VL53LOX distance Sensor calibration
Hello everyone,
I used two VL53LOX distance sensor at a time both the sensor give distance but it not give accurate distance.
For this i used below example code which is given by adafruit.
#include "Adafruit_VL53L0X.h"
// address we will assign if dual sensor is present
#define LOX1_ADDRESS 0x30
#define LOX2_ADDRESS 0x31
// set the pins to shutdown
#define SHT_LOX1 7
#define SHT_LOX2 6
// objects for the vl53l0x
Adafruit_VL53L0X lox1 = Adafruit_VL53L0X();
Adafruit_VL53L0X lox2 = Adafruit_VL53L0X();
// this holds the measurement
VL53L0X_RangingMeasurementData_t measure1;
VL53L0X_RangingMeasurementData_t measure2;
    Reset all sensors by setting all of their XSHUT pins low for delay(10), then set all XSHUT high to bring out of reset
    Keep sensor #1 awake by keeping XSHUT pin high
    Put all other sensors into shutdown by pulling XSHUT pins low
    Initialize sensor #1 with lox.begin(new_i2c_address) Pick any number but 0x29 and it must be under 0x7F. Going with 0x30 to 0x3F is probably OK.
    Keep sensor #1 awake, and now bring sensor #2 out of reset by setting its XSHUT pin high.
    Initialize sensor #2 with lox.begin(new_i2c_address) Pick any number but 0x29 and whatever you set the first sensor to
void setID() {
  // all reset
  digitalWrite(SHT_LOX1, LOW);
  digitalWrite(SHT_LOX2, LOW);
  delay(10);
  // all unreset
  digitalWrite(SHT_LOX1, HIGH);
  digitalWrite(SHT_LOX2, HIGH);
  delay(10);
  // activating LOX1 and resetting LOX2
  // initing LOX1
  if(!lox1.begin(LOX1_ADDRESS)) {
    Serial.println(F("Failed to boot first VL53L0X"));
    while(1);
  delay(10);
  // activating LOX2
  delay(10);
  //initing LOX2
  if(!lox2.begin(LOX2_ADDRESS)) {
    Serial.println(F("Failed to boot second VL53L0X"));
    while(1);
void read_dual_sensors() {
  lox1.rangingTest(&measure1, false); // pass in 'true' to get debug data printout!
  lox2.rangingTest(&measure2, false); // pass in 'true' to get debug data printout!
  // print sensor one reading
  Serial.print(F("1: "));
  if(measure1.RangeStatus != 4) {     // if not out of range
    Serial.print(measure1.RangeMilliMeter);
    Serial.print(F("Out of range"));
  Serial.print(F(" "));
  // print sensor two reading
  Serial.print(F("2: "));
  if(measure2.RangeStatus != 4) {
    Serial.print(measure2.RangeMilliMeter);
  // wait until serial port opens for native USB devices
  while (! Serial) { delay(1); }
  pinMode(SHT_LOX1, OUTPUT);
  pinMode(SHT_LOX2, OUTPUT);
  Serial.println(F("Shutdown pins inited..."));
  Serial.println(F("Both in reset mode...(pins are low)"));
  Serial.println(F("Starting..."));
  setID();
  read_dual_sensors();
  delay(100);
In the serial monitor i get values after 30 and 40 mm like i cover distance sensor from my hand at origin point i get around 30 mm.As an example , i put object 30 mm far from sensor i got distance about 60 mm. So i did not get accurate value from sensor.
Anyone has solution for this ??
Also i found that the values of my distance sensor is flctuating continuesly it is not constant it shows variation about 4 mm even my object is steady So how to solve that?
Take an arbitrary number of samples and average them?
