Void Function/If statement question
What do i need to add to the last if statement, to make it that it will only proceed if LevelSense is >= 96 and if the void function WaitWaterSense is complete (WaitWaterSense is a timer)?
  int LevelSense = 98;
  if (LevelSense >=96) WaterSenseWait(); // if levelsensor is 96% or more full complete void function WaterSenseWait
   if ( LevelSense <= 95)
        //do something
  else if ( LevelSense >= 96) // here i want if levelsense>=96 and WaterSenseWait is complete
    //do something here
void WaterSenseWait(){
  //do timer here
Does WaitWaterSense() contain a loop that is waiting on something? If so then your program won't be able to do anything while waiting.
It looks like you are already doing that so I don't really understand...
ahh my bad. sorry there. In essence i simply have a water sensor but given when filling a water tank the water level can often get choppy i want to make sure that the water level is above 96%. So bassicly all i'm trying to achieve is if the water level sensor is above 96% for 5 seconds do task, if not, dont do task.
So your recommending i don't use the last if statement, but put it in the timer code instead? so in essence if levelSense reaches 96% start 5 second counter then do whatever.
if so my only problem with that is i want to see if the water level remains at 96% or more for 5 seconds and then do what is whatever is next.
If during the 5 seconds the water goes below 96%, you disable the TIMER.
When it again returns to >= 96% the TIMER is reset and enabled.
Actually you should use millis() function to time the 5 seconds. If the level remains above 96% then the timer will time out.
I can't test but this should work:
  static unsigned long prevMs = millis();
  unsigned long currentMs = millis();
  if (LevelSense < 96)
    prevMs = currentMs;
  if (currentMs - prevMs >= 5000)
    // If you get here then level must have been >= 96 for 5 seconds!!!
Just a minor point, but when you refer to a "void function", do you know what that means?
