Hello,
I am trying to get the readings of LDR on 0.96" Adafruit OLED Display using voice module V3 (voice commands). The display should start/stop displaying LDR readings when I say "on" and "off", it should run in loop. I have trained the voice module with that command.
I am even able to turn on/off led with that command. But after changing the code to read the LDR values as:
#include <SoftwareSerial.h>
#include "VoiceRecognitionV3.h"
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
int sensorPin = A0; // select the input pin for ldr
int sensorValue = 0;
#define OLED_RESET 4 // not used / nicht genutzt bei diesem Display
Adafruit_SSD1306 display(OLED_RESET);
char inChar;
String string;
Connection
Arduino VoiceRecognitionModule
2 -------> TX
3 -------> RX
VR myVR(2,3); // 2:RX 3:TX, you can choose your favourite pins.
uint8_t records[7]; // save record
uint8_t buf[64];
#define OnRecord (0)
#define OffRecord (1)
@brief Print signature, if the character is invisible,
print hexible value instead.
@param buf --> command length
len --> number of parameters
void printSignature(uint8_t *buf, int len)
int i;
for(i=0; i<len; i++){
if(buf[i]>0x19 && buf[i]<0x7F){
Serial.write(buf[i]);
else{
Serial.print("[");
Serial.print(buf[i], HEX);
Serial.print("]");
@param buf --> VR module return value when voice is recognized.
buf[0] --> Group mode(FF: None Group, 0x8n: User, 0x0n:System
buf[1] --> number of record which is recognized.
buf[2] --> Recognizer index(position) value of the recognized record.
buf[3] --> Signature length
buf[4]~buf[n] --> Signature
void printVR(uint8_t *buf)
Serial.println("VR Index\tGroup\tRecordNum\tSignature");
Serial.print(buf[2], DEC);
Serial.print("\t\t");
if(buf[0] == 0xFF){
Serial.print("NONE");
else if(buf[0]&0x80){
Serial.print("UG ");
Serial.print(buf[0]&(~0x80), DEC);
else{
Serial.print("SG ");
Serial.print(buf[0], DEC);
Serial.print("\t");
Serial.print(buf[1], DEC);
if(buf[3]>0){
printSignature(buf+4, buf[3]);
else{
Serial.println("\r\n");
/** initialize */
myVR.begin(9600);
pinMode(13, OUTPUT);
// initialize with the I2C addr 0x3C / mit I2C-Adresse 0x3c initialisieren
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.display();
display.clearDisplay();
display.setTextColor(INVERSE);
Serial.println("Elechouse Voice Recognition V3 Module\r\nControl LED sample");
pinMode(sensorPin, INPUT);
if(myVR.clear() == 0){
Serial.println("Recognizer cleared.");
}else{
Serial.println("Not find VoiceRecognitionModule.");
Serial.println("Please check connection and restart Arduino.");
while(1);
if(myVR.load((uint8_t)OnRecord) >= 0){
Serial.println("startRecord loaded");
if(myVR.load((uint8_t)OffRecord) >= 0){
Serial.println("endRecord loaded");
int ret;
ret = myVR.recognize(buf, 50);
if(ret>0){
switch(buf[1]){
case OnRecord:
sensorValue = analogRead(sensorPin);
display.setCursor(30,0);
display.setTextSize(1);
display.print("LDR Reading:");
display.setCursor(30,10);
display.setTextSize(2);
display.print(sensorValue);
case OffRecord:
default:
Serial.println("Record function undefined");
display.display();
printVR(buf);
The OLED in this case will start the display when I say on and freezes on the first reading with no change in display. Also there is no response when I say the second command.
There is a fault in my code. I am trying to run a loop inside switch case. I am a beginner in programming, can somebody please help me out?
Thanks in advance