Pololu has a good discussion of how to use this sensor.
in ArdaFruitVL53LOx library.
change the fie C:\Users\Administrator\Documents\Arduino\libraries\Adafruit_VL53L0X_offset_CAL\src\Adafruit_VL53L0X.cpp with the code
 * @file Adafruit_VL53L0X.cpp
 * @mainpage Adafruit VL53L0X time-of-flight sensor
 * @section intro_sec Introduction
 * This is the documentation for Adafruit's VL53L0X driver for the
 * Arduino platform.  It is designed specifically to work with the
 * Adafruit VL53L0X breakout: https://www.adafruit.com/product/3317
 * These sensors use I2C to communicate, 2 pins (SCL+SDA) are required
 * to interface with the breakout.
 * Adafruit invests time and resources providing this open source code,
 * please support Adafruit and open-source hardware by purchasing
 * products from Adafruit!
 * @section dependencies Dependencies
 * @section author Author
 * Written by Limor Fried/Ladyada for Adafruit Industries.
 * Updated by Andrew DeVries for Digital Example to include methods needed for
 * Interrupt triggering
 * @section license License
 * BSD license, all text here must be included in any redistribution.
#include "vl53l0x_api_core.h"
#define VERSION_REQUIRED_MAJOR 1 ///< Required sensor major version
#define VERSION_REQUIRED_MINOR 0 ///< Required sensor minor version
#define VERSION_REQUIRED_BUILD 1 ///< Required sensor build
#define STR_HELPER(x) #x     ///< a string helper
#define STR(x) STR_HELPER(x) ///< string helper wrapper
//offset calibration as 100mm distance from the white reflecting board
#define OFFSET_CAL
    @brief  Setups the I2C interface and hardware
    @param  i2c_addr Optional I2C address the sensor can be found on. Default is
   0x29
    @param debug Optional debug flag. If true, debug information will print out
   via Serial.print during setup. Defaults to false.
    @param  i2c Optional I2C bus the sensor is located on. Default is Wire
    @param vl_config Sensor configuration
    @returns True if device is set up, false on any failure
boolean Adafruit_VL53L0X::begin(uint8_t i2c_addr, boolean debug, TwoWire *i2c,
                                VL53L0X_Sense_config_t vl_config) {
  uint32_t refSpadCount;
  uint8_t isApertureSpads;
  uint8_t VhvSettings;
  uint8_t PhaseCal;
  int32_t OffsetMicroMeter;
  // Initialize Comms
  pMyDevice->I2cDevAddr = VL53L0X_I2C_ADDR; // default
  pMyDevice->comms_type = 1;
  pMyDevice->comms_speed_khz = 400;
  pMyDevice->i2c = i2c;
  pMyDevice->i2c->begin(); // VL53L0X_i2c_init();
  // unclear if this is even needed:
  if (VL53L0X_IMPLEMENTATION_VER_MAJOR != VERSION_REQUIRED_MAJOR ||
      VL53L0X_IMPLEMENTATION_VER_MINOR != VERSION_REQUIRED_MINOR ||
      VL53L0X_IMPLEMENTATION_VER_SUB != VERSION_REQUIRED_BUILD) {
    if (debug) {
      Serial.println(F(
          "Found " STR(VL53L0X_IMPLEMENTATION_VER_MAJOR) "." STR(VL53L0X_IMPLEMENTATION_VER_MINOR) "." STR(
              VL53L0X_IMPLEMENTATION_VER_SUB) " rev " STR(VL53L0X_IMPLEMENTATION_VER_REVISION)));
      Serial.println(F("Requires " STR(VERSION_REQUIRED_MAJOR) "." STR(
          VERSION_REQUIRED_MINOR) "." STR(VERSION_REQUIRED_BUILD)));
    Status = VL53L0X_ERROR_NOT_SUPPORTED;
    return false;
  Status = VL53L0X_DataInit(&MyDevice); // Data initialization
  if (!setAddress(i2c_addr)) {
    return false;
  Status = VL53L0X_GetDeviceInfo(&MyDevice, &DeviceInfo);
  if (Status == VL53L0X_ERROR_NONE) {
    if (debug) {
      Serial.println(F("VL53L0X Info:"));
      Serial.print(F("Device Name: "));
      Serial.print(DeviceInfo.Name);
      Serial.print(F(", Type: "));
