Void loop it gets stuck at the end of the program(help)
I use bluetooth and bluetooth electronics app on phone. When I press a button and then another in the application I have a loop in the last part of the code:
int gaisma;
float lights;
bool manual = 0;
int n;
char k;
gaisma = 1023 - analogRead (A0);
//gaisma = map(gaisma, 0,1023,0,100);
lights = gaisma * 0.09775171;
Serial.println("*I"+String(lights)+"%*");
Serial.println(lights, 1);
 if(Serial.available() > 0)
    {k = Serial.read();}
   if ( k == 'N')
      manual = 1;
      if ( k == 'K' )
      manual = 0;
if (lights <= 30 && manual == 0 )
{Serial.print("*MR255G255B255*");}
if (lights <= 80, lights >= 41 && manual == 0)
{Serial.print("*MR150G150B150*");}
if (lights <= 100,lights >= 81 && manual == 0)
{Serial.print("*MR0G0B0*");}
 if ( k == 'O' && manual == 1 )
      n = Serial.parseInt();
      Serial.print("*MR250G00B00*");
    Serial.println(n);}
    return;
In this part there is a constant cycle but sometimes it comes back as needed
    Serial.println(n);}
    return;
P.S. Maybe there is a video with this program and how to program it. Thanks.
This is probably not doing what you think
Maybe you mean
if (lights <= 80 && lights >= 41 && manual == 0)
Fix all your similar misuses of the comma operator.
HTH
a7
It will also help you if you formatted your code and got the indentations sorted.
What is the purpose of the return statement near the end of loop?
Hello iljas123
Welcome to the best Arduino forum ever :smile:
I have done a code review.
In addition to the errors already mentioned, there is also a design error in the programming of the serial interface in the sketch.
There is a conflict at
and
which steal each other's characters from the interface.
Rethink the overall design again.
Thank so much!!!
