Voice password led trigger
Hi all, could anyone help me on this? I doing the voice password to trigger the led. I set my password to "1234" and once it correct, the led will be light up. But I cant get that works. Please help me on this. Your help is much appreciate!
#include "VoiceRecognitionV4.h" //VOICE using serial port library
VR myVR1(&Serial1);
VR myVR2(&Serial2);
uint8_t record[10]; // save record
uint8_t buf[32];
int led = 13;
#define group0Record0       (0)
#define group0Record1       (1)
#define group0Record2       (2)
#define group0Record3       (3)
#define group0Record4       (4)
#define group0Record5       (5)
#define group0Record6       (6)
#define group1Record0       (0)
#define group1Record1       (1)
#define group1Record2       (2)
enum Groups
  GROUP_1 = 1,
  GROUP_2 = 2,
  GROUP_16 = 16,
enum Group1
  G1_PASSWORD = 1,
  G1_CODE_NUMBER = 2,
enum Group2
  G2_ZERO = 0,
  G2_ONE = 1,
  G2_TWO = 2,
  G2_THREE = 3,
  G2_FOUR = 4,
  G2_FIVE = 5,
  G2_SIX = 6,
  G2_SEVEN = 7,
  G2_EIGHT = 8,
  G2_NINE = 9,
  G2_DELETE = 10,
enum Group16
  G16_OPENLOCK = 0,
int8_t group;
int8_t pci=0;
int form = 0;
char passcode[5] = "1234";
char usercode[5] = {'x','x','x','x','\0'};
  /** initialize */
  Serial1.begin(9600);
  Serial2.begin(9600);
  Serial.println("Elechouse Voice Recognition V3 Module\r\nMulti Commands sample");
  pinMode(led, OUTPUT);
  record[0] = group0Record0;
  record[1] = group0Record1;
  record[2] = group0Record2;
  record[3] = group0Record3;
  record[4] = group0Record4;
  record[5] = group0Record5;
  record[6] = group0Record6;
  record[0] = group1Record0;
  record[1] = group1Record1;
  record[2] = group1Record2;
  if(myVR1.load(record, 7) >= 0){
    printRecord(record, 7);
    Serial.println(F("loaded."));
  if(myVR2.load(record, 3) >= 0){
    printRecord(record, 3);
void action();
  int ret,ret1;
  ret = myVR1.recognize(buf, 50);
  ret1 = myVR2.recognize(buf, 50);
  if(ret>0)
    /** voice recognized */
    printVR(buf);
  if(ret1>0)
    printVR(buf);
  action();
void action()
      switch(group)
        case GROUP_1:
          switch(buf[1])
            case G1_PASSWORD:
            group = 16;
            case G1_CODE_NUMBER:
            form = 2;
            group = 2;
        case GROUP_2:
          switch(buf[1])
           case G2_ZERO:
            if(!passCode('0',0))
              group = 2;
           case G2_ONE:
            if(!passCode('1',1))
              group = 2;
           case G2_TWO:
            if(!passCode('2',2))
              group = 2;
           case G2_THREE:
            if(!passCode('3',3))
              group = 2;
           case G2_FOUR:
            if(!passCode('4',4))
              group = 2;
           case G2_FIVE:
            if(!passCode('5',5))
              group = 2;
           case G2_SIX:
            if(!passCode('6',6))
              group = 2;
           case G2_SEVEN:
            if(!passCode('7',7))
              group = 2;
           case G2_EIGHT:
            if(!passCode('8',8))
              group = 2;
           case G2_NINE:
            if(!passCode('9',9))
              group = 2;
            case G2_DELETE:
            pci--;
            usercode[pci] = 'x';
            Serial.println("delete number");
            Serial.print("pci: ");
            Serial.println(pci);
            if(pci<=0)
              pci=0;
            case GROUP_16:
            switch(buf[1])
              case G16_OPENLOCK:
              Serial.println("password correct");
              digitalWrite(led,HIGH);
bool passCode(char code_num, int number)
  usercode[pci] = code_num;
  Serial.println(number);
  Serial.println(usercode);
  pci++;
  if(pci>3)
    return comparePasscode();
  return false;
bool comparePasscode()
  if(!strcmp(usercode,passcode))
    Serial.println(passcode);
    Serial.println("passcode corect");
    delay(2000);
    return true;
     Serial.println("passcode inccorect");
     delay(2000);
     return false;
  @brief   Print signature, if the character is invisible,
           print hexible value instead.
  @param   buf     --> command length
           len     --> number of parameters
void printSignature(uint8_t *buf, int len)
  int i;
  for(i=0; i<len; i++){
    if(buf[i]>0x19 && buf[i]<0x7F){
      Serial.write(buf[i]);
    else{
      Serial.print("[");
      Serial.print(buf[i], HEX);
      Serial.print("]");
  @param   buf  -->  VR module return value when voice is recognized.
             buf[0]  -->  Group mode(FF: None Group, 0x8n: User, 0x0n:System
             buf[1]  -->  number of record which is recognized.
             buf[2]  -->  Recognizer index(position) value of the recognized record.
             buf[3]  -->  Signature length
             buf[4]~buf[n] --> Signature
void printVR(uint8_t *buf)
  Serial.println("VR Index\tGroup\tRecordNum\tSignature");
  Serial.print(buf[2], DEC);
  Serial.print("\t\t");
  if(buf[0] == 0xFF){
    Serial.print("NONE");
  else if(buf[0]&0x80){
    Serial.print("UG ");
    Serial.print(buf[0]&(~0x80), DEC);
  else{
    Serial.print("SG ");
    Serial.print(buf[0], DEC);
  Serial.print("\t");
  Serial.print(buf[1], DEC);
  if(buf[3]>0){
    printSignature(buf+4, buf[3]);
  else{
//  Serial.println("\r\n");
void printRecord(uint8_t *buf, uint8_t len)
  Serial.print(F("Record: "));
  for(int i=0; i<len; i++){
    Serial.print(buf[i], DEC);
    Serial.print(", ");
Why do you have two functions with the same name?
Paul
Ohh, I just aware that. But this doesnt affect anything
OP, you were able to train the model, correct? Did you test the trained model? What kind of correlations were you getting with the trained model testing? In your posted code, where is the trained model loaded?
Ya the model was loaded correct. I have trained from digit 0 to 9 and all can perform correctly