      Serial.print(DeviceInfo.Type);
      Serial.print(F(", ID: "));
      Serial.println(DeviceInfo.ProductId);
      Serial.print(F("Rev Major: "));
      Serial.print(DeviceInfo.ProductRevisionMajor);
      Serial.print(F(", Minor: "));
      Serial.println(DeviceInfo.ProductRevisionMinor);
    if ((DeviceInfo.ProductRevisionMajor != 1) ||
        (DeviceInfo.ProductRevisionMinor != 1)) {
      if (debug) {
        Serial.print(F("Error expected cut 1.1 but found "));
        Serial.print(',');
    if (debug) {
      Serial.println(F("VL53L0X: StaticInit"));
    Status = VL53L0X_StaticInit(pMyDevice); // Device Initialization
    if (debug) {
      Serial.println(F("VL53L0X: PerformRefSpadManagement"));
    Status = VL53L0X_PerformRefSpadManagement(
        pMyDevice, &refSpadCount, &isApertureSpads); // Device Initialization
    if (debug) {
      Serial.print(F("refSpadCount = "));
      Serial.print(refSpadCount);
      Serial.print(F(", isApertureSpads = "));
      Serial.println(isApertureSpads);
    if (debug) {
      Serial.println(F("VL53L0X: PerformRefCalibration"));
    Status = VL53L0X_PerformRefCalibration(pMyDevice, &VhvSettings,
                                           &PhaseCal); // Device Initialization
  //add offeset calibration function as 100mm distance in dark mode
  #ifdef OFFSET_CAL
    if (debug) {
      Serial.println(F("VL53L0X: PerformOffsetCalibration"));
    Status = VL53L0X_PerformOffsetCalibration(pMyDevice, 100<<16,
                                           &OffsetMicroMeter); // Device Initialization
    if(debug){
        Serial.println(OffsetMicroMeter);
  #endif
    // no need to do this when we use VL53L0X_PerformSingleRangingMeasurement
    if (debug) {
      Serial.println(F("VL53L0X: SetDeviceMode"));
    Status = VL53L0X_SetDeviceMode(
        pMyDevice,
        VL53L0X_DEVICEMODE_SINGLE_RANGING); // Setup in single ranging mode
  // call off to the config function to do the last part of configuration.
    configSensor(vl_config);
    return true;
    if (debug) {
      Serial.print(F("VL53L0X Error: "));
      Serial.println(Status);
    return false;
    @brief  Change the I2C address of the sensor
    @param  newAddr the new address to set the sensor to
    @returns True if address was set successfully, False otherwise
boolean Adafruit_VL53L0X::setAddress(uint8_t newAddr) {
  newAddr &= 0x7F;
  Status = VL53L0X_SetDeviceAddress(pMyDevice, newAddr * 2); // 7->8 bit
  delay(10);
    pMyDevice->I2cDevAddr = newAddr; // 7 bit addr
    return true;
  return false;
    @brief  Configure the sensor for one of the ways the example ST
    sketches configure the sensors for different usages.
    @param  vl_config Which configureation you are trying to configure for
    It should be one of the following
        VL53L0X_SENSE_DEFAULT
        VL53L0X_SENSE_LONG_RANGE
        VL53L0X_SENSE_HIGH_SPEED,
        VL53L0X_SENSE_HIGH_ACCURACY
boolean Adafruit_VL53L0X::configSensor(VL53L0X_Sense_config_t vl_config) {
  // All of them appear to configure a few things
  // Serial.print(F("VL53L0X: configSensor "));
  // Serial.println((int)vl_config, DEC);
  // Enable/Disable Sigma and Signal check
  Status = VL53L0X_SetLimitCheckEnable(
      pMyDevice, VL53L0X_CHECKENABLE_SIGMA_FINAL_RANGE, 1);
        pMyDevice, VL53L0X_CHECKENABLE_SIGNAL_RATE_FINAL_RANGE, 1);
  if (Status != VL53L0X_ERROR_NONE)
    return false;
  switch (vl_config) {
  case VL53L0X_SENSE_DEFAULT:
    // Taken directly from SDK vl5310x_SingleRanging_example.c
    // Maybe should convert to helper functions but...
