void loop cannot execute and returns values on Arduino Mega 2560
Hi I have a sketch with the following structure:
int main()
void A()
void B()
void C()
void D()
So the idea is that the obtain values in void loop should be return to void D and after some math, the values of void D should return to void C. The problem is that the void loop never executed!! Any suggestion?
Complete sketch is as follows:
#define UN (400.0)
#define FN (50.0)
#define P (UN/FN)
#define T_PWM (0.000255)
#define T_MAX (4.0)
#define T_MIN (0.02)
#define K_MAX floor (T_MAX/T_PWM)
#define K_MIN ceil (T_MIN/T_PWM)
volatile static unsigned int length_tab_sin;
static unsigned int i = 0;
volatile static unsigned int main_counter = 0;
static unsigned int next_value_sin = 0;
static double t_param = 100;
static float t = T_PWM;
static float omega_t;
static float t_out;
static float U_o_param;
static unsigned int ocr3a, ocr3b, ocr1a;
static unsigned int ocr1b, ocr2a, ocr2b;
static double sin_in;
static double error = 1;
static unsigned int analog = 0;
static double U_in = 0;
static double U_rms_max;
static bool a = 0;
// Tachometer parameters: //////////////////////////////
long startTime = 0;
int state, prevState = 0;
int sensor = 0;
long counter = 0;
double Ff = 0;
long sample_time;
int magnet_number;
int sensore_output_voltage = 1000;
int rpm;
//unsigned long startTime;
long samp = 0;
  Serial.begin(57600);
  pinMode(A7, OUTPUT);          //LED out pin
  pinMode(A1,OUTPUT);           //Sensor VCC pin
  pinMode(A0,INPUT);            //Sensor Input pin
int main()
  io_init();
  timers_init(); // initialization of PWM meters
  adc_init(); // initialization of the ADC transducer
  while (1) // infinite loop with the main program
    if (i == 185)
      chang_para();
      i = 0;
    next_value_sin = main_counter % length_tab_sin;
    sin_in = omega_t*next_value_sin;
    ocr1a = round(error * (U_o_param * (sin(sin_in) + 1) * 254 / 2) + 1); // pin
    ocr1b = ocr1a - 1;
    ocr2a = round (error * (U_o_param * (sin(sin_in - 2.09) + 1) * 254 / 2) + 1); // pin
    ocr2b = ocr2a - 1;
    ocr3a = round(error * (U_o_param * (sin(sin_in + 2.09) + 1) * 254 / 2) + 1); // pin
    ocr3b = ocr3a - 1;
    cli();
    OCR1AL = ocr1a; // pin
    OCR1BL = ocr1b; // pin
    OCR2A = ocr2a; // pin
    OCR2B = ocr2b; // pin
    OCR3AL = ocr3a; // pin
    OCR3BL = ocr3b; // pin
    sei();
    i++;
void adc_init()
  ADCSRA |= _BV(ADEN);
  ADCSRA |= _BV(ADPS2);
  ADCSRA |= _BV(ADPS1);
  ADCSRA |= _BV(ADPS0);
  ADMUX |= _BV(REFS0);
  ADMUX |= ADMUX &= 0b11110000; // choose the ADC0 input for measurement
void timers_init()
  cli();
  TCCR1A |= _BV(COM1A1) | _BV(COM1B0) | _BV(COM1B1) | _BV(WGM10);
  TCCR1B |= _BV(CS11); // preskaler 8  | _BV(WGM02)
  TIMSK1 |= _BV (TOIE1);        // flag from value 0 enabled //??????????
