Hey, I created a 16 channel lighting controller for my Christmas lights this year. Easy project and things are working so far, but I'm not familiar with code and could use some help. When the Arduino does not detect the Vixen software the lights go into a Random Mode, and I want them to be steady on. Which line of code do I need to change? Here is the code I am using.....
There are a few #define lines on top to set the serial speed, the number of channels to use, and whether the relays activate with a high or low signal:
-Set the number of channels that you will use with the line #define CHANNEL_COUNT 16
-Set the mode line to "#define MODE INVERTED" or "#define MODE NOT_INVERTED" as needed. If your channels are doing the opposite than expected, change it to the other mode.
-Set the com port speed (currently to 57600) #define VIXEN_COM_SPEED 57600
-Set the timeout (in milliseconds) for Random mode with #define TIME_OUT 1000
It only uses 1 library for the watchdog timer, included in the arduino IDE, so just copy the code to a new sketch, change the channels, speed, and relay mode settings, and upload to your Arduino.
NOTE: If you use an Arduino Uno, remove all the #define lines for channels after 18, and remove those channels from the line with "int channels[] = {CH01..." as all those pins are only valid in the Arduino Mega and would give a compilation error in an Arduino Uno.
It works in the following way:
-Vixen needs to be setup to use a header of: ~!
-Sets all the channels to off in startup.
-Wait for up to 2 seconds (can be changed for longer) and if there is no valid input, it goes into random mode, blinking some lights on and off every second.
-If it detects valid input (with ~! header), it writes to the relays, as long as Vixen is working.
-If Vixen goes off for more than 2 seconds, back to random mode.
Here is the code:
// This code was written by Click that moment.
// To adapt the code to your case, just change this top section, with the #define lines.
// Includes the watchdog timer library
#include <avr/wdt.h>
// This sets how many channels will vixen be sending. Can be set to any number from 1 to 48 for Arduino Mega, and 1 to 18 for Arduino Uno.
// speed for the com port for talking with vixen. From 9600 to 115200. Use the same speed as set in Vixen.
// Timeout waiting for serial input before going to random mode (in milliseconds).
// If the relays turn On and Off opposite to Vixen sequence, change "#define MODE NOT_INVERTED" for "#define MODE INVERTED"
#define NOT_INVERTED 0
#define INVERTED 1
// which pins control which channels
// You can change these assignment to use different pins, but be very careful to not repeat the same pin number for 2 channels.
// DO NOT use pings 0 and 1, as those are for the serial port to talk to the computer.
#define CH01 2
#define CH02 3
#define CH03 4
#define CH04 5
#define CH05 6
#define CH06 7
#define CH07 8
#define CH08 9
#define CH09 10
#define CH10 11
#define CH11 12
#define CH12 13
#define CH13 A0
#define CH14 A1
#define CH15 A2
#define CH16 A3
#define CH17 A4
#define CH18 A5
// Up to here for Arduino uno.
#define CH19 A6
#define CH20 A7
#define CH21 A8
#define CH22 A9
#define CH23 A10
#define CH24 A11
#define CH25 A12
#define CH26 A13
#define CH27 A14
#define CH28 A15
#define CH29 22
#define CH30 23
#define CH31 24
#define CH32 25
#define CH33 26
#define CH34 27
#define CH35 28
#define CH36 29
#define CH37 30
#define CH38 31
#define CH39 32
#define CH40 33
#define CH41 34
#define CH42 35
#define CH43 36
#define CH44 37
#define CH45 38
#define CH46 39
#define CH47 40
#define CH48 41
int channels[] = {CH01,CH02,CH03,CH04,CH05 ,CH06,CH07,CH08,CH09,
CH10,CH11,CH12,CH13,CH14,CH15,CH16,CH17,CH18,CH19, CH20,CH21,CH22,
CH23,CH24,CH25,CH26,CH27,CH28,CH29,CH30,CH31,CH32, CH33,CH34,CH35,
CH36,CH37,CH38,CH39,CH40,CH41,CH42,CH43,CH44,CH45, CH46,CH47,CH48};
int incomingByte[CHANNEL_COUNT];
int i = 0; // Loop counter
volatile unsigned long timer_a = 0; // new line
//setup the pins/ inputs & outputs
void setup(){
// enable the watchdog timer with a time of 1 second. If the board freezes, it will reset itself after 1 second.
wdt_enable(WDTO_1S);
// specifically for the UNO
sei();
// initalize PWM Channels / Pins
for (i=0; i < CHANNEL_COUNT; i++){
pinMode(channels[i], OUTPUT);
// set all the realys to off to start with
if (MODE == NOT_INVERTED) {
digitalWrite(channels[i], LOW);
else {
digitalWrite(channels[i], HIGH);
testSequence();
// set up Serial according to the speed defined above.
Serial.begin(VIXEN_COM_SPEED);
if (Serial.available() >= (CHANNEL_COUNT+2)) {
wdt_reset(); // resets the watchdog
timer_a = millis (); // new line
int uno = Serial.read();
if (uno == 126){
int dos = Serial.read();
if (dos == 33){
for (i=0; i < CHANNEL_COUNT; i++) {
// read each byte
incomingByte[i] = Serial.read();
int value = incomingByte[i];
if (value <= 127) {
else {
else {
if (value < 127) {
else {
// Random mode code. Random mode starts if no serial input has been received in TIME_OUT millisenconds
else {
unsigned long diff = millis() - timer_a;
if (diff >= TIME_OUT) {
int random_a = 0;
random_a = random(0, 2);
if (random_a == 0) {
else {
void testSequence(){
delay (500);
else {
delay (500);
