Voice Recognition V3 Module timeout
i just used sample but shows me this error:
Elechouse Voice Recognition V3 Module "train" sample.
Usage:
COMMAND        FORMAT                        EXAMPLE                    Comment
train          train (r0) (r1)...            train 0 2 45               Train records
load           load (r0) (r1) ...            load 0 51 2 3              Load records
clear          clear                         clear                      remove all records in  Recognizer
record         record / record (r0) (r1)...  record / record 0 79       Check record train status
vr             vr                            vr                         Check recognizer status
getsig         getsig (r)                    getsig 0                   Get signature of record (r)
sigtrain       sigtrain (r) (sig)            sigtrain 0 ZERO            Train one record(r) with signature(sig)
settings       settings                      settings                   Check current system settings
help           help                          help                       print this message
train 1
Train Timeout.
clear
Clear recognizer failed or timeout.
settings
Check system settings error or timeout
vr
Check recognizer failed or timeout.
I've deleted your other cross-posts @arashsoft.
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
pert:
the problem is solved please remove them i don't know how to do it
I'm very glad to hear you solved your problem. It would be nice if you would take a minute to post a description of the solution you found. That will help anyone else with the same problem who later finds this thread while searching for information. I'm sure they would be very grateful.
Thanks!
