VL53LOX details
Looked in several data sheets and code examples for breakdown explanation of different forms of coding used with Arduino and the VL53lox sensor without any luck.
Anyone know of antwhere I could find the details?
Thanks
Example shown below
int o,r = sensor.readRangeSingleMillimeters();
  test.in( r );
  o = test.out();
  Serial.print(o);
First hit on Google is this Adafruit example code. Does it work when you test it?
EDIT:
Second hit is this linking to the Arduino site.
Riva:
EDIT:
I want an explanation of what all the code for the VL53LOX means.
Above was one example of many.
Whether it works or not is irrelivent when I attempt to write my own and not know what it means or how to approach any changes which may be necessary.
Didn't see any reference to what I need in either link you supplied.
VL53L0X API
Thankyou.
