Voice recognition module v3.1
Hi i’m Agustín. I have two voice recognition modules and im using vr_example_train of voicerecognitionmodulev3.1 library. One of the VRM work perfectly but to the other one i charge the voice command perfectly too but when i Need to load it to the device using “load” it seems to be no charged voice command.
If someone have used this board anytime please contact me
I moved your topic to an appropriate forum category @agusboli.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
What forum was the topic moved to?
I am curious, what board specifically are you using? where did you buy it?
I’m using https://www.elechouse.com/elechouse/images/product/VR3/VR3_manual.pdf this board. @LanGenz and i buy it from Aliexpress. Thank you for your response.
I recommend another module, the voice recognition module DM50A, which can record 50 instructions without grouping. It is also easy to use for UART communication, as it is available on AliExpress
I recommend another module, the voice recognition module DM50A, which can record 50 instructions without grouping. It is also easy to use for UART communication and can be purchased on AliExpress.
