Voice control and Bluetooth
Hello everyone I'm new to this. And I can't connect the code together.
I wanted to do voice control and control via Bluetooth HC-06. The code works separately. And if you connect no. ESP8266 nodemcu microcontroller. I want to make a single code
Voice control:
byte com = 0;
  Serial.write(0xAA);
  Serial.write(0x37);
  Serial.write(0xAA);
  Serial.write(0x21);
  while (Serial.available()) {
    com = Serial.read();
    switch (com) {
      case 0x11:
        Serial.println("1");
      case 0x12:
        Serial.println("2");
      case 0x13:
        Serial.println("3");
      case 0x14:
        Serial.println("4");
      case 0x15:
        Serial.println("5");
Bluetooth
#include <SoftwareSerial.h>
SoftwareSerial BLUETOOTH(2, 0);
String readString;
  BLUETOOTH.begin(9600);
  while (BLUETOOTH.available()) {
    delay(3);
    char c = BLUETOOTH.read();
    readString += c;
  if (readString.length() > 0) {
    if (readString == "|")
      Serial.println("Send");
    readString = "";
Start from the bluetooth code.
At the end of loop You paste the content of the other loop.
Do the same for setup.
Do the same for declarations.
Delete duplicates like Serial.begin.
Is that true?
String readString;
    readString += c;
    readString = "";
Yes.
Make sure the 2 codes use different I/O pins. Don't use delay.
Fixed it.
Bluetooth D3 D4
RX TX voice control
Next, what needs to be done?
Compile it! If it's free from errors, download the code and let it run.
Well, he initially worked. Both sketches work.
I can't combine 2 sketches and make 1 sketch
I don't understand You. Follow the instructions in reply #2, line by line. Then You will have all the code in one sketch. Give it a new name and save it.
Here's the full sketch:
byte com = 0;
String readString;
  Serial.write(0xAA);
  Serial.write(0x37);
  Serial.write(0xAA);
  Serial.write(0x21);
    switch (com) {
      case 0x11:
      case 0x12:
      case 0x13:
      case 0x14:
      case 0x15:
    delay(3);
    readString += c;
    readString = "";
Please tell me what is wrong?
I don't see any errors. Compile and run the code. Remember to move all perpheral stuff to that one board.
The BT code reads the BT but doesn't do anyting more with the data read.
