino\Crypto.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\Esp-frag.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\Esp-version.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\FS.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\FSnoop.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\FunctionalInterrupt.cpp.o
src\main.cpp: In function 'void setup()':
src\main.cpp:8:7: warning: unused variable 'result' [-Wunused-variable]
    8 |   int result = myFunction(2, 3);
Compiling .pio\build\esp07s\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\LwipDhcpServer-NonOS.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\LwipDhcpServer.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\LwipIntf.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\LwipIntfCB.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\Print.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\Schedule.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\StackThunk.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\StreamSend.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\TypeConversion.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\Updater.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\abi.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\aes_unwrap.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\cont.S.o
Compiling .pio\build\esp07s\FrameworkArduino\cont_util.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_app_entry_noextra4k.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_eboot_command.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_features.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_flash_quirks.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_flash_utils.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_i2s.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_main.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_non32xfer.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_noniso.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_phy.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_postmortem.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_si2c.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_sigma_delta.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_spi_utils.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_timer.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_vm.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_waveform_phase.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_waveform_pwm.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_wiring.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_wiring_analog.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_wiring_digital.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_wiring_pulse.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_wiring_pwm.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\core_esp8266_wiring_shift.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\crc32.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\debug.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\exc-c-wrapper-handler.S.o
Compiling .pio\build\esp07s\FrameworkArduino\exc-sethandler.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\flash_hal.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\gdb_hooks.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\heap.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\hwdt_app_entry.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\libb64\cdecode.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\libb64\cencode.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\libc_replacements.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\mmu_iram.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\reboot_uart_dwnld.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\spiffs\spiffs_cache.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\spiffs\spiffs_check.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\spiffs\spiffs_gc.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\spiffs\spiffs_hydrogen.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\spiffs\spiffs_nucleus.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\spiffs_api.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\sqrt32.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\stdlib_noniso.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\time.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\uart.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\umm_malloc\umm_info.c.o
Compiling .pio\build\esp07s\FrameworkArduino\umm_malloc\umm_integrity.c.o
Compiling .pio\build\esp07s\FrameworkArduino\umm_malloc\umm_local.c.o
Compiling .pio\build\esp07s\FrameworkArduino\umm_malloc\umm_malloc.cpp.o
Compiling .pio\build\esp07s\FrameworkArduino\umm_malloc\umm_poison.c.o
Compiling .pio\build\esp07s\FrameworkArduino\wpa2_eap_patch.cpp.o
Archiving .pio\build\esp07s\libFrameworkArduino.a
Linking .pio\build\esp07s\firmware.elf
Building .pio\build\esp07s\firmware.bin
Creating BIN file ".pio\build\esp07s\firmware.bin" using "C:\Users\dipl-\.platformio\packages\framework-arduinoespressif8266\bootloaders\eboot\eboot.elf" and ".pio\build\esp07s\firmware.elf"
=========================================== [SUCCESS] Took 20.05 seconds ===========================================
Ich klicke Upload. Hier das Log dazu
Executing task in folder my3rdESP8266-Testproject: C:\Users\dipl-\.platformio\penv\Scripts\platformio.exe run --target upload
PACKAGES:
No dependencies
Auto-detected: COM7
esptool.py v3.0
Serial port COM7
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
Leaving...
=========================================== [SUCCESS] Took 21.35 seconds ===========================================
tja und LED des ESP8266 blinkt NICHT !
Wenn ich am ESP8266 den Resettaster drücke dann zeigt der serielle Monitor
16:51:38.955 ->
16:51:38.955 ->  ets Jan  8 2013,rst cause:2, boot mode:(3,6)
16:51:38.955 ->
16:51:38.955 -> load 0x4010f000, len 3424, room 16
16:51:38.955 -> tail 0
16:51:38.955 -> chksum 0x2e
16:51:38.955 -> load 0x3fff20b8, len 40, room 8
16:51:38.955 -> chksum 0x2b
16:51:38.955 -> csum 0x2b
16:51:38.955 -> v00040970
16:51:38.955 -> ~ld
16:51:39.049 -> rf cal sector: 1020
16:51:39.049 -> freq trace enable 0
16:51:39.049 -> rf[112] : 0
Also irgendwas an der Betonung beim Aussprechen des "Zauberspruchs" passt noch nicht.
Dann habe ich im Code an den Serial.prints ein bisschen was geändert. main.cpp neu gespeichert und dann Upload geklickt
Es findet keine Neucompilierung statt.
