This void prints the rfid value on the lcd screen;
void dump_byte_array(byte *buffer, byte bufferSize) {
for (byte x=0; x < bufferSize; x++){
lcd.print(buffer[x] < 16 ? "0" :""); //value cannot be bigger than 16 digits
lcd.print(buffer[x], HEX);
When you include the void in the loop();
dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
its like that, but I wanna store the value it gives out as a int. So I can make name tags for each rfid card. ex;
if(valueoncard=="81949B75"){
lcd.print("Name1");
}else if(valueoncard=="839FA9D5"){
lcd.print("Name2");
}else if(dvalueoncard=="938C8F00"){
lcd.print("Name3");
}else if(valueoncard=="45E09F2C"){
lcd.print("Name4");
}else{
lcd.print("Your card has not been entered into the database. Sorry frown emoticon");
Hope this kinda makes sense.
Thanks for the help guys!
This is what everything looks like so far, we can make it print the value, but we want it to print out names.
#include <SPI.h>
#include <MFRC522.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd (7,6,5,4,3,2);
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
byte id;
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
// Number of known default keys (hard-coded)
// NOTE: Synchronize the NR_KNOWN_KEYS define with the defaultKeys[] array
#define NR_KNOWN_KEYS 8
// Known keys, see: https://code.google.com/p/mfcuk/wiki/MifareClassicDefaultKeys
byte knownKeys[NR_KNOWN_KEYS][MFRC522::MF_KEY_SIZE] = {
{0xff, 0xff, 0xff, 0xff, 0xff, 0xff}, // FF FF FF FF FF FF = factory default
{0xa0, 0xa1, 0xa2, 0xa3, 0xa4, 0xa5}, // A0 A1 A2 A3 A4 A5
{0xb0, 0xb1, 0xb2, 0xb3, 0xb4, 0xb5}, // B0 B1 B2 B3 B4 B5
{0x4d, 0x3a, 0x99, 0xc3, 0x51, 0xdd}, // 4D 3A 99 C3 51 DD
{0x1a, 0x98, 0x2c, 0x7e, 0x45, 0x9a}, // 1A 98 2C 7E 45 9A
{0xd3, 0xf7, 0xd3, 0xf7, 0xd3, 0xf7}, // D3 F7 D3 F7 D3 F7
{0xaa, 0xbb, 0xcc, 0xdd, 0xee, 0xff}, // AA BB CC DD EE FF
{0x00, 0x00, 0x00, 0x00, 0x00, 0x00} // 00 00 00 00 00 00
* Initialize.
lcd.begin(16, 2);
lcd.print("Scan a card");
lcd.setCursor(0,2);
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
Serial.println(F("Try the most used default keys to print block 0 of a MIFARE PICC."));
* Helper routine to dump a byte array as hex values to Serial.
void uids(){
//You need to find a way to turn the value into an int
//You've tried including the void and such.
if(dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size)=="81949B75"){
lcd.print("Name1");
}else if(dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size)=="839FA9D5"){
lcd.print("Name2");
}else if(dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size)=="938C8F00"){
lcd.print("Name3");
}else if(dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size)=="45E09F2C"){
lcd.print("Name4");
}else{
void dump_byte_array1(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
//Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i] < 16 ? "0" : "");
//Serial.print(buffer[i], HEX);
* Try using the PICC (the tag/card) with the given key to access block 0.
* On success, it will show the key details, and dump the block data on Serial.
* @return true when the given key worked, false otherwise.
boolean try_key(MFRC522::MIFARE_Key *key)
boolean result = false;
byte buffer[18];
byte block = 0;
byte status;
// Serial.println(F("Authenticating using key A..."));
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, key, &(mfrc522.uid));
if (status != MFRC522::STATUS_OK) {
// Serial.print(F("PCD_Authenticate() failed: "));
// Serial.println(mfrc522.GetStatusCodeName(status));
return false;
// Read block
byte byteCount = sizeof(buffer);
status = mfrc522.MIFARE_Read(block, buffer, &byteCount);
// Serial.print(F("MIFARE_Read() failed: "));
else {
// Successful read
result = true;
dump_byte_array((*key).keyByte, MFRC522::MF_KEY_SIZE);
// Dump block data
Serial.print(F("Block ")); lcd.print(block); Serial.print(F(":"));
dump_byte_array(buffer, 16);
mfrc522.PICC_HaltA(); // Halt PICC
mfrc522.PCD_StopCrypto1(); // Stop encryption on PCD
return result;
* Main loop.
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
// Show some details of the PICC (that is: the tag/card)
Serial.print(F("Card UID:"));
dump_byte_array1(mfrc522.uid.uidByte, mfrc522.uid.size);
lcd.clear();
lcd.setCursor(0,2);
//lcd.clear();
