Void loop doesn't work
the loop doesn't work can anybodie help me?
#include <Wire.h>
#include <Servo.h>
//scherm
LiquidCrystal_I2C lcd(0x27, 20, 4);
//servo maken
Servo servo_base;
Servo servo_grijper;
Servo servo_voor_achter;
Servo servo_boven_onder;
int menu_Licht = 52;
int pos_draai_langzaam_controle = 0;
int pos_grijp_langzaam;
int pos_draai_langzaam;
int pos_open_langzaam;
int einde = 0;
int grijper_dicht_langzaam_controle = 0;
int grijper_open_langzaam_controle = 0;
int menue = 0;
// pottentiometer input voor manuele besturing
int potPin_Grijper = A0;
int potPin_Base = A1;
int potPin_voor_achter = A2;
int potPin_boven_onder = A3;
// pottentiometer waarde voor manuele besturing
int potVal_Grijper = 0;
int potVal_Base = 0;
int potVal_voor_achter = 0;
int potVal_boven_onder = 0;
//knop
int switchPinKnop1 = 40;
int switchStateKnop1 = LOW;
int switchPinKnop2 = 38;
int switchStateKnop2 = LOW;
int switchPinKnop3 = 42;
int switchStateKnop3 = LOW;
int switchPinKnop4 = 36;
int switchStateKnop4 = LOW;
int switchPinKnopMenue = 44;
int switchStateKnopMenue = LOW;
int switchPinReset = 26;
int switchStateReset = LOW;
// servo aan poort vast maken
  servo_base.attach(7);
  servo_grijper.attach(6);
  servo_voor_achter.attach(5);
  servo_boven_onder.attach(5);
// servo klaarzetten
  servo_base.write(0);
  delay(40);
 // servo_grijper.write(40);
  delay(40);
 // servo_voor_achter.write(0);
  delay(40);
//knop
    delay(200);
    pinMode(switchPinReset, INPUT);
     delay(100);
     //knop bedining
      pinMode(switchPinKnop1, INPUT);
        delay(100);
      pinMode(switchPinKnop2, INPUT);
        delay(100);
      pinMode(switchPinKnop3, INPUT);
        delay(100);
      pinMode(switchPinKnop4, INPUT);
        delay(100);
      pinMode(switchPinKnopMenue, INPUT);
        delay(100);
  // licht
   pinMode(menu_Licht, OUTPUT);
 //scherm
  lcd.init();                   // initialiseer het LCD scherm
  lcd.backlight();
       Serial.print("looptest");
     debug();
     controlerenKnopEinde();
       selectKnoppen();
       selectKnoppen;
    pot();
  if (einde == 0){
void selectKnoppen () {
          knoppenStateGeven();
          DebugKnoppen();
      if (switchStateKnop1 == HIGH) {
            if (menue == 0){
           else if (menue == 1){
              //opdracht
            delay(200);
      if (switchStateKnop2 == HIGH) {
            if (menue == 0){
                klappen();
           if (menue == 1){
              //opdracht
            delay(200);
      if (switchStateKnop3 == HIGH) {
            if (menue == 0){
              //opdracht
           if (menue == 1){
             //opdracht
            delay(200);
      if (switchStateKnop4 == HIGH) {
            if (menue == 0){
              //opdracht
           if (menue == 1){
             //opdracht
            delay(200);
            // menue
      if (switchStateKnopMenue == HIGH) {
            if (menue == 0){
              menue = 1;
              digitalWrite(menu_Licht, HIGH);
              menue = 0;
              digitalWrite(menu_Licht, LOW);
            delay(200);
void pot(){
    // potentiometer meten
   potVal_Grijper  = analogRead(potPin_Grijper);
   potVal_Base = analogRead(potPin_Base);
   potVal_voor_achter   = analogRead(potPin_voor_achter);
   potVal_boven_onder   = analogRead(potPin_boven_onder);
   lcd.clear();
   lcd.setCursor(0, 0);
   lcd.print("Grijper:");
   lcd.setCursor(16, 0);
   lcd.print(potVal_Grijper);
   lcd.setCursor(0, 1);
   lcd.print("Base:");
