Void loop is non-stop running. how to create start with potentiometer?
Is there a way to start a void loop running after that the potentiometer is set on the highest value? The potentiometer is the start sign of the code. How can i do that?
thnx
When the potentiometer level reaches a trigger point you can call a function that needs to run.
if(analogRead(potPin) >= triggerLevel)
//call your function here
If you want to wait in setup() until the pot value hits maximum and THEN go on to running loop() repeatedly, put this code at the bottom of setup():
  while (analogRead(PotPin) != 1023)
    /* Do Nothing */
} // End of setup()
