HI there,i use visuino 8.0.0.2 and i was finished design diagram component.and after that i compiled to arduino IDE.the problem occured in arduino ide.i also search on google about visuino problem generated code in arduino ide,but i didnt find it.can anyone help?.thanks
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\ridho\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\ridho\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ridho\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10812 -build-path C:\Users\ridho\AppData\Local\Temp\arduino_build_147767 -warnings=none -build-cache C:\Users\ridho\AppData\Local\Temp\arduino_cache_849246 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\ridho\Documents\Visuino\Generated\Generated.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\ridho\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\ridho\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ridho\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10812 -build-path C:\Users\ridho\AppData\Local\Temp\arduino_build_147767 -warnings=none -build-cache C:\Users\ridho\AppData\Local\Temp\arduino_cache_849246 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\ridho\Documents\Visuino\Generated\Generated.ino
Using board 'uno' from platform in folder: C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Using core 'arduino' from platform in folder: C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Detecting libraries used...
"C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\ridho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\ridho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "C:\Users\ridho\AppData\Local\Temp\arduino_build_147767\sketch\Generated.ino.cpp" -o nul
Alternatives for OpenWire.h: [Mitov]
ResolveLibrary(OpenWire.h)
-> candidates: [Mitov]
"C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\ridho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\ridho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "-IC:\Users\ridho\Documents\Arduino\libraries\Mitov" "C:\Users\ridho\AppData\Local\Temp\arduino_build_147767\sketch\Generated.ino.cpp" -o nul
Generating function prototypes...
"C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\ridho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\ridho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "-IC:\Users\ridho\Documents\Arduino\libraries\Mitov" "C:\Users\ridho\AppData\Local\Temp\arduino_build_147767\sketch\Generated.ino.cpp" -o "C:\Users\ridho\AppData\Local\Temp\arduino_build_147767\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\ridho\AppData\Local\Temp\arduino_build_147767\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\ridho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\ridho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\ridho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "-IC:\Users\ridho\Documents\Arduino\libraries\Mitov" "C:\Users\ridho\AppData\Local\Temp\arduino_build_147767\sketch\Generated.ino.cpp" -o "C:\Users\ridho\AppData\Local\Temp\arduino_build_147767\sketch\Generated.ino.cpp.o"
Generated:116:10: error: 'ConstantProperty' is not a member of 'Mitov'
Mitov::ConstantProperty<51, bool, false>, // InitialValue
Generated:116:42: error: wrong number of template arguments (3, should be 2)
In file included from C:\Users\ridho\Documents\Visuino\Generated\Generated.ino:17:0:
C:\Users\ridho\Documents\Arduino\libraries\Mitov/Mitov.h:2257:60: note: provided for 'template<int C_PIN_NUMBER, bool T_INITIAL_VALUE> class Mitov::ArduinoDigitalChannel'
template<int C_PIN_NUMBER, bool T_INITIAL_VALUE> class ArduinoDigitalChannel
Generated:116:43: error: expected unqualified-id before ',' token
Generated:117:26: error: expected initializer before '<' token
Mitov::ConstantProperty<22, bool, false>, // IsAnalog
Generated:131:8: error: 'ArduinoDigitalChannel_5' in namespace 'BoardDeclarations::Types' does not name a type
Types::ArduinoDigitalChannel_5 ArduinoDigitalChannel_5;
Generated:136:52: error: 'AnalogPin_EmbeddedPinImplementation' is not a member of 'Mitov'
typedef Mitov::ArduinoAnalogInputChannel<0, Mitov::AnalogPin_EmbeddedPinImplementation<1, ::PinCalls::PinCallerReceive0 >> ArduinoAnalogInputChannel_0;
C:\Users\ridho\Documents\Visuino\Generated\Generated.ino:136:52: note: suggested alternative: 'AnalogPin_StandardPinImplementation'
Generated:136:103: error: wrong number of template arguments (3, should be 1)
C:\Users\ridho\Documents\Arduino\libraries\Mitov/Mitov.h:2004:35: note: provided for 'template class Mitov::ArduinoAnalogInputChannel'
template class ArduinoAnalogInputChannel
Generated:136:121: error: expected unqualified-id before '>' token
Generated:141:8: error: 'ArduinoAnalogInputChannel_0' in namespace 'BoardDeclarations::Types' does not name a type
Types::ArduinoAnalogInputChannel_0 ArduinoAnalogInputChannel_0;
Generated:152:9: error: 'Mitov::Timer' is not a template
typedef Mitov::Timer<
Generated:153:10: error: 'ConstantProperty' is not a member of 'Mitov'
Mitov::ConstantProperty<3, bool, false >, // AutoRepeat
Generated:153:43: error: expected unqualified-id before ',' token
Generated:154:26: error: expected initializer before '<' token
Mitov::ConstantProperty<4, bool, true >, // CanRestart
