if somebody starts to learn to program for arduino it happens quite often
that there is a pretty big difference between what the imagination of how much work it is and how much work it really is.
I had this idea to create a description that uses easy to understand pictures to explain it.
So if somebody has just started from zero to write programs her / his knowledge might be like this
After a short time some very basic things work. But this is not yet the final thing.
The final thing shall have more funcionality than the very simple lego-car shown above.
And simply from not knowing it because somebody has no experience yet her / his imagination how much work it will be to realise this wanted functionality is similar to this
A lego-car like this cool shaped and the wheels are able to rotate. It takes about 10 to 20 minutes to build it.
This newcomer might think "just show me in which spare-part-box will I find this cool shaped bricks and just quickly show me where to plug them in.
In reality the wanted functionity looks like this
Oh ! Yes I see. Ok even an experienced user needs some hours to build such a car
It might be that experienced users have build cars that look like this
Surely a car with steerable frontwheels and suspension but pretty different parts.
To modify the red car to look like the black car is doable but requires
- taking different parts (different hardware)
- still a lot of work to modify it
The user that has build the red car can give advice how to build the parts:
the frontwheel section is build like this
But as a newcomer you should build your final thing with steps inbetween that are easier tasks like these
of course this will take additional time. But after learning these steps inbetween
you will become independent of the advice of experienced users ´
- next plug this brick
- next plug this brick...
it might turn out that on the way to build the final functionality it is nescessary to change from this kind of suspension
to something like this
still a suspension but different parts (= different code) but still the same basic functionality suspension
and on the way to learn this more advanced way it might be useful to do an exercise like this
All newcomers that show own effort in learning can be sure that they will get helping support. Very detailed, good tailored support that really helps.
My observation how most users react is
Egoistic users that are calling for "ready to use code" will receive either no answer at all or very short very generalised hints to tutorials where they can learn themself.
Which of course is the opposite what they called for.
best regards Stefan