  TCCR2A |= _BV(COM2A1) | _BV(COM2B0) | _BV(COM2B1) | _BV(WGM20);
  TCCR2B |= _BV (CS21); // preskaler 8 //  | _BV(WGM02)
  TCCR3A |= _BV(COM3A1) | _BV(COM3B0) | _BV(COM3B1) | _BV(WGM30);
  TCCR3B |= _BV(CS31); // preskaler 8  | _BV(WGM02)
  TCNT1L = 0;
  TCNT2 = 0;
  TCNT3L = 0;
  sei();
void io_init()
  pinMode(5, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(14, INPUT_PULLUP);
  pinMode(15, INPUT_PULLUP);
  pinMode(16, OUTPUT);
ISR(TIMER1_OVF_vect) // interrupt at 0 counter 0
  analog = ADC;
  if (a)
    U_in = 0.0709 * analog;
    ADMUX |= _BV(MUX0); // choose the ADC1 input to measure the current
    ADMUX |= ADMUX &= 0b11110000; // select the ADC0 input to measure the voltage
    if (analog > 579)
      error = 0; // if the overload turn off the voltage generation
      digitalWrite(16, HIGH); // lighting the diode
  ADCSRA |= _BV(ADSC); // start reading the measurement
  a = a ^ 1; // the XOR gate negates the logical value a
  main_counter++;
  if (main_counter >= length_tab_sin) main_counter = 0;
void chang_para()
  U_rms_max = U_in * 0.62;
  bool up;
  bool down;
  up = digitalRead(14);
  down = digitalRead(15);
  if (!up) t_param--;
  if (!down) t_param ++;
  if (t_param < 0) t_param = 0;
  if (t_param > 100) t_param = 100;
  length_tab_sin = ceil((K_MAX - K_MIN) * t_param / 500 + K_MIN);
  t_out = T_PWM * length_tab_sin;
  omega_t = t * 2 * PI / t_out;
  U_o_param = (P / t_out) / U_rms_max;
  if (t_out > 1) U_o_param = 0.5 * (18.5 / U_rms_max);
  if (U_o_param > 1) U_o_param = 1;
  error = 1;
  digitalWrite(16, LOW); //diode lighting
                Serial.println(t_param);
  //reset variables.
  sensor = 0;
  Ff = 0;
  state = 0;
  prevState = 0;
  counter = 0;
  startTime = millis();
  sample_time = 5000;        //Loop for sample duration of sec
  magnet_number = 4;       //is number of magnets per revulotion
  rpm = 0;
  //enable sensor and turn on LED when touched.
  digitalWrite(A1, HIGH);
   Serial.println("Measuring...");
  //Loop for sample duration of 10 sec
  while((millis() - startTime) < sample_time)
    sensor =  analogRead(0);
//    Serial.print("sensor = "); Serial.println(sensor);
    if (sensor > sensore_output_voltage)  //sensore output voltage
    state = 1;
    state = 0;
     digitalWrite(A7,state); // Blinking LED when sensor Activated
    //On change of state increment counter.
    //A change in state twice represents one revolution
    if(state != prevState)
      counter++;
      prevState = state;
  counter = counter * 12 / 2; // 12*5sec=60sec
  rpm = counter / magnet_number;
//  Ff=  rpm * 4.0 * 100 / 120;               // rpm=120*f/p   , 4 pole motor, 100 is float multiplier
  Ff=  rpm * 4.0 / 120;               // rpm=120*f/p   , 4 pole motor,
  //Trun off Sensor and LED
  digitalWrite(A7,LOW);
  digitalWrite(A1, LOW);
  //Display RPM
  Serial.print("count = "); Serial.println(counter);
  Serial.print("RPM = "); Serial.println(rpm);
  Serial.print("freq = "); Serial.println(Ff);
  delay(100); // delay 1 ms
There is a main() function in the Arduino core library that calls setup() and loop(). When you define a function named main() in your sketch it overrides the main() in the core library and so setup() and loop() never get called.
It's not really clear what you're trying to accomplish in this code. Maybe it's just blind copy/paste?
pert: There is a main() function in the Arduino core library that calls setup() and loop(). When you define a function named main() in your sketch it overrides the main() in the core library and so setup() and loop() never get called.
It is not a blind copy paste, it was 2 separate codes that I modified them separately and tried to combine them. The whole code except the loop() part is a PWM variable frequency drive which should be drive a induction motor. The loop() section should read the speed of another rotating shaft and its speed should be return back to void chang_para() section as a coefficient to the final speed of the motor. Both code are running separately without any problem but when combine the loop part is not running. Is it possible to replace main or loop function to another commands to solve the problem?
