Yeah I totally agree with you, I will be happy to learn the first steps of processing that would then lead me to continue by myself in my experiments (and to produce something useful for people). Can you show me a “hello world” program to start triyng?
I took a look to reference and howtos of processing but i can’t produce by myself the communication code.
here it is the code that I build on arduino:
#include <Servo.h>
// words for clarity
#define LEFT 1
#define RIGHT 2
#define LEDBICOLOR 0
#define LEDTRICOLOR 1
// parameters
#define BUMPS_TO_STOP 5 // number of obstacles to stop after
#define RANDOM_START_SECONDS 120 // mean time in seconds for random start
#define RANDOM_SOUND_SECONDS 30 // mean time in seconds for random sound
#define RANDOM_STEER_SECONDS 3 // mean time in seconds for random steering
#define BACKWARD_MSECONDS 800 // time to go back after hitting an obstacle in milliseconds
#define ROTATION_MSECONDS 500 // duration of the rotation in milliseconds
#define STEER_MSECONDS 1000 // duration of the random steering
#define SPEED 100 // speed to go
#define STEER_PERCENT 3 // percent of SPEED to set one of the servos to steer
#define SNDMEAN 150 // number of samples to mean
// digital pins
#define ledPin1 2 // LED 0 red
#define ledPin2 3 // LED 0 green
#define ledPin3 4 // LED 1 blue
#define ledPin4 5 // LED 1 green
#define ledPin5 6 // LED sensor
#define winkerPin1 7 // winker LEFT
#define winkerPin2 8 // winker RIGHT
#define servoPin1 9 // servo LEFT
#define servoPin2 10 // servo RIGHT
#define outSndPin 11 // speaker
#define ledPin6 12 // LED sensor
// analog pins
#define inSndPin 5 // sound sensor
// variables
float actualSpeed = 0.0; // percent of actual moving speed we are accelerating to
boolean moving = false; // stopped or moving
int speedLeft = 0; // speed we want on left servo
int speedRight = 0; // speed we want on right servo
Servo left;
Servo right;
int contact = 0; // did we hit? where?
int contactCount = 0; // number of hits since start
int contactStep = 0; // part of the hit manouver we are in
long contactTime = 0; // time of hitting
boolean steering = false; // steering or going straight
boolean lightCheck = true;
long lightTime = 0; // time of last light check
long startTime = 0; // time of last random start
long steerTime = 0; // time of last random steering change
long soundTime = 0; // time of last random sound
int meanSnd[SNDMEAN]; // past values of sound sensor
long meanSndCount = 0; // number of values stored
// setup
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
pinMode(ledPin4, OUTPUT);
pinMode(ledPin6, OUTPUT);
pinMode(winkerPin1, INPUT);
pinMode(winkerPin2, INPUT);
left.attach(servoPin1);
right.attach(servoPin2);
pinMode(outSndPin, OUTPUT);
randomSeed(analogRead(0));
digitalWrite(ledPin6, LOW);
// winkers
int checkContact() {
if(digitalRead(winkerPin1) == LOW)
return LEFT;
if(digitalRead(winkerPin2) == LOW)
return RIGHT;
return 0;
// servo
void servoContinue() {
if(moving) {
if((actualSpeed < 1)) {
actualSpeed += 0.009;
if(steering && (steerTime < millis() - STEER_MSECONDS)) {
speedLeft = speedRight = max(speedLeft, speedRight);
steering = false;
steerTime = millis();
servoSpeed(LEFT, round(speedLeft * actualSpeed));
servoSpeed(RIGHT, round(speedRight * actualSpeed));
void servoGo(int speed) {
if(speed < 0) {
setLed(LEDBICOLOR, 1);
else {
setLed(LEDBICOLOR, 0);
speedLeft = speedRight = speed;
servoReset();
void servoReset() {
actualSpeed = 0;
servoContinue();
void servoRotate(int side) {
setLed(LEDBICOLOR, 2);
switch(side) {
case LEFT:
speedLeft = 40;
speedRight = -40;
case RIGHT:
