Void -> how it returns values to the main programm
Hallo
i am new to C and the arduino
i have a question
i am bulding a vu meter
and i want to find the max and the min analog read from my microphone
so i write a “void”
void analog_calibration (int analoginput)
  timecounter = millis();
  timerunning = 0;
  mini = 1030;
  maxi = 0;
  for (i=1; ((timerunning-timecounter) < calibrationtime); i++ )
      value = analogRead(analoginput);
      if (value < mini) mini = value;
      if (value > maxi) maxi = value;
      timerunning = millis();
so in my programm sometime i will write
analog_calibration(microphone);
how can i make return me the min and the max value?
"void" means "nothing". A "void" function returns no value.
A function can return only a single value, so if you want to pass back two values from a function, you can use: 1) a structure 2) pointers 3) references.
I'd probably go with 3).
void analog_calibration (int analoginput, int& maxVal, int& minVal))
so i write a "void"
You don't write a "void", you write a function of type void.
void analog_calibration(int analoginput, unsigned long calibrationtime, int *detectedMini, int *detectedMaxi)
  //reset these to ensure a new reading
  detectedMini = 1030;
  detectedMaxi = 0;
  //local variables used to time the calibration
  unsigned long timecounter = millis();
  unsigned long timerunning = 0;
  int value = 0; //store the current read
  while ((timerunning-timecounter) < calibrationtime)
      if (value < *detectedMini) *detectedMini = value;
      if (value > *detectedMaxi) *detectedMaxi = value;
Call it like:
int micMin;
int micMax;
analog_calibration(microphone,1000,&micMin,&micMax); //calibrate min and max for mic over a period of 1000 ms
[edit]Groove beat me to it.
Since we ended up ‘recommending’ different solutions I’ll explain why I used the pointer method: It is simply because the the code that calls the function will have to explicitly say that the adress of a variable is to be sent. This is a way to tell the coder ‘remember that these variables may, or may not, be altered when you call this function’. The reference method provides the caller no visual cues as to what might happen to the original variable (not just the value of it).[/edit]
[edit]WHOOPS!
Thank you Groove!
I forgot that ‘tiny’ detail in the midst of everything :-[(I forgot to dereference the min/max variables in the function body)[/edit]
so i write a "void"
No. You wrote a function. Functions can have many different return types. The function you wrote was defined to not return a value (that's what the void in front means).
Had you defined the function to return an int, you could (and should) have had a return statement, to return the appropriate value.
Functions can return only a single value, though.
You could declare the function like this:
void analog_calibration(int analoginput, int &mini, int &maxi)
   // Compute mini and maxi
Then, call it like this:
int minVal;
int maxVal;
int inVal = 27;
analog_calibration(inVal, minVal, maxVal);
// minVal contains the value defined in the function as mini
// maxVal contains the value defined in the function as maxi
However, mini and maxi are not typed in the function you wrote, so they must be global variables. In which case, there is not need to return them.
if (value < detectedMini) detectedMini = value;
Ahem. :wink:
thanks
so the & means that the value goes back
The & means that you are passing by reference, instead of by value. In other words, the address of the memory location referred to by that name (the location to read from/write to) is passed to the function, instead of the value at that address.
Having the address, instead of the value, means that the function can modify the value and that modified value will be seen by the caller when the function ends.
void analog_calibration (int analoginput, int &mini, int &maxi )
  long value;
  mini = 1030;
  maxi = 0;
then i call
analog_calibration (int microphone, minval, maxval )
and below this line
in minval i will have the last value of the mini
and on the maxval the last value of the maxi
sry but the arduino is still on the way and i cant test it
The variable i is not typed. This will not compile, unless i is a global variable. If it is, using a global variable as a loop counter is not appropriate.
Typically, a for loop is used when the number of iterations is known. In this case, the termination of the loop is not dependent on i, so a for loop is not really appropriate.
calibrationtime is not typed, so it must be a global variable.
millis() returns an unsigned long, not a long. So, timecounter and timerunning are not typed appropriately.
As a side note, camel case is preferred for variable names, so timeCounter, timeRunning, and calibrationTime would be better names.
Finally, analogRead does not return a long, so value is mis-typed.
i didnt find a way to loop something for a amount of time(sec) not an amount o times ( repeats )
yes i use i j k as global for many void functions
about the unsigned long
its gone work ?
Look at the while statement.
Stop that. And get rid of the word there. The term is function(s). void is a return type.
What about it?
The Arduino-preprocessor cannot handle reference parameters in sketches (yet?). There is a bug-report for this (google-code-servers are currently down :( I can't set a link to the issue).
So only structure and pointer solutions will work. Eberhard
i made the changes
it is a knight rider project
i have write the most of my patterns
but i dont have write the main programm
how can we fase an led and the same check if a button is pressed
can the arduino goes over two loops at the same time
the whole code
run out of Remaining characters on post
int led[ ] = {54, 53, 52, 51, 50, 49, 48, 47, 46, 45, 44, 43, 42, 41, 40, 39, 38, 37, 36, 35, 34, 33, 32, 31, 30, 29, 28, 27, 26, 25, 24, 23, 22, 21, 20, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8};
is this correct
the led[0] is equal to 54 and led[45] is equal to 8
"45" is the total numbers minus one for the zero
they have to be 46 - i havent count them
Arduino 0017:
void myProc (int& a, int& b)
  a = 2;
  b = 7;
int myA = 0;  //Belt AND braces.
int myB = 0;
void setup ()
  myProc (myA, myB);
  Serial.begin (9600);
  Serial.println (myA);
  Serial.println (myB);
void loop ()
seems to work perfectly.
This has become a long thread!
Stop that! And get rid of the word there. The term is thread(s). long is an adjective
OK, so I put it on the edge, but I think it is perfectly fine to say 'void function', it is easier to say and understand than 'a function that returns void' which is kind of a paradox, really.
Pun slightly intended PaulS 8-)
Yes your code works
void myProc (int& a, int& b) {
  a = 2;
  b = 7;
int myB = 0;
void setup () {
  myProc (myA, myB);
void loop () {
but this one doesn't
int myB = 0;
void setup () {
  myProc (myA, myB);
void loop () {
  a = 2;
  b = 7;
The IDE does not generate a prototype for functions that use arguments with reference parameters.
see: http://code.google.com/p/arduino/issues/detail?id=205 (please ignore that the OP of the google-code issue got the headline wrong)
Eberhard
