I'm wondering if anyone has been able to put the VL53L0X in high accuracy mode and report back data? After looking through the data sheet I've come up with these lines of code, trying to tweak the example code a bit. For some reason the ToF sensor won't report any data when I add the timing budget line.Any idea why? By the way I am using the adafruit library.
#include "Adafruit_VL53L0X.h"
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
VL53L0X_Dev_t MyDevice;
VL53L0X_Dev_t *pMyDevice = &MyDevice;
// wait until serial port opens for native USB devices
while (! Serial) {
delay(1);
Serial.println("Adafruit VL53L0X test");
if (!lox.begin()) {
Serial.println(F("Failed to boot VL53L0X"));
while(1);
// power
Serial.println(F("VL53L0X API Simple Ranging example\n\n"));
VL53L0X_SetMeasurementTimingBudgetMicroSeconds(pMyDevice, 200000);
Serial.println(("Here"));
VL53L0X_RangingMeasurementData_t measure;
Serial.print("Reading a measurement... ");
lox.rangingTest(&measure, false); // pass in 'true' to get debug data printout!
if (measure.RangeStatus != 4) { // phase failures have incorrect data
Serial.print("Distance (mm): "); Serial.println(measure.RangeMilliMeter);
Serial.println(" out of range ");
delay(100);