speedLeft = -40;
speedRight = 40;
servoReset();
void servoSpeed(int side, int speed) {
speed = speed * 90 / 100;
switch(side) {
case LEFT:
left.write(90 + speed);
case RIGHT:
right.write(90 - speed);
void servoSteer(int side) {
steering = true;
switch(side) {
case LEFT:
speedLeft = round(speedLeft * STEER_PERCENT / 100.0);
case RIGHT:
speedRight = round(speedRight * STEER_PERCENT / 100.0);
// LED
void setLed(int led, int state) {
switch(led) {
case LEDBICOLOR:
switch(state) {
case 0:
digitalWrite(ledPin1, LOW);
digitalWrite(ledPin2, LOW);
case 1:
digitalWrite(ledPin1, HIGH);
case 2:
digitalWrite(ledPin2, HIGH);
case LEDTRICOLOR:
switch(state) {
case 0:
digitalWrite(ledPin3, LOW);
digitalWrite(ledPin4, LOW);
case 1:
digitalWrite(ledPin4, HIGH);
case 2:
digitalWrite(ledPin3, HIGH);
// sound
void sndPlay(int sound) {
switch(sound) {
case 0: // sound when hitting an obstacle
sndTone(1275);
sndTone(1915);
sndTone(2000);
case 1: // sound when starting
sndTone(2100);
sndTone(1500);
sndTone(1200);
case 2: // random sound
for(int i = 0; i < 3; i++)
sndTone(random(1200, 3000));
void sndTone(int tone) {
for(long i = 0; i < 80000; i += tone * 2) {
digitalWrite(outSndPin, HIGH);
delayMicroseconds(tone);
digitalWrite(outSndPin, LOW);
// movement
void start() {
contactCount = 0;
steerTime = soundTime = millis();
moving = true;
servoGo(SPEED);
sndPlay(1);
setLed(LEDTRICOLOR, 2);
void stop() {
startTime = millis();
meanSndCount = 0;
moving = false;
servoGo(0);
setLed(LEDTRICOLOR, 0);
void hit() {
contactCount++;
servoGo(-SPEED);
sndPlay(0);
// time
long randomTime(long since, long about) {
return since - (millis() - round(about * random(5, 15) / 10));
// main loop
if(! moving) {
if(lightTime < millis() - 1000) {
lightTime = millis();
long light = 0;
for(int i = 0; i < 3; i++) {
pinMode(ledPin5, OUTPUT);
digitalWrite(ledPin5, HIGH);
pinMode(ledPin5, INPUT);
digitalWrite(ledPin5, LOW);
for(; light < 90000; light++)
if(digitalRead(ledPin5) == 0)
lightCheck = light < 10000;
Serial.println(light);
if(lightCheck)
if(lightCheck && randomTime(startTime, RANDOM_START_SECONDS * 1000L) < 0)
start();
else if(contactStep == 0) {
if(randomTime(soundTime, RANDOM_SOUND_SECONDS * 1000L) < 0) {
sndPlay(2);
// check number of hits
int remaining = BUMPS_TO_STOP - contactCount;
if(remaining == 0)
stop(); // too many hits, stop ;)
else if(remaining == 1)
setLed(LEDTRICOLOR, 1); // turn off one led, we are going to stop next hit
if(! moving) {
// sound sensor to start
int snd = analogRead(inSndPin);
meanSnd[meanSndCount++ % SNDMEAN] = snd;
if(meanSndCount >= SNDMEAN) {
float mean = 0;
for(int i = 0; i < SNDMEAN; i++)
mean += meanSnd[i];
mean /= SNDMEAN;
if(lightCheck && (snd < round(mean) - 1))
start(); // sound activated start
else {
// moving and hitting obstacles
switch(contactStep) {
case 0: // moving straight
contact = checkContact();
if(contact != 0) {
contactStep = 1;
contactTime = millis();
hit();
else {
if((! steering) && (randomTime(steerTime, RANDOM_STEER_SECONDS * 1000L) < 0))
servoSteer(random(LEFT, RIGHT + 1));
case 1: // moving backwards after hit
if(contactTime < millis() - BACKWARD_MSECONDS) {
contactStep = 2;
servoRotate(contact);
case 2: // rotating after moving backwards
if(contactTime < millis() - (BACKWARD_MSECONDS + ROTATION_MSECONDS + random(0, 200))) {
contactStep = 0;
servoGo(SPEED);
// go on accelerating
servoContinue();
In this code there is some modifications to do, because now I use ir sensor instead of winkers, and the piezo sound output would be the speech output. There I have to put serial outputs and in processing “if” for serial inputs?