Generated:164:8: error: 'Timer1' in namespace 'Declarations::Types' does not name a type
Types::Timer1 Timer1;
Generated:169:9: error: 'Mitov::SpeedToClock' is not a template
typedef Mitov::SpeedToClock<
Generated:170:10: error: 'GenericPin_EmbeddedPinImplementation' is not a member of 'Mitov'
Mitov::GenericPin_EmbeddedPinImplementation<1, ::PinCalls::PinCallerReceive2 >, // ClockOutputPin
C:\Users\ridho\Documents\Visuino\Generated\Generated.ino:170:10: note: suggested alternative: 'AnalogPin_StandardPinImplementation'
Generated:170:81: error: expected unqualified-id before ',' token
Generated:171:53: error: invalid declarator before ',' token
Mitov::DigitalPin_DirectBoardPinImplementation<4 >, // DirectionOutputPin
Generated:172:26: error: expected initializer before '<' token
Mitov::ConstantProperty<4, bool, true >, // Enabled
Generated:180:8: error: 'SpeedToClock1' in namespace 'Declarations::Types' does not name a type
Types::SpeedToClock1 SpeedToClock1;
Generated:189:1: error: 'Mitov::Convert_BinaryToClock' is not a template
Mitov::Convert_BinaryToClock<Mitov::TypedVariable<0, bool, ::ComponentVariables::Variable4 >> Converter0;
Generated:189:37: error: 'TypedVariable' is not a member of 'Mitov'
C:\Users\ridho\Documents\Visuino\Generated\Generated.ino:189:37: note: suggested alternative: 'TypedSerialPort'
TypedSerialPort
TypedSerialPort
Generated:189:92: error: expected unqualified-id before '>' token
Generated:190:1: error: 'Mitov::Convert_BinaryToClock' is not a template
Mitov::Convert_BinaryToClock<Mitov::TypedVariable<0, bool, ::ComponentVariables::Variable5 >> Converter1;
Generated:190:37: error: 'TypedVariable' is not a member of 'Mitov'
C:\Users\ridho\Documents\Visuino\Generated\Generated.ino:190:37: note: suggested alternative: 'TypedSerialPort'
TypedSerialPort
TypedSerialPort
Generated:190:92: error: expected unqualified-id before '>' token
C:\Users\ridho\Documents\Visuino\Generated\Generated.ino: In member function 'void PinCalls::PinCallerReceive0::Notify(void*)':
Generated:207:28: error: 'SpeedToClock1' is not a member of 'Declarations::Instances'
Declarations::Instances::SpeedToClock1.InputPin_o_Receive( _Data );
C:\Users\ridho\Documents\Visuino\Generated\Generated.ino: In member function 'void PinCalls::PinCallerReceive1::Notify(void*)':
Generated:212:19: error: 'Converter0' is not a member of 'TypeConverters'
TypeConverters::Converter0.Convert( _Data, PinCallerConverterReceive1 );
Generated:213:33: error: 'ArduinoDigitalChannel_5' is not a member of 'BoardDeclarations::Instances'
BoardDeclarations::Instances::ArduinoDigitalChannel_5.DigitalInputPin_o_Receive( _Data );
C:\Users\ridho\Documents\Visuino\Generated\Generated.ino: In function 'void PinCalls::PinCallerConverterReceive1(void*)':
Generated:218:28: error: 'Timer1' is not a member of 'Declarations::Instances'
Declarations::Instances::Timer1.ResetInputPin_o_Receive( _Data );
C:\Users\ridho\Documents\Visuino\Generated\Generated.ino: In member function 'void PinCalls::PinCallerReceive2::Notify(void*)':
Generated:222:19: error: 'Converter1' is not a member of 'TypeConverters'
TypeConverters::Converter1.Convert( _Data, PinCallerConverterReceive2 );
C:\Users\ridho\Documents\Visuino\Generated\Generated.ino: In function 'void PinCalls::PinCallerConverterReceive2(void*)':
Generated:227:28: error: 'Timer1' is not a member of 'Declarations::Instances'
Declarations::Instances::Timer1.StartInputPin_o_Receive( _Data );
C:\Users\ridho\Documents\Visuino\Generated\Generated.ino: In function 'void setup()':
Generated:241:33: error: 'ArduinoDigitalChannel_5' is not a member of 'BoardDeclarations::Instances'
BoardDeclarations::Instances::ArduinoDigitalChannel_5.SystemInit();
Generated:242:33: error: 'ArduinoAnalogInputChannel_0' is not a member of 'BoardDeclarations::Instances'
BoardDeclarations::Instances::ArduinoAnalogInputChannel_0.SystemInit();
Generated:243:33: error: 'ArduinoDigitalChannel_5' is not a member of 'BoardDeclarations::Instances'
BoardDeclarations::Instances::ArduinoDigitalChannel_5.SystemStart();
Generated:244:33: error: 'ArduinoAnalogInputChannel_0' is not a member of 'BoardDeclarations::Instances'
BoardDeclarations::Instances::ArduinoAnalogInputChannel_0.SystemStart();
Generated:245:28: error: 'Timer1' is not a member of 'Declarations::Instances'
Declarations::Instances::Timer1.SystemStart();
Generated:246:28: error: 'SpeedToClock1' is not a member of 'Declarations::Instances'
Declarations::Instances::SpeedToClock1.SystemStart();
C:\Users\ridho\Documents\Visuino\Generated\Generated.ino: In function 'void loop()':
Generated:252:33: error: 'ArduinoDigitalChannel_5' is not a member of 'BoardDeclarations::Instances'
BoardDeclarations::Instances::ArduinoDigitalChannel_5.SystemLoopBegin();
Generated:253:33: error: 'ArduinoAnalogInputChannel_0' is not a member of 'BoardDeclarations::Instances'
BoardDeclarations::Instances::ArduinoAnalogInputChannel_0.SystemLoopBegin();
Generated:254:28: error: 'Timer1' is not a member of 'Declarations::Instances'
Declarations::Instances::Timer1.SystemLoopBegin();
Generated:255:28: error: 'SpeedToClock1' is not a member of 'Declarations::Instances'
Declarations::Instances::SpeedToClock1.SystemLoopBegin();
Using library Mitov in folder: C:\Users\ridho\Documents\Arduino\libraries\Mitov (legacy)
exit status 1
