voice shield and LCD
//Reciever
#include<SPI.h>
#include <Wire.h>
#include <LiquidCrystal.h>
#include<VoiceShield.h>
LiquidCrystal lcd(30,31,32,33,34,35);
int key;
byte ledPin = 13;
VoiceShield vs(80);              // Create a instance of the Voice Shield called "vs" with 80 sound slots
int i = 1;
int Sentence[16];
int Phs1[] = {
   33, 78, 72, 255};     // "I am cold"
 int Phs2[] = {
   33, 78, 16};            // "I am sick"
int Phs3[] = {
    33, 44, 69};        // "I want food"
  Wire.begin(4);                // join i2c bus with address #4
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);           // start serial for output
    lcd.begin(16,2);
  if (key) {
    Wire.println(key);      //This will print which ever key is pressed
 int phrase;
  int loca=0;
   for(i =1; i < 4; i++)
 switch (key)               // Switching the keypad numbers to a message
       case '1':      //This calls keypad number 1
       for(loca =0; loca < (sizeof(Phs2)/sizeof(int)); loca++)
      Sentence[loca] = Phs2[loca];
       break;        //Ends witch for PRESSED
       case '2':      //This calls keypad number 2
        for(loca =0; loca < (sizeof(Phs3)/sizeof(int)); loca++)
      Sentence[loca] = Phs3[loca];
       case '3':       //This calls keypad number 3
        for(loca =0; loca < (sizeof(Phs1)/sizeof(int)); loca++)
          Sentence[loca] = Phs1[loca];
         default:
    Sentence[0] = 255;
  for(loca=0; loca < 15; loca = loca +1)
    if(Sentence[loca] == 255)
      loca = 15;
        vs.ISDPLAY_to_EOM(Sentence[loca]);
  // when characters arrive over the serial port...
    if (Serial.available()) {
      // wait a bit for the entire message to arrive
      // clear the screen
      lcd.clear();
      // read all the available characters
      while (Serial.available() > 0) {
        // display each character to the LCD
        lcd.write(Serial.read());
 //delay(20);
void receiveEvent(int howMany)
  while(1 < Wire.available()) // loop through all but the last
    char c = Wire.read(); // receive byte as a character
    Serial.print(c);         // print the character
    lcd.setCursor(1,0);
     lcd.print(c);
int x = Wire.read();    // receive byte as an integer
Serial.print(x);
 lcd.setCursor(0,1);
lcd.print(x);
i am trying to transmit information from one arduino to another. my problem is that i need the voice shield to say something when the button on the keypad is pushed based of the message coming from the sender keypad. the voice shield is on the second arduino along with the LCD and all that is showing is just a -1 on the LCD in place of the information and i wanted to know how i can fix that along with getting the voice shield to play when a button is pushed on the keypad that is on the sender device. this is the code for it
//Sender
#include <Wire.h>
#include <SoftwareSerial.h>
#include <Keypad.h>                   //This is the library for the key pad
#include <TinyGPS.h>
const int inPin=A0;
float temp;
int tempPin = A0;
const int heartratePin = A1;
int difference;
int newHeartReading = 0;
int lastHeartReading = 0;
int measurements[5] = {0,0,0,0,0};
int historySize = 5;
int recenttotal = 0;
int Index = 0;
boolean highChange = false;
int minimumdifference = 2;
int num[5];
int average=0;
SoftwareSerial GPS(11,12); // configure software serial port
TinyGPS shield;
// Heart rate timing
long lastHeartbeatTime = 0;
long debounceDelay = 150;       // the debounce time; increase if the output flickers
int currentHeartrate = 0;
int lastHeartrate = 0;
int slope = ((newHeartReading-lastHeartReading)/(debounceDelay-lastHeartrate));
// Debugging string
String debugOutput = "";
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
        {'1','2','3'},
        {'4','5','6'},
        {'7','8','9'},
        {'*','0','#'}
byte rowPins[ROWS] = {5, 4, 3, 2}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {8, 7, 6}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
byte ledPin = 13;
  Wire.begin(); // join i2c bus (address optional for master)
  GPS.begin(9600);
void getgps(TinyGPS &gps)
     // Define the variables that will be used
     float latitude, longitude;
     // Then call this function
     shield.f_get_position(&latitude, &longitude);
