VL53LOX
VL53LOX will this sensor suitable use for laser engraver ? i think use that my autotune sensor. point thats same point where laser cut will it work?
Probably not but you didn't specify what you planned to use it for.
Your question is about the same as: Will an Audi TT be suitable to dig my garden? It might be used for it but it strongly depends on why you are digging your garden and in most cases it may not be the ideal tool for it.
i planned it track distance of workpiece ... then it tell the laser head it position. and stepper motor will move the laser head its like zero point sensor. keeping the burning point good height
Finnish844:
I suspect it won't work like you want. I used its little brother VL6180X at ~8-9 cm. and even at rest with a light colored target the readings varied so much I had to add some averaging code (last 5 readings) to tamp it down to a reasonable level. Could just be my setup.
YMMV
