Voice record and playback basics?
Goal - play a voice recording if someone enters a room (part of a house alarm.)
I want to make a really simple audio player and have a switch trigger play back and another to cancel the playback.
I guess I need
Arduino
SD card for the recorded file (WAV?)
An amplifier and speaker loud enough to be heard if you are at the front door.
This library will help you a lot with your project.
The amplifier would be requied if you need to drive a loudspeaker. But for headphones, it's not necessary.
Note that the audio output is made from a PWM signal, so you will need a "low-pass filter". This can be built out of two 100 ohm resistors in series, and a 0.1 uF ceramic capacitor.
Awesome thanks for the tips.
Amplifier - Any recommendations from ebay or similar? Maybe 15 - 20Watts max.
What's an Arduino got to do with it?
You want a voice recorder, use a voice recorder!
Dave_vo:
It's for an alarm system, so that power should be enough. Remember to use a speaker that handles your output power.
Paul__B:
Believe it or not, an Arduino can playback audio pretty well (however here is always a quality limit, but still good enough :smiley: ).
Thanks for the suggestions.
Dave