  int value = analogRead(inPin);
  Wire.beginTransmission(4); // transmit to device #4
  float millivolts = (value/1024.0)*5000;
  float celsius = millivolts/10-50;
  Wire.println("TEMPRATURE = ");
  Wire.println(celsius);
  Wire.println("*C");
  Wire.println();
 // lcd.setCursor(0,1);
  Wire.println((celsius * 9)/5 +32);
  Wire.println("*F");
  Wire.println();
   newHeartReading = analogRead(heartratePin);
   Wire.beginTransmission(1); // transmit to device #4
  //calculation
  difference = newHeartReading - lastHeartReading;
  lastHeartReading = newHeartReading;
  // Find new recent total
  recenttotal = recenttotal - measurements[Index] + difference;
  // replace indexed recent value
  measurements[Index] = difference;
   //index + 1 index = (index + 1) % historySize;
    for (int i=0; i<5; i=i+1){
               num[i]=0;
              if (Index>=5)
              Index=0;
              //calculating the average
              average=recenttotal/5;
              Wire.println(average);
  if (recenttotal >= minimumdifference)
    // possible heart rate check timing
    if (millis() - lastHeartbeatTime >= debounceDelay)   // whatever the reading is at, it's been there for longer
    // than the debounce delay, so take it as the actual current state:
 // Heart rate
 currentHeartrate = 60000 / (millis() - lastHeartbeatTime);
     lastHeartbeatTime = millis();
     if (currentHeartrate <= 200)// && currentHeartrate > 20)
                  Wire.println("Heart Rate =" + String(currentHeartrate) + "  ");
                 // delay(100);
            if (currentHeartrate <= 39 and currentHeartrate >= 0){
                  Wire.println("I Am Sick");
          if (currentHeartrate<= 79 and currentHeartrate >= 70){
                  Wire.println("Night Mare");
            if (currentHeartrate <= 69 and currentHeartrate >= 40){
                  Wire.println("kid Is At Sleep");
              if (currentHeartrate <= 99 and currentHeartrate >= 80){
                  Wire.println("Kid Is Resting");
                if (currentHeartrate <= 119 and currentHeartrate >= 100){
                  Wire.println("Kid Is Playing");
                  if(currentHeartrate > 120){
                    Wire.println(" The Kid Is Having ");
    Wire.endTransmission();    // stop transmitting
    byte a;
  if ( GPS.available() > 0 ) // if there is data coming from the GPS shield
    a = GPS.read(); // get the byte of data
    if(shield.encode(a)) // if there is valid GPS data...
      getgps(shield); // then grab the data and display it on the LCD
       Wire.println("Lat: ");
       Wire.println(latitude,5);
       Wire.println("  ");
       Wire.println("Long: ");
       Wire.println(longitude,5);
       Wire.println(" ");
char key = keypad.getKey();   //This calls the keypad its self
  if (key) {
       Wire.println("I AM Sick");    //This will display the message
       Wire.println("I Want Food");   //This will display the message
       Wire.println("I Am Cold");   //This will display the message
       case '4':   //This calls keypad number 4
       Wire.println("RECCA");   //This will display the message
       case '5':   ////This calls keypad number 5
       Wire.println("REVON");  //This will display the message
       case '6':  ////This calls keypad number 6
       Wire.println("JEAN PAUL");   //This will display the message
       case '7':   ////This calls keypad number 7
       Wire.println("MONIA");    //This will display the message
       case '8':   ////This calls keypad number 8
       Wire.println("DREAD HAIR");   //This will display the message
 delay(2000);
WTF?
      loca = 15;
This is nonsense.
if(Sentence[0] != 255)
   for(....
Don’t even enter the loop if there is nothing to do.
Nonsense. Send the damned packet with an end-of-packet marker. Read and store data, as fast as possible, until the end of packet marker arrives. When that happens, do something with the data.
You might as well get rid of this function. It accomplishes NOTHING.
  Wire.println("*C");
  Wire.println();
  Wire.println("*F");
  Wire.println();
Why
are
you
using
println()
for
everything?
Stupid comment aside, you are still in the middle of sending data to the other address.
