VoiceBox: how to implement serial flow control?
I stacked a voicebox shield on my Arduino and and XBEE shield on that. I wrote a small Delphi program to send the phonemes to the arduino which plays the phonemes. This all works great untill the text gets too long. The VoiceBox has a buffer 64 bytes and that easily overflows in my setup (I am sending it complete poems :-D).
I guess that I should use the Data Out pins to check the status of the VoiceBox. Read out D0, when it is HIGH the buffer is half full, wait until the VoiceBox is ready (D2 HIGH) and continue.
  • is that the correct approach?
  • if so, how can I access those pins?
Thanks for any help!
Rnold
Rnold:
Links to the relevant Voicebox and XBee shield would help but assuming your using the Sparkfun shield (https://www.sparkfun.com/products/10661?) then manual for the chip it uses says what to do
D2 / Buffer Half Full : Data Out 2 / Buffer Half Full
Data Out 2 / Buffer Half Full output is used for flow control
with a serial port by connecting to the CTS line back to the
computer or controller. Or it may be used as a general-
purpose output. This line is a logical output with either a High
or Low logic level. Which function this output uses is
determined by a configuration bit stored in the EEPROM and
the factory default configurations is: “Buffer Half Full” and is
Active High.
Only problem is the D2/BHF pin is not broken out to any arduino pins so you would need to solder a wire to it and cut a trace to one of the E pins so you could hijack it. Or maybe just wire it directly to the CTS pin on the XBee (if it has one).
Another approach would be to monitor D1 and when it goes low send <64 bytes of data to the shield and so on. You would have to buffer or control serial data flow from PC using arduino.
Ah, that explains i could not find an arduino pin for the D? because there is none . I will try your hijack suggestion in the weekend. I guess I have to solder a wire to the speakjet chip. Interesting experiment for me :-).
Thanks , Arnold.
Some late addition. I finally decided not solder the VoiceBox, just a bit too scary for me :slight_smile: But I did find out that the SPK pin (pin 4) of the voicebox goes high when it is speaking and low when it ceases speaking. I implemented an interrupt service routine for this pin that sends a signal to the computer when the pin goes low and the computer sends the next 64 bytes of code. This leads to an audible interrupt though.
You can connect a LED to SPK so you see exactly when the Voicebox speaks.
I'm glad you got something working. It's just a shame the D2/BHF did not get broken out somewhere to make the process smoother.
i agree it,You can connect a LED to SPK so you see exactly when the Voicebox speaks. good info
@Riva,agree with you completely. It's another shame that the SPK pin is not documented. Your remarks about breaking out the pins led me to very careful examination of the voicebox PCB. It was than that I detected some lanes communicating between the speakjet and some low number pins. After some experimenting I detected the SPK pin. So your remarks led me to the correct answer :-). Thanks!