    // Serial.println("  VL53L0X_SENSE_DEFAULT");
          pMyDevice, VL53L0X_CHECKENABLE_RANGE_IGNORE_THRESHOLD, 1);
      Status = VL53L0X_SetLimitCheckValue(
          (FixPoint1616_t)(1.5 * 0.023 * 65536));
  case VL53L0X_SENSE_LONG_RANGE:
    Serial.println("  VL53L0X_SENSE_LONG_RANGE");
        (FixPoint1616_t)(0.1 * 65536));
      Status = VL53L0X_SetLimitCheckValue(pMyDevice,
                                          (FixPoint1616_t)(60 * 65536));
      Status = VL53L0X_SetMeasurementTimingBudgetMicroSeconds(pMyDevice, 33000);
      Status = VL53L0X_SetVcselPulsePeriod(pMyDevice,
                                           VL53L0X_VCSEL_PERIOD_PRE_RANGE, 18);
          pMyDevice, VL53L0X_VCSEL_PERIOD_FINAL_RANGE, 14);
  case VL53L0X_SENSE_HIGH_SPEED:
    // Serial.println("  VL53L0X_SENSE_HIGH_SPEED");
        (FixPoint1616_t)(0.25 * 65536));
                                          (FixPoint1616_t)(32 * 65536));
      Status = VL53L0X_SetMeasurementTimingBudgetMicroSeconds(pMyDevice, 30000);
  case VL53L0X_SENSE_HIGH_ACCURACY:
    // increase timing budget to 200 ms
      setLimitCheckValue(VL53L0X_CHECKENABLE_SIGNAL_RATE_FINAL_RANGE,
      setLimitCheckValue(VL53L0X_CHECKENABLE_SIGMA_FINAL_RANGE,
                         (FixPoint1616_t)(18 * 65536));
      setMeasurementTimingBudgetMicroSeconds(200000);
    // Not sure about ignore threshold, try turnning it off...
          pMyDevice, VL53L0X_CHECKENABLE_RANGE_IGNORE_THRESHOLD, 0);
  return (Status == VL53L0X_ERROR_NONE);
    @brief  get a ranging measurement from the device
    @param  RangingMeasurementData the pointer to the struct the data will be
   stored in
    @param debug Optional debug flag. If true debug information will print via
   Serial.print during execution. Defaults to false.
VL53L0X_Error Adafruit_VL53L0X::getSingleRangingMeasurement(
    VL53L0X_RangingMeasurementData_t *RangingMeasurementData, boolean debug) {
  VL53L0X_Error Status = VL53L0X_ERROR_NONE;
  FixPoint1616_t LimitCheckCurrent;
   *  Step  4 : Test ranging mode
    if (debug) {
      Serial.println(F("sVL53L0X: PerformSingleRangingMeasurement"));
    Status = VL53L0X_PerformSingleRangingMeasurement(pMyDevice,
                                                     RangingMeasurementData);
    if (debug) {
      printRangeStatus(RangingMeasurementData);
    if (debug) {
      VL53L0X_GetLimitCheckCurrent(pMyDevice,
                                   &LimitCheckCurrent);
      Serial.print(F("RANGE IGNORE THRESHOLD: "));
      Serial.println((float)LimitCheckCurrent / 65536.0);
      Serial.print(F("Measured distance: "));
      Serial.println(RangingMeasurementData->RangeMilliMeter);
  return Status;
    @brief Start the ranging measurement from the device
    @returns status code
VL53L0X_Error Adafruit_VL53L0X::startMeasurement(boolean debug) {
    if (debug) {
      Serial.println(F("sVL53L0X: StartMeasurement"));
    Status = VL53L0X_StartMeasurement(pMyDevice);
  return Status;
    @brief Stop ranging measurement from the device
VL53L0X_Error Adafruit_VL53L0X::stopMeasurement(boolean debug) {
    if (debug) {
      Serial.println(F("sVL53L0X: StopMeasurement"));
    Status = VL53L0X_StopMeasurement(pMyDevice);
  return Status;
    @param LimitCheckId Limit Check ID (0<= LimitCheckId <
   VL53L0X_GetNumberOfLimitCheck() ).
