I want to know if this possible.
I am using 4 force density sensors each sensor correspond n,s,e,w.
if the sensor is press
it will increment
example
n= n++
if the n value will be going to 10
then
it will light up leds like a trafficlight
then the n value will return to value of zero
then the other will continues counting up to 10.
using void loop
I didn't try yet due to i am researching all the ideas i need from making the traffic light last night i am having problem making a counter in the void loop thats why i am asking here. if you can help show me an example a continues counter logic. Thank you in advance
if n<100 then
ncounter =ncounter++
else if s < 100 then
scounter =scounter++
else if e < 100 then
ecounter =ecounter++
else if w< 100 then
wcounter =wcounter++
end if
if ncounter =10 then
ncounter=0
and set the LED to high
i will ask if the previous values of the scounter,wcounter,ecounter will be retain?
You need to explain more precisely what you want. Do you want the counter to increment indefinitely or do you want it to reset back to 0 after a certain number of counts?
If you write down a clear description in plain language it will often help you to see a solution.