   lcd.setCursor(16, 1);
   lcd.print(potVal_Base);
   lcd.setCursor(0, 2);
   lcd.print("voor achter:");
   lcd.setCursor(16, 2);
   lcd.print(potVal_voor_achter);
   lcd.setCursor(0, 3);
   lcd.print("boven onder:");
   lcd.setCursor(16, 3);
   lcd.print(potVal_boven_onder);
   delay(200);
void klappen (){
  for (int i = 0; i <= 100; i++) {
    servo_grijper.write(50);
    delay(300);
    servo_grijper.write(100);
    delay(300);
void openen (){
  servo_grijper.write(90);
    if (grijper_dicht_langzaam_controle == 0){
   for (pos_open_langzaam = 0; pos_open_langzaam == 90; pos_open_langzaam++){
    servo_grijper.write(pos_open_langzaam);
    delay(15);
     if (pos_open_langzaam = 90){
     grijper_open_langzaam_controle = 1;
void grijpen (){
  for (pos_grijp_langzaam = 130; pos_grijp_langzaam >= 44; pos_grijp_langzaam--){
    servo_grijper.write(pos_grijp_langzaam);
    delay(15);
  if (pos_grijp_langzaam = 90){
     grijper_dicht_langzaam_controle = 1;
void base_draai_90(){
  if (pos_draai_langzaam_controle == 0){
  for (pos_draai_langzaam = 0; pos_draai_langzaam = 90; pos_draai_langzaam++){
    servo_base.write(pos_draai_langzaam);
    delay(10);
  pos_draai_langzaam_controle = 1;
void debug (){
   if (pos_grijp_langzaam = 1){
   // grijpen
    Serial.print("dicht");
    Serial.print(grijper_dicht_langzaam_controle);
void DebugKnoppen() {
            if (menue == 0){
                Serial.print("|1.1|");
                Serial.print("|2.1|");
            if (menue == 0){
              Serial.print("|1.2|");
           if (menue == 1){
              Serial.print("|2.2|");
            if (menue == 0){
              Serial.print("|1.3|");
           if (menue == 1){
             Serial.print("|2.3|");
            if (menue == 0){
              Serial.print("|1.4|");
           if (menue == 1){
             Serial.print("|2.4|");
            if (menue == 0){
              Serial.print("menu1");
           if (menue == 1){
             Serial.print("menu2");
void MeneuLicht(){
             if (menue == 0){
           if (menue == 1){
void knoppenStateGeven(){
  switchStateKnop1 = digitalRead(switchPinKnop1);
  switchStateKnop2 = digitalRead(switchPinKnop2);
  switchStateKnop3 = digitalRead(switchPinKnop3);
  switchStateKnop4 = digitalRead(switchPinKnop4);
  switchStateKnopMenue = digitalRead(switchPinKnopMenue);
void controlerenKnopEinde(){
    switchStateReset = digitalRead(switchPinReset);
    if (switchStateReset == HIGH) {
      eindPositsie();
void eindPositsie (){
  delay(40);
  servo_grijper.write(0);
  delay(40);
  delay(40);
  einde = 1;
Thank you for using code tags on your first post!
Now, please explain what "doesn't work" means. What should the program do, and what does it do instead? Post examples of output on the serial monitor, if applicable.
Servo programs often fail due to wiring or power supply problems, so please post a hand drawing wiring diagram, and links to the servos and servo power supply.
One of those lines must be wrong. I bet that if you mouse the boundary to make the lowest section of your IDE bigger ( it is black on mine ) there will be a message from the compiler informing you that there is a fault in loop(). The line number might be a bit off but helps to find what your fault is near to.
selectKnoppen();
selectKnoppen; this does not know what to do.
This is not a compiler error. The first line calls the function selectKnoppen and the second line simply fetches the address of that function and does nothing with it.
