Hi, I'm quite new to the voice recognition project. For this project, I'm going to set the 6 digit of password. So, once the password was matched, the storage locker will open and close accordingly. The problem is that this voice recognition module v3 only can recognize 7 digit at one time. So, I have digit 0 to digit 9, totally 10 digit. So, I have trained the voice module to recognize digit 0 to digit 9. Similarly, I have utilize the multicommand example given in arduino. The working principle is that after I speak from digit 0 to digit 6, I need to set a digit in order to switch to the second group and enable the digit 7,8 and 9 to be spoken. My question is that how I going to set the module in roder for me to speak from digit 0 to digit 9 unsequncely. Below is the code:
In this case, I'm using digit 0 as the word to switch between group1 and group 2.
#include <SoftwareSerial.h>
#include "VoiceRecognitionV3.h"
Connection
Arduino VoiceRecognitionModule
2 -------> TX
3 -------> RX
VR myVR(2,3); // 2:RX 3:TX, you can choose your favourite pins.
uint8_t record[7]; // save record
uint8_t buf[64];
int led = 13;
int group = 0;
#define group0Record0 (0)
#define group0Record1 (1)
#define group0Record2 (2)
#define group0Record3 (3)
#define group0Record4 (4)
#define group0Record5 (5)
#define group0Record6 (6)
#define group1Record1 (7)
#define group1Record2 (8)
#define group1Record3 (9)
/** initialize */
myVR.begin(9600);
Serial.println("Elechouse Voice Recognition V3 Module\r\nMulti Commands sample");
pinMode(led, OUTPUT);
if(myVR.clear() == 0){
Serial.println("Recognizer cleared.");
}else{
Serial.println("Not find VoiceRecognitionModule.");
Serial.println("Please check connection and restart Arduino.");
while(1);
record[0] = group0Record0;
record[1] = group0Record1;
record[2] = group0Record2;
record[3] = group0Record3;
record[4] = group0Record4;
record[5] = group0Record5;
record[6] = group0Record6;
group = 0;
if(myVR.load(record, 7) >= 0){
printRecord(record, 7);
Serial.println(F("loaded."));
int ret;
ret = myVR.recognize(buf, 50);
if(ret>0){
switch(buf[1])
case group0Record0:
if(group == 0)
group = 1;
myVR.clear();
record[1] = group1Record1;
record[2] = group1Record2;
record[3] = group1Record3;
group = 0;
myVR.clear();
if(myVR.load(record, 4) >= 0){
printRecord(record, 4);
default:
/** voice recognized */
printVR(buf);
@brief Print signature, if the character is invisible,
print hexible value instead.
@param buf --> command length
len --> number of parameters
void printSignature(uint8_t *buf, int len)
int i;
for(i=0; i<len; i++){
if(buf[i]>0x19 && buf[i]<0x7F){
Serial.write(buf[i]);
else{
Serial.print("[");
Serial.print(buf[i], HEX);
Serial.print("]");
@param buf --> VR module return value when voice is recognized.
buf[0] --> Group mode(FF: None Group, 0x8n: User, 0x0n:System
buf[1] --> number of record which is recognized.
buf[2] --> Recognizer index(position) value of the recognized record.
buf[3] --> Signature length
buf[4]~buf[n] --> Signature
void printVR(uint8_t *buf)
Serial.println("VR Index\tGroup\tRecordNum\tSignature");
Serial.print(buf[2], DEC);
Serial.print("\t\t");
if(buf[0] == 0xFF){
Serial.print("NONE");
else if(buf[0]&0x80){
Serial.print("UG ");
Serial.print(buf[0]&(~0x80), DEC);
else{
Serial.print("SG ");
Serial.print(buf[0], DEC);
Serial.print("\t");
Serial.print(buf[1], DEC);
if(buf[3]>0){
printSignature(buf+4, buf[3]);
else{
// Serial.println("\r\n");
void printRecord(uint8_t *buf, uint8_t len)
Serial.print(F("Record: "));
for(int i=0; i<len; i++){
Serial.print(buf[i], DEC);
Serial.print(", ");
