VL53L0X sensor with esp8266 unable sending message to telegram
Following is my coding, i am changing vl6180X to VL53L0X sensor. After that i changing the libraries the message can measure the distance but it only println out the notification line did not approve to the sending message part.
#include <UniversalTelegramBot.h>
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <Wire.h>
#include "Adafruit_VL53L0X.h"
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
#define SCLPIN  D1     //output
#define SDAPIN  D2   //input to recieve and an output to transmit
long Bot_lasttime;
int bulk_messages_mtbs = 30000; // testing to delay 6sec to detecting another distance and which message been sent .
int Dist = 0;   //Set  Range to integer
//------- WiFi Settings -------
char ssid[] = "";       // your network SSID (name)
char password[] = "";  // your network key
// ------- Telegram config ----------
#define BOT_TOKEN ""  // your Bot Token (Get from Botfather)
#define CHAT_ID "" // Chat ID of where you want the message to go (You can use MyIdBot to get the chat ID)
// SSL client needed for both libraries
WiFiClientSecure client;
UniversalTelegramBot bot(BOT_TOKEN, client);
String ipAddress = "";
volatile bool telegramButton1PressedFlag = false;
volatile bool telegramButton2PressedFlag = false;
Wire.begin();
pinMode(SDAPIN, INPUT); // Sets the SDAPin as an INput
pinMode(SCLPIN, OUTPUT);// Sets the SCLPin as an OUTput
// Set WiFi to station mode and disconnect from an AP if it was Previously
// connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
// Attempt to connect to Wifi network:
Serial.print("Connecting Wifi: ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
IPAddress ip = WiFi.localIP();
Serial.println(ip);
// wait until serial port opens for native USB devices
while (! Serial) {
    delay(1);
Serial.println("Adafruit VL53L0X test");
if (!lox.begin()) {
    Serial.println(F("Failed to boot VL53L0X"));
    while(1);
// power
Serial.println(F("VL53L0X API Simple Ranging example\n\n"));
 ipAddress = ip.toString();
void telegramButton1Pressed() {                                 //FULL
  Serial.println("Telegram Button-1 Pressed");
  VL53L0X_RangingMeasurementData_t measure;
  Serial.print("Reading a measurement... ");
  lox.rangingTest(&measure, false); // pass in 'true' to get debug data printout!
  if(measure.RangeMilliMeter <50){
     Serial.print("Distance (mm): "); Serial.println(measure.RangeMilliMeter);
     telegramButton1PressedFlag = true;
  return;
void sendTelegramMessage() {
  String message = "Dustbin was full @ 27 Mandai Estate #04-01!";
  if(bot.sendMessage(CHAT_ID, message, "Markdown")){
    Serial.println("TELEGRAM Message 1 Successfully sent");
void telegramButton2Pressed() {                                 //Empited
  Serial.println("Telegram Button-2 Pressed");
  if(measure.RangeMilliMeter >70){
     telegramButton2PressedFlag = true;
  return;
void sendTelegramMessage2() {
  String message2 = "Dustbin was empited @ 27 Mandai Estate #04-01!";
  if(bot.sendMessage(CHAT_ID, message2, "Markdown")){
    Serial.println("TELEGRAM Message 2 Successfully sent");
  static bool Distance_reach = false;
  if(measure.RangeMilliMeter <50) {
       Serial.println("Checking Full Condition again");
       delay(10000);       //delay 10 second for checking propose.
       if(!Distance_reach)
                Serial.println("sent notifcation1 to Telegram");
                sendTelegramMessage();
                delay(bulk_messages_mtbs);
                Bot_lasttime = 0;
                Distance_reach = true;
  else if (measure.RangeMilliMeter >70) {                              //EMPTY
                 Serial.println("Checking Empited Condition again");
                 delay(30000);     //delay 30 second for checking propose.
          if(Distance_reach) {
                       Serial.println("sent notifcation2 to Telegram");
                       sendTelegramMessage2();
                       Bot_lasttime = 0;