So a blind copy-paste as we suspected...
Move the code at the start of your main() into setup().
Move the body of the while loop in your main() into loop()
Delete your main() function which is now empty.
MarkT:
So a blind copy-paste as we suspected…
Mark, for a expert like you it is a blind thing but for a newbie like me it is a lot of work. Also thank you for your help. As you said I made the change on code and it became like this:
#define UN (400.0)
#define FN (50.0)
#define P (UN/FN)
#define T_MAX (4.0)
static float t_out;
static bool a = 0;
long startTime = 0;
int sensor = 0;
long counter = 0;
double Ff = 0;
long sample_time;
int magnet_number;
int rpm;
long samp = 0;
  io_init();
void adc_init()
void timers_init()
  cli();
  TCNT1L = 0;
  TCNT2 = 0;
  TCNT3L = 0;
  sei();
void io_init()
  pinMode(5, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(9, OUTPUT);
  analog = ADC;
  if (a)
    if (analog > 579)
  main_counter++;
void chang_para()
  bool up;
  bool down;
  if (!up) t_param--;
  error = 1;
     if (i == 185)
      chang_para();
      i = 0;
    ocr1b = ocr1a - 1;
    ocr2b = ocr2a - 1;
    ocr3b = ocr3a - 1;
    cli();
    sei();
    i++;
  //reset variables.
  sensor = 0;
  Ff = 0;
  state = 0;
  prevState = 0;
  counter = 0;
  rpm = 0;
    state = 1;
    state = 0;
      counter++;
      prevState = state;
  //Display RPM
now the problem is the functionality is totally destroyed, not PWM is working nor rpm counter. I tried to do more googling to learn more but nothing found. Any help?
You need to go through the original programs line by line until you understand what each line is supposed to do and why.
Only when you understand that, will it become possible to sensibly merge two programs.
"A lot of work" is the only way to become an expert. If you want a result without doing the work, post on the Gigs and Collaborations forum section, and be prepared to pay for the help.
void functions don't return values.
jremington: You need to go through the original programs line by line until you understand what each line is supposed to do and why.
Only when you understand that, will it become possible to sensibly merge two programs. "A lot of work" is the only way to become an expert. If you want a result without doing the work, post on the Gigs and Collaborations forum section, and be prepared to pay for the help.
You are right and I am trying to learn and understand it.
Delta_G: void functions don't return values.
Good point, thank you
You have put a lot of stuff before - Void Setup().. .
Slumpert: You have put a lot of stuff before - Void Setup().. .
The main problem is with timers, when I disable timers_init(), timer0 can do millis(). I do not know how to set timer0 for millis and timer 1,2,3 for PWM! I think this is the first problem.
Maslord: The main problem is with timers, when I disable timers_init(), timer0 can do millis(). I do not know how to set timer0 for millis and timer 1,2,3 for PWM! I think this is the first problem.
Why are you trying to do that yourself? Just let the Arduino core do that stuff for you. Stick within the normal framework of an Arduino sketch, which just means not having a function called "main" and you get that with no effort.
The Arduino IDE automatically sets up the timers to count milliseconds and produce PWM.
MarkT:
After few days following your useful comment I finally could fix the code but the respond time is very slow and the rpm counter is very noisy, do you have any idea please? if you have required hardware, could you please test the output frequency on oscilloscope?