    @param pLimitCheckCurrent Pointer to current Value for a given LimitCheckId.
VL53L0X_Error Adafruit_VL53L0X::getLimitCheckCurrent(
    uint8_t LimitCheckId, FixPoint1616_t *pLimitCheckCurrent, boolean debug) {
  uint16_t intLimitCheckId = LimitCheckId;
    if (debug) {
      Serial.println(F("sVL53L0X: getLimitCheckCurrent"));
    Status = VL53L0X_GetLimitCheckCurrent(pMyDevice, intLimitCheckId,
                                          pLimitCheckCurrent);
  return Status;
    @brief  Set a new device mode
    @param   DeviceMode            New device mode to apply
                                   Valid values are:
                                   VL53L0X_DEVICEMODE_CONTINUOUS_RANGING
                                   VL53L0X_DEVICEMODE_CONTINUOUS_TIMED_RANGING
                                   VL53L0X_DEVICEMODE_SINGLE_HISTOGRAM
                                   VL53L0X_HISTOGRAMMODE_REFERENCE_ONLY
                                   VL53L0X_HISTOGRAMMODE_RETURN_ONLY
                                   VL53L0X_HISTOGRAMMODE_BOTH
VL53L0X_Error Adafruit_VL53L0X::setDeviceMode(VL53L0X_DeviceModes DeviceMode,
                                              boolean debug) {
    if (debug) {
      Serial.println(F("sVL53L0X: setDeviceMode"));
    Status = VL53L0X_SetDeviceMode(pMyDevice, DeviceMode);
  return Status;
    @brief Set low and high Interrupt thresholds
    @param ThresholdLow     Low threshold (mm, lux ..., depending on the mode)
    @param ThresholdHigh    High threshold (mm, lux ..., depending on the mode)
VL53L0X_Error Adafruit_VL53L0X::setInterruptThresholds(
    FixPoint1616_t ThresholdLow, FixPoint1616_t ThresholdHigh, boolean debug) {
    if (debug) {
      Serial.println(F("sVL53L0X: setInterruptThresholds"));
    // ST API Comments "no dependency on DeviceMode for Ewok " so device mode
    // not used but API requires something so pass in
    // VL53L0X_DEVICEMODE_CONTINUOUS_RANGING even though not used
    Status = VL53L0X_SetInterruptThresholds(
        pMyDevice, VL53L0X_DEVICEMODE_CONTINUOUS_RANGING, ThresholdLow,
        ThresholdHigh);
  return Status;
    @brief Get high and low Interrupt thresholds
    @param pThresholdLow    Low threshold (mm, lux ..., depending on the mode)
    @param pThresholdHigh   High threshold (mm, lux ..., depending on the mode)
VL53L0X_Error
Adafruit_VL53L0X::getInterruptThresholds(FixPoint1616_t *pThresholdLow,
                                         FixPoint1616_t *pThresholdHigh,
                                         boolean debug) {
    if (debug) {
      Serial.println(F("sVL53L0X: getInterruptThresholds"));
    Status = VL53L0X_GetInterruptThresholds(
        pMyDevice, VL53L0X_DEVICEMODE_CONTINUOUS_RANGING, pThresholdLow,
        pThresholdHigh);
  return Status;
    @brief Get current new device mode
    @param pDeviceMode Pointer to current apply mode value
VL53L0X_Error Adafruit_VL53L0X::getDeviceMode(VL53L0X_DeviceModes *pDeviceMode,
                                              boolean debug) {
    if (debug) {
      Serial.println(F("sVL53L0X: getDeviceMode"));
    Status = VL53L0X_GetDeviceMode(pMyDevice, pDeviceMode);
  return Status;
    @brief Clear system interrupt condition
VL53L0X_Error Adafruit_VL53L0X::clearInterruptMask(boolean debug) {
    if (debug) {
      Serial.println(F("sVL53L0X: clearInterruptMask"));
    Status = VL53L0X_ClearInterruptMask(pMyDevice, 0);
  return Status;
    @brief Set the configuration of GPIO pin 0
    @param DeviceMode Device Mode associated to the Gpio.
