VNH5019 Motor Driver- need help
is there H bridge in the VNH5019 Motor Driver for Arduino?
Please give a link to the data sheet of that driver.
here is the link: Pololu - VNH5019 Motor Driver Carrier
Can you please tell me if there is already H bridge cause I need to use this driver as my motor is 12V and 5 A plus the motor will have to do the forward and reverse direction?
As per web site:
“ a fully integrated H-bridge that can be used for bidirectional speed control of a single brushed DC motor”
The description says "motor direction is determined by the states of the INA and INB pins". It looks like the circuit contains two half bridges, which can be used as one H-bridge. Instead of a DIR pin apply inverse signals to INA and INB inputs.
thank you so much Mr LarryD