#define UN (400.0) // motor rated voltage
#define FN (50.0) // motor nominal frequency
#define P (UN/FN) // associate Determining the ratio of voltage to nominal frequency
#define T_PWM (0.000255) // PWM signal period - set by the prescaler in the counters
#define T_MAX (4.0) // Specify the maximum output voltage period
#define T_MIN (0.02) // minimum output voltage
#define K_MAX floor (T_MAX/T_PWM) // number of period values for T_MAX
#define K_MIN ceil (T_MIN/T_PWM) // number of period values for T_MIN
volatile static unsigned int length_tab_sin; // variable containing the number of values in the full // period of the output voltage
static unsigned int i = 0; // auxiliary variable
volatile static unsigned int main_counter = 0; // variable in the interrupt
// ^ every T_PWM period increasing its value by 1
static unsigned int next_value_sin = 0; // variable which value sin should be calculated
static double t_param = 100; // parameter specifying the period of the output voltage
static float t = T_PWM; // T_PWM
static float omega_t; // pulsation of the output voltage multiplied by T_PWM
static float t_out; // output voltage period
static float U_o_param; // parameter specifying the size of the output voltage
// ^ calculated on the basis of t_out and U_in
static unsigned int ocr3a, ocr3b, ocr1a; // auxiliary variables to store obl. fillings
static unsigned int ocr1b, ocr2a, ocr2b; // ^
static double sin_in; // variable containing the parameter of the function sin
static double error = 1; // variable used to stop generating voltage when overloaded
static unsigned int analog = 0; // variable containing the measured value
static double U_in = 0; // variable holding the voltage measurement of the intermediate system
static double U_rms_max; // maximum currently possible to generate the effective voltage value
static bool a = 0; // logical variable for the implementation of two alternating measurements
unsigned long startTime = 0;
int sensor = 0;
long counter = 0;
double Ff = 0;
long sample_time;
int magnet_number;
int rpm;
long samp = 0;
  io_init(); // initiate entry and exit
    if (i == 185) // condition specifying the entry to the change function
    { // parameter of the discharge voltage, calling approx. 100ms
      chang_para(); // function to change the parameters of the output voltage
      i = 0;
    next_value_sin = main_counter % length_tab_sin; // the next sine value to be calculated
    // calculating the value to registers specifying the completion of the output signal /
    ocr1b = ocr1a - 1;
    ocr2b = ocr2a - 1;
    ocr3b = ocr3a - 1;
    sensor = 0;
  Ff = 0;
  state = 0;
  prevState = 0;
  counter = 0;
  sample_time = 10;        //Loop for sample duration of sec
  rpm = 0;
  samp=0;
  digitalWrite(A5, HIGH);
//  Loop for sample duration of 10 sec
    sensor =  analogRead(A3);
    samp=millis();
    state = 1;
    state = 0;
      counter++;
      prevState = state;
      Serial.println("sensor");
    // updating values in registers /
    cli(); // prohibition on obsloge interruptions in case if
    // an interrupt occurred during the upgrade
    OCR1BL= ocr1b; // pin
    sei(); // allow for interruption obsloge
    i++;
void adc_init()
  ADCSRA |= _BV(ADEN); // start the transmitter
  ADCSRA |= _BV(ADPS2); // setting the prescaler
  ADCSRA |= _BV(ADPS1); // ^
  ADCSRA |= _BV(ADPS0); // ^
  ADMUX |= _BV(REFS0); // reference voltage set as power supply
void timers_init()
  cli(); // interrupt handler is forbidden
  // timer1 init
  // timer2 init
  // timer3 init
  // resetting counter values
  TCNT1L = 0;
  TCNT3L = 0;
  TCNT2 = 0;
  /* the counter counts in g3re to 255, then in d3 ณ: / \ / \ / \
            at the value of 255 there is an interruption at which it occurs
            voltage and current measurements
void io_init()
  pinMode(2, OUTPUT); // OC0A Arduino Mega2560 pin 13
  pinMode(5, OUTPUT); // OC0B Arduino Mega2560 pin 4
  pinMode(11, OUTPUT); // OC1A Arduino Mega2560 pin 11
  pinMode(12, OUTPUT); // OC1B Arduino Mega2560 pin 12
  pinMode(10, OUTPUT); // OC2A Arduino Mega2560 pin 10
  pinMode(9, OUTPUT); // OC2B Arduino Mega2560 pin 9
  pinMode(16, OUTPUT); // Arduino Mega2560 16
    pinMode(A5,OUTPUT); //Sensor VCC pin
    pinMode(A3,INPUT); //Sensor Input pin
    pinMode(A0,INPUT); //pot Input pin
  analog = ADC;
  if (a)
    if (analog > 579)
  main_counter++;
void chang_para()
t_param = map(analogRead(0),0,1230,0,100);
  U_rms_max = U_in * 0.62; // value 0.62 experimentally limited
  if (t_param < 0) t_param = 0; // protection of exceeding the extreme values
  if (t_param > 100) t_param = 100; // ^
  length_tab_sin = ceil((K_MAX - K_MIN) * t_param / 500 + K_MIN); // amount of values filled in one period
  t_out = T_PWM * length_tab_sin; // calculate the period of the output voltage
  omega_t = t * 2 * PI / t_out; // calculate the output voltage pulsation
  U_o_param = (P / t_out) / U_rms_max; // calculate the parameter determining the value of the output voltage
  if (t_out > 1) U_o_param = 0.5 * (18.5 / U_rms_max); // voltage at the output at low frequencies of 10v
  if (U_o_param > 1) U_o_param = 1; //protection of exceeding the extreme values
  error = 1; //if the overload turn off the voltage generation
There are lots of problems with that code.
