Voice recognition module v2 code issue
I am working in a voice recognition project and all the comands that I send in Serial depends on the button to execute the sub routines.
This code is all working, but when I press the button (botao), nothing happens.
I am brazilian, so the following code have comments in portuguese. Sorry about my english :confused:
This is part of my code, can you tell me what is wrong?
Here is a bit of my void loop, calling the sub routine "configurarG1" when gets 1 in the serial
  if ( Serial.available() > 0) {
    switch (Serial.read())
      case 49: { // numero 1
          Serial.println("Para confirmar a gravacao no grupo 1, pressione o botao");
          if(digitalRead(botao) == LOW){
          configurarG1();
This is one of the sub routines
void configurarG1()
  boolean sinal = 0;
    Serial.println("Iniciando gravacao do grupo 1");
    Serial1.write(0xAA);
    Serial1.write(0x11); //entra no modo de gravacao do grupo 1
    while (sinal == 0) {
      if ( Serial1.available() > 0) //detecta dado na porta serial
        incomingByte = Serial1.read(); //pega dado da serial e parte para o testes
        if (incomingByte == 0xe0) //erro de comando
          Serial.println("Erro de comando");
        else if (incomingByte == 0x40) //fale agora - START
          Serial.println("Fale agora");
        else if (incomingByte == 0x41) //sem voz
          Serial.println("Voz não detectada");
        else if (incomingByte == 0x42) //fale de novo!
          Serial.println("Fale novamente");
        else if (incomingByte == 0x43) //muito alto
          Serial.println("Muito alto");
        else if (incomingByte == 0x44)//diferente
          Serial.println("Comandos diferentes");
        else if (incomingByte == 0x45) //comando gravado
          Serial.println("Comando gravado com sucesso");
      else if (incomingByte == 0x46) //grupo gravado
        Serial.println("Grupo 1 gravado com sucesso");
        sinal = 1;
        Serial.println("Aguardando comando, mestre..");
    Serial1.write(0x21);    //incorpora o grupo 1 para utilizar
  sinal = 0;
What button? Perhaps you should try a switch, instead.
or
      case '1': { // no silly comment needed
          configurarG1();
Are you holding the switch when the 1 arrives?
You need to separate the reading of the switch from the reading of serial data.
Thank you!! I will see what I can do..
One of my problems was solved with:
estadoBotao = digitalRead(botao);
while ( estadoBotao != LOW ) {
            delay(100);
configurarG1();
Now I am having another issue, when I send 0xAA04 to the module, in datasheet it would return 0xcc or 0xe0, but it is returning the number 65. How can I fix this? 65 is the positive returning or the negative returning?
My code:
 void apagarTudo()
  Serial1.write(0x04);
  if (Serial1.available() > 0)
  Serial.println(incomingByte);
    if (incomingByte == 0xcc)
      Serial.println("Grupos apagados com sucesso!");
    else if( incomingByte == 0xe0)
      Serial.println("Erro ao apagar grupos");
Thanks in advance
65 is 0x41...
Thanks guys, all problems solved !