    @param Functionality Select Pin functionality.
    @param Polarity Set interrupt polarity. Active high or active low.
VL53L0X_Error Adafruit_VL53L0X::setGpioConfig(
    VL53L0X_DeviceModes DeviceMode, VL53L0X_GpioFunctionality Functionality,
    VL53L0X_InterruptPolarity Polarity, boolean debug) {
    if (debug) {
      Serial.println(F("sVL53L0X: setGpioConfig"));
    //  Pin is always 0, Devicemode is ignored if not
    //  VL53L0X_DEVICEMODE_GPIO_DRIVE or VL53L0X_DEVICEMODE_GPIO_OSC
    Status = VL53L0X_SetGpioConfig(pMyDevice, 0, DeviceMode, Functionality,
                                   Polarity);
  return Status;
    @brief Get current configuration for GPIO pin 0
    @param   pDeviceMode Pointer to Device Mode associated to the Gpio.
    @param   pFunctionality Pointer to Pin functionality.
    @param   pPolarity Pointer to interrupt polarity. Active high or active low.
VL53L0X_Error Adafruit_VL53L0X::getGpioConfig(
    VL53L0X_DeviceModes *pDeviceMode, VL53L0X_GpioFunctionality *pFunctionality,
    VL53L0X_InterruptPolarity *pPolarity, boolean debug) {
    if (debug) {
      Serial.println(F("sVL53L0X: getGpioConfig"));
    Status = VL53L0X_GetGpioConfig(pMyDevice, 0, pDeviceMode, pFunctionality,
                                   pPolarity);
  return Status;
   stored in
    @returns VL53L0X_ERROR_NONE or Error if one occured
VL53L0X_Error Adafruit_VL53L0X::getRangingMeasurement(
    if (debug) {
      Serial.println(F("sVL53L0X: getRangingMeasurement"));
    Status =
        VL53L0X_GetRangingMeasurementData(pMyDevice, RangingMeasurementData);
    if (debug) {
    if (debug) {
  return Status;
    @brief  print a ranging measurement out via Serial.print in a human-readable
   format
    @param pRangingMeasurementData a pointer to the ranging measurement data
void Adafruit_VL53L0X::printRangeStatus(
    VL53L0X_RangingMeasurementData_t *pRangingMeasurementData) {
  char buf[VL53L0X_MAX_STRING_LENGTH];
  uint8_t RangeStatus;
   * New Range Status: data is valid when pRangingMeasurementData->RangeStatus =
   * 0
  RangeStatus = pRangingMeasurementData->RangeStatus;
  VL53L0X_GetRangeStatusString(RangeStatus, buf);
  Serial.print(F("Range Status: "));
  Serial.print(RangeStatus);
  Serial.print(F(" : "));
  Serial.println(buf);
    @brief  Single shot ranging. Be sure to check the return of readRangeStatus
    to before using the return value!