It is slow because of the extensive use of floating point operations (trigonometric functions are very slow), you are printing unnecessarily; it may not work because variables are used in interrupt routines that are not declared "volatile" and there appear to be typos in some values. You should NOT do floating point operations in interrupt routines, in fact you should just set a global flag that the interrupt occurred, and exit.
Examples of potential problems:
Serial.println("sensor"); //why print this?
  analog = ADC;
  if (a)  //not volatile
    U_in = 0.0709 * analog; //slow
t_param = map(analogRead(0),0,1230,0,100);  //1023?
jremington:
It is slow because of the extensive use of floating point operations (trigonometric functions are very slow), you are printing unnecessarily; it may not work because variables are used in interrupt routines that are not declared “volatile” and there appear to be typos in some values. You should NOT do floating point operations in interrupt routines, in fact you should just set a global flag that the interrupt occurred, and exit.
  analog = ADC;
Thank you Jremington for the points.
Actually I used Serial.println just for debugging, and the value"1230" was a typo.
I red about necessity of “volatile” for intrups, but I do not know how to do it, as “a” is a logical variable! Should I simply use “volatile int a;” at the beginning of the code?
Before adding the following section the code was running very fast, but the problem starts after adding it to the “void loop ()” body.
    sensor = 0;
  Ff = 0;
  state = 0;
  prevState = 0;
  counter = 0;
  rpm = 0;
  samp=0;
    samp=millis();
    state = 1;
    state = 0;
      counter++;
      prevState = state;
The problem got worst when I increase the “sample_time” value. I think the while loop and millis function slow down the implementation of the code. Is it possible to execute two action in parallel in loop?
use "volatile int a;" at the beginning of the code
Yes.
No. But two sequential actions can be carried out so quickly that you might not notice a delay.
Post ALL the code that you are having problems with, and explain as clearly as possible what the problem is. Snippets are useless.
The fact that your “sample time” is actually only .01 seconds might be a issue.
jremington:
Yes.
Ok, lets start from the beginning. I had 2 codes, one for three phase PMW drive (code1), the other one for tachometer (code2). Both codes work totally well separately.
The problem started from the pint of combining both codes in one code. Code1 is based on modified “int main()” function and code2 is based on “void loop()” function. So to combine, as MarkT suggested, I moved the code at the start of the main() of code1 into setup() of code1, then renamed “int main ()” to “void loop ()”. So in the next step I added the constants, void setup () and void loop () of code2 in the code1, which became code3 that I posted at #14.
I connected LEDs to PWM outputs so see the blinking status. Now the main problems:
1- When I keep connecting pin A5 to A3, the counter start to count random values which should not. Seems noisy but A3 is connected to ground using 10k resistor.
2- When set “t_param” to a specific value using pot, the blinking speed is much much slower in
comparison with the same value in code1. seems loop () very slow down the speed or change the frequency of PWM.
3- Every time that the counter starts to count, LEDs stop blinking, seems PWM pauses.
Any suggestion?
code1.ino (7.46 KB)
code2.ino (1.7 KB)