Log
 *  Executing task in folder my3rdESP8266-Testproject: C:\Users\dipl-\.platformio\penv\Scripts\platformio.exe run --target upload
PACKAGES:
No dependencies
Auto-detected: COM7
esptool.py v3.0
Serial port COM7
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
Leaving...
So und "aktiv lernen" wie Tommy das ausdrückt besteht jetzt da drin, das man einfach von vorne bis hinten die ganze Doku liest (man will ja sowieso alle Details wissen ) um dann in der Lage zu sein ein erstes MIniprogramm ein weiteres mal zu flashen?
Also bitte !
Das "Getting started" ist wohl so gemeint: Den allerersten Anfang zeigen wir dir noch
Aber dann musste den Rest durch Doku lesen herausfinden.
sigh!
Bei mir waren die benötigten Frameworks, Tools und Toolchains schon installiert. Darum sah das bei Dir ein wenig anders aus. Das macht der aber nur einmal ... halt wenn was fehlt.
Bzw. hier muss ich mich korrigieren. Bei Deiner Ausgabe zeigt er ja nur an, was alles verwendet wurde. Das war in meinem Video genau so...
Was ist daran so schlimm? Dazu wird Doku geschrieben. Damit die jemand liest.
Wird ungerne gemacht. Ich weiß. Darum ist das Forum auch voll von Fragen, die sich die Leute selber beantworten könnten, wenn Sie statt stundenlang aufs Geratewohl herum zu probieren mal Doku lesen würden.
Aber das ist ja irgendwie uncool.
Das entscheidene ist nach compilieren und upload
Arduino-IDE: LED blinkt - PlatformIO: Led blinkt nicht
PlatformIO
LED blinkt nicht.
keine serielle Ausgabe
platform_IO zeigt im Log compilieren und upload an
PACKAGES:
No dependencies
Auto-detected: COM7
esptool.py v3.0
Serial port COM7
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
Leaving...
Aber auf dem ESP8266 scheint kein Code drauf zu sein
oder in einer Form, dass er jedenfalls nicht ausgeführt wird.
jedenfalls blinkt die LED nicht.
Wenn genau der gleiche Code mit Arduino-IDE geflasht wird
dann blinkt die LED
So und woran liegt das jetzt?
Bei Project & Configuration "monitor_speed" aus der Auswahlliste auswählen und 74880 eintragen. Rechts Oben mit "Save" abschließen.
Das Terminal wird durch einen Klick auf den Stecker in der Werkzeugleiste unten gestartet.
Warum Deine LED nicht blinkt weiß ich nicht... Vielleicht falsches Board ausgewählt?
Eins ohne X am Ende
Aso wen in der IDE Faches Board eigestellt wird dann ist nix mit hochladen.
Kann sein. Ich weiß üblicherweise was ich verwende ... darum sehe ich das nicht als Problem.
Habe es gerade ausprobiert. Bei mir ist es egal ob ich esp07s oder esp12e auswähle ... funktioniert beides. Es blinkt. Auch wenn ich einen esp12e verwende und das esp07s Profil auswähle.
Kommentar zu "aktiv" lernen
Also es gibt verschiedene Arten Lernstoff zu präsentieren.
Die effektivste ist: als Erstes einen Überblick geben.
Über = "von oben draufschauen" Blick = visuell
In Bezug auf eine Programmierumgebung heißt das
Startbildschirm als Bild zeigen.
Visuell: Wenn einzelne Element im Text benannt werden Bild dazu.
Und wirklich effektiv ist das wenn es für ALLE Elemente gemacht wird.
Und ergänzend auch noch Hinweispfeile in der Gesamtansicht.
Thommy nennt das dann
Wenn man Spaß am in-effektiv lernen (= ich lese erst mal ALLES) hat ist das natürlich was anderes.
Du hast genau meine Aussage bestätigt.
Wenn Du Dokus nach Deinem Geschmack willst, dann schreibe welche.
Andere können Datenblätter lesen und - oh Wunder - die haben ein Inhaltsverzeichnis, so dass man nicht alles am Anfang lesen muss.
Aber das hatten wir alles schon mal. Ich halte diese Diskussion für Zeitverschwendung und klinke mich hier aus.
Gruß Tommy
Aber nur wenn das Boards signifikante für die IDE erkennbare Unterschiede aufweist.
cu
