Voice Recording: Too Much Noise
RE: http://forum.arduino.cc/index.php?topic=573158.0
hello everyone i am having the same problem
here am using
Electret Mic Breakout Board;
Arduino uno
and
SD card adapter
what i noticed is that when i give a 3.3v to the mic i get a reasonable output put the noise is still present but when i give a 5v then i get the same output that was posted by MarkT
I searched online and i found “power supply noise rejection”
Power supply noise rejection – Technical Brief. … PSNR is a measurement of how well a circuit rejects noise from various frequencies which get coupled into the power supply. In high speed analog and digital circuitry, power supply pins are vulnerable to random noise.
so i tried giving vcc and ground of the mic from a nodemcu(3.3v) i have with me but still getting the same output.
from the zip file
TEST 4 is when i give vcc to 5v
TEST 5 and 6 is with 3.3v
test files.zip (214 KB)
That noise is way too low to be caused by the power supply. It is not noise anyway, which in electronics is a specific thing which sounds like a hiss.
The clicking sounds like interference from another source, maybe clipping caused by too much input signal or an LED or something flashing.
there no other input signal other than the sd card and and the mic and definitely for sure no led flashing
any other suggestions plz
TEST4.WAV has this sort of spike on a sporadic basis (not every 512 samples, so not buffering probably):
Mark T
what can i do to get better recording am not understanding the graph
Its a plot of sample value against sample number taken direct from the wav file - read a byte, plot it, just
a simple bit of python using matplotlib.
You have those noise spikes in your system, you have to troubleshoot this... The more information you
give us the more likely we can help. Without an oscilloscope problems like this are trickier to troubleshoot.
Here’s the Python code if its useful to anyone…
Needs numpy and matplotlib.
import numpy as np
import matplotlib.pyplot as plt
content = None
with open ("TEST4.WAV", "rb") as f:
    content = f.read()
samplen = np.zeros ([len(content)], int)
samplev = np.zeros ([len(content)], int)
for i in range (len(content)):
    samplen[i] = i
    samplev[i] = content[i]
#START = 1000
#LIMIT = 15000
START = 13700
LIMIT = 14200
# plot and show that the difference of output complex amplitudes for high and low has constant amplitude
fig = plt.figure()
ax = fig.add_subplot (1,1,1)
ax.plot (samplen[START:LIMIT], samplev[START:LIMIT], 'r')
plt.show()
Azeez_Jimoh:
Post all your code along with schematics and photographs of the wiring.
connections
Arduino and SD Card
https://hallroad.org/wp-content/uploads/2018/03/Micro-SD-Card-Reader-Module-In-Pakistan-3.jpg
arduino with mic
A0 to audio
3.3v to vcc
gnd to gnd
Code
#include <SD.h>
#include <SPI.h>
#include <TMRpcm.h>
#define SD_ChipSelectPin 4  //using digital pin 4 on arduino nano 328, can use other pins
TMRpcm audio;   // create an object for use in this sketch
  if (!SD.begin(SD_ChipSelectPin)) {
    return;
  }else{
    Serial.println("SD OK");
  // The audio library needs to know which CS pin to use for recording
  audio.CSPin = SD_ChipSelectPin;
    if(Serial.available()){                          //Send commands over serial to play
      switch(Serial.read()){
        case 'r': audio.startRecording("test.wav",16000,A0); break;    //Record at 16khz sample rate on pin A0
        case 'R': audio.startRecording("test.wav",16000,A0,1); break;  //Record, but with passthrough to speaker.
        case 't': audio.startRecording("test.wav",16000,A0,2); break;  //Do not record. Output direct to speaker
        							       //Note: If samples are dropped before writing, it
        							       //      will not be heard in passthrough mode
        case 's': audio.stopRecording("test.wav"); break;              //Stop recording
        case 'p': audio.play("test.wav"); break;                       //Play the recording
        case '=': audio.volume(1); break;                              //Increase volume by 1. Does not affect recording
        case '-': audio.volume(0); break;                              //Decrease volume by 1. Does not affect recording
        case 'S': audio.stopPlayback(); break;                         //Stop all playback
That link does not work, I get a page not found.
That description is not a schematic, at best it is incomplete.
Sorry for that for the sd card
Arduino to SD card
VCC to 5V in the Arduino.
GND of SD card to the ground of Arduino.
CS to pin 4
SCK to pin 13
MOSI to pin 11
MISO to pin 12
i gave different ground from the for both SD card and the mic from the UNO
They should have the same ground.
Link still does not work, that is not a schematic, are you serious about getting help?
A png of both connections
SD card and MIC with uno.zip (187 KB)
Blood -> stone :frowning:
The things I want to check is do you have level logic shifters on the SD card. A stupid Fritzing diagram is not going to tell me that, a schematic will because you will / should have labeled the SD card with the actual type it is.
Have you tried recording at a lower sample rate?
It is likely the dropouts you are seeing is a result of sporadic writing to the SD card.