    @return Distance in millimeters if valid
uint16_t Adafruit_VL53L0X::readRange(void) {
  VL53L0X_RangingMeasurementData_t measure; // keep our own private copy
  Status = getSingleRangingMeasurement(&measure, false);
  _rangeStatus = measure.RangeStatus;
    return measure.RangeMilliMeter;
  // Other status return something totally out of bounds...
  return 0xffff;
    @brief  Request ranging success/error message (retrieve after ranging)
    @returns One of possible VL6180X_ERROR_* values
uint8_t Adafruit_VL53L0X::readRangeStatus(void) { return _rangeStatus; }
    @brief  Start a range operation
    @return true if range operation successfully started.
boolean Adafruit_VL53L0X::startRange(void) {
  /* This function will do a complete single ranging
   * Here we fix the mode! */
  // first lets set the device in SINGLE_Ranging mode
  Status = VL53L0X_SetDeviceMode(pMyDevice, VL53L0X_DEVICEMODE_SINGLE_RANGING);
    // Lets start up the measurement
    @brief  Checks to see if a range operation has completed
    @return true if range operation completed or an error has happened
boolean Adafruit_VL53L0X::isRangeComplete(void) {
  uint8_t NewDataReady = 0;
  Status = VL53L0X_GetMeasurementDataReady(pMyDevice, &NewDataReady);
  return ((Status != VL53L0X_ERROR_NONE) || (NewDataReady == 1));
    @brief  Wait until Range operation has completed.
    @return true if range operation completed, false if error.
boolean Adafruit_VL53L0X::waitRangeComplete(void) {
  Status = VL53L0X_measurement_poll_for_completion(pMyDevice);
    @brief  Return the range in mm for the last operation.
    @return Range in mm.
uint16_t Adafruit_VL53L0X::readRangeResult(void) {
  Status = VL53L0X_GetRangingMeasurementData(pMyDevice, &measure);
  if ((Status == VL53L0X_ERROR_NONE) && (_rangeStatus != 4))
  return 0xffff; // some out of range value
    @brief  Start a continuous range operation
    @param period_ms inter measurement period in milliseconds
    @return True if successful, false otherwise
boolean Adafruit_VL53L0X::startRangeContinuous(uint16_t period_ms) {
                                 VL53L0X_DEVICEMODE_CONTINUOUS_TIMED_RANGING);
    Status =
        VL53L0X_SetInterMeasurementPeriodMilliSeconds(pMyDevice, period_ms);
    @brief  Stop a continuous ranging operation
void Adafruit_VL53L0X::stopRangeContinuous(void) {
  // lets wait until that completes.
  uint32_t StopCompleted = 0;
  uint32_t LoopNb;
  // Wait until it finished
  // use timeout to avoid deadlock
    LoopNb = 0;
    do {
      Status = VL53L0X_GetStopCompletedStatus(pMyDevice, &StopCompleted);
      if ((StopCompleted == 0x00) || Status != VL53L0X_ERROR_NONE) {
      LoopNb = LoopNb + 1;
      VL53L0X_PollingDelay(pMyDevice);
    } while (LoopNb < VL53L0X_DEFAULT_MAX_LOOP);
    if (LoopNb >= VL53L0X_DEFAULT_MAX_LOOP) {
      Status = VL53L0X_ERROR_TIME_OUT;
        pMyDevice, VL53L0X_REG_SYSTEM_INTERRUPT_GPIO_NEW_SAMPLE_READY);
    @brief  Wrapper to ST library code to budget how long a measurement
    should take
    @param  budget_us the new budget
    @returns True if success
boolean
Adafruit_VL53L0X::setMeasurementTimingBudgetMicroSeconds(uint32_t budget_us) {
  Status = VL53L0X_SetMeasurementTimingBudgetMicroSeconds(pMyDevice, budget_us);
    should take
    @returns the current budget time in microseconds.
uint32_t Adafruit_VL53L0X::getMeasurementTimingBudgetMicroSeconds() {
  uint32_t budget_us;
  Status =
      VL53L0X_GetMeasurementTimingBudgetMicroSeconds(pMyDevice, &budget_us);
  return (budget_us);
    @brief Sets the VCSEL pulse period.
    @param   VcselPeriodType       VCSEL period identifier (pre-range|final).
