Good morning, sir,
For my part, I have on S Duino Due (clone of the Arduino Due) with an ARM AT SAM 3X8E AU processor.
The test sketch used is the one of lDE Arduino 1.87 : Files / Example : 01. Basics \ Blink
This is the flashing of LED 13 on the Due card.
My problem : void loop() does not run in infinite loop
In some cases only the 1st line of void loop() is executed: led 13 lit in fixed.
Delay(1000) does not execute!
The "Blink" sketch being uploaded into the Due depending on the case void loop() works.
A--> If the card has been unplugged for about 1 minute (the capacitor on the card should discharge after this time), LED 13 remains lit permanently if the USB power supply is connected.
Only 2 manipulations restart void loop() and the led starts flashing normally.
- Press the Reset button
- Repeatedly unplug and replug the USB
B--> If the board has been disconnected for about 1 minute (the capacitor on the board must discharge after this time), LED 13 remains permanently lit if an external 7.5V power supply is connected.
3) Press the Reset button
4) Disconnect and reconnect the external power supply multiple times.
Q1: Do you have the same operation of your Arduino Due?
Q2: How do you manage this situation?
Related question :
Q3: When do you use the "Erase" button next to the CPU?
Q4 : What should I do if the " Erase " button has been pressed when the Arduino Due card is powered on? (case of another Arduino Due card that I own)
Q5: Do you have a link that talks about the use of this button?
Thank you for your opinion and experience!