    @param   VCSELPulsePeriod          VCSEL period value
boolean
Adafruit_VL53L0X::setVcselPulsePeriod(VL53L0X_VcselPeriod VcselPeriodType,
                                      uint8_t VCSELPulsePeriod) {
  Status =
      VL53L0X_SetVcselPulsePeriod(pMyDevice, VcselPeriodType, VCSELPulsePeriod);
    @brief Gets the VCSEL pulse period.
    @returns the current pulse peried for the given type.
uint8_t
Adafruit_VL53L0X::getVcselPulsePeriod(VL53L0X_VcselPeriod VcselPeriodType) {
  uint8_t cur_period;
  Status = VL53L0X_GetVcselPulsePeriod(pMyDevice, VcselPeriodType, &cur_period);
  return (cur_period);
    @brief  Enable/Disable a specific limit check
     (0<= LimitCheckId < VL53L0X_GetNumberOfLimitCheck() ).
    @param   LimitCheckEnable              if 1 the check limit
     corresponding to LimitCheckId is Enabled
                                           if 0 the check limit
     corresponding to LimitCheckId is disabled
    @return  true if succeeded
boolean Adafruit_VL53L0X::setLimitCheckEnable(uint16_t LimitCheckId,
                                              uint8_t LimitCheckEnable) {
  Status =
      VL53L0X_SetLimitCheckEnable(pMyDevice, LimitCheckId, LimitCheckEnable);
    @brief  Get specific limit check enable state
    @return  current state of limit enabled
uint8_t Adafruit_VL53L0X::getLimitCheckEnable(uint16_t LimitCheckId) {
  uint8_t cur_limit;
  Status = VL53L0X_GetLimitCheckEnable(pMyDevice, LimitCheckId, &cur_limit);
  return (cur_limit);
    @brief  Set a specific limit check value
    LimitCheckId
    @param  LimitCheckValue  Limit Check Value
    @return  true if succeeded.
boolean Adafruit_VL53L0X::setLimitCheckValue(uint16_t LimitCheckId,
                                             FixPoint1616_t LimitCheckValue) {
  Status = VL53L0X_SetLimitCheckValue(pMyDevice, LimitCheckId, LimitCheckValue);
    @brief  Get a specific limit check value
    @return  limit check value in FixPoint1616
FixPoint1616_t Adafruit_VL53L0X::getLimitCheckValue(uint16_t LimitCheckId) {
  FixPoint1616_t LimitCheckValue;
  Status =
      VL53L0X_GetLimitCheckValue(pMyDevice, LimitCheckId, &LimitCheckValue);
  return (LimitCheckValue);
  1. and upload this ino file
//NEED TO  DEFINE IN Adafruit_VL53L0x.cpp line 44 uncommnet #define OFFSET_CAL for offset Calibration
//And you should put the VL53L0x sensor 100 mm from a white plain object (in black enviroment is better) before uploading this ino file to arduino.
//Once you have calibration the sensor , the calibration data has been stored in the sensor's memory , you should comment line 44 in Adafruit_VL53L0x.cpp library file. So it will not calibrate on every beginnig.
*  需要在库文件中开启offset 校准, 黑暗环境,距离白色面板反射物100 mm
* Email:seighbang@126.com  中国福建省莆田第四中学 张远东
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
  while (! Serial) {
    delay(1);
  Serial.println("Adafruit VL53L0X test");
  if (!lox.begin( VL53L0X_I2C_ADDR, true)) {
    Serial.println(F("Failed to boot VL53L0X"));
    while(1);
  // power
  Serial.println(F("VL53L0X API 100 mm Calibration example\n\n"));
   //while(1);
  Serial.print("Reading a measurement... ");
  lox.rangingTest(&measure, false); // pass in 'true' to get debug data printout!
  if (measure.RangeStatus != 4) {  // phase failures have incorrect data, after calibrationg ,the distance will be 100 +/- 3 mm.
    Serial.print("Distance (mm): "); Serial.println(measure.RangeMilliMeter);
    Serial.println(" out of range ");
  1. reset the library as oringinal code .
