void loop() keep looping while functions run
Hello,
Im new to Arduino but I do have some programming experience.
And I have a question regarding the standard loop.
Sample code:
functA();
functB();
void functA()
//some code which takes 5 seconds to run
void functB()
//some code which takes 1 seconds to run
When the loop starts it will obviously first run functA(); and then start functB();
The thing is that functB(); will be started after 5 seconds and keeps being started after an interval of 5 seconds.
What I want to accomplice is that functB(); keeps running every 1 second and not being slowed down by functA();
Is there a way to do this?
Thanks!
Don't use delay() in your functions and take a look at the Blink Without Delay example.
Hi Arrch,
Thanks for your reply.
The delay is not caused by delay(). I send an ICMP ping to a host and once the host goes offline it will timeout.. this timeout takes around 5 seconds. So once the host is online the function will run in 1 second but when it it's offline it will take 5 seconds.
It would be nice to run the functions asynchronous.
Can you post the "some code" please?
Sure, I found code on the Internet that I use and modify to my needs:
Repeatedly ping a number of servers and output the response to serial and pins 2,3,4
pin 2: ping request sent
pin 3: ping response received
pin 4: ping response not received
This software requires the ICMPPing library, available at
http://www.blake-foster.com/projects/ICMPPing.zip
Portions of this code were derived from code available at
http://www.blake-foster.com/project.php?p=44
My thanks go to Blake for his hard work.
If you do not wish to output to the serial port, comment out the line
#define serialOut 1
If you do not wish to output to the LEDs, comment out the line
#define ledOut 1
The lines
byte ip[] = {192,168,0,177}; // ip address for ethernet shield
byte pingAddr[8][4] = { {91,121,5,142}, {91,121,5,143}, {91,121,5,144}, {91,121,5,145}, {91,121,5,146}, {91,121,5,147}, {91,121,5,148}, {91,121,5,149} }; // ip address to ping
need to be changed to suit your own needs. If your network has DHCP the arduino
will automatically grab an IP address for itself.
#include <SPI.h>
#include <Ethernet.h>
#include <ICMPPing.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED}; // mac address for ethernet shield
byte ip[] = {172,16,0,60}; // ip address for ethernet shield
byte pingAddr[1][4] = { {172,16,0,112}};
int numAddresses = 1; //sizeof(pingAddr[0]);
bool deviceFound = false;
int lampCountdown = 10;
SOCKET pingSocket = 0;
char buffer [256];
int delayMS = 1 * 1000; // check every 1 seconds (delay between successive pings (60 * 1000 = 60 seconds))
#define serialOut 1
#define ledOut 1
#ifdef ledOut
	#define ledPing 2
	#define ledOk 3
	#define ledFail 4
	#define lamp 5
	void startPing()
		digitalWrite(ledPing, HIGH);
	void endPing()
		digitalWrite(ledPing, LOW);
	void pingSuccess()
		deviceFound = true;
	void pingFail()
#endif
	#ifdef ledOut
		pinMode(ledPing, OUTPUT);
		pinMode(ledOk, OUTPUT);
		pinMode(ledFail, OUTPUT);
		pinMode(lamp, OUTPUT);
		// initialising, turn all LEDs on
		digitalWrite(ledFail, HIGH);
		digitalWrite(ledOk, HIGH);
	#endif
	#ifdef serialOut
		// start serial port:
		Serial.println("Starting ethernet connection");
	#endif
	// start Ethernet
	if (Ethernet.begin(mac) == 0) {
		#ifdef serialOut
		Serial.println("Failed to configure Ethernet using DHCP");
		#endif
		// DHCP failed, so use a fixed IP address:
		Ethernet.begin(mac, ip);
int i = 0;
	pingDevice();
	if(deviceFound==true){
		lampCountdown=10;
		digitalWrite(ledFail, LOW);
		digitalWrite(lamp, HIGH);
	}else{
		if(lampCountdown<=0){
			digitalWrite(lamp, LOW);
		}else{
			digitalWrite(ledOk, LOW);
			Serial.print("Device not found: ");
			Serial.println(lampCountdown);
			lampCountdown--;
void pingDevice(){
	bool pingRet; // pingRet stores the ping() success (true/false)
	#ifdef ledOut
		startPing();
	#endif
	ICMPPing ping(pingSocket);
	byte pingAddr2[] = { pingAddr[i][0], pingAddr[i][1], pingAddr[i][2], pingAddr[i][3] };
	pingRet = ping(4, pingAddr2, buffer);
	#ifdef ledOut
		delay(250);
		endPing();
	#endif
	#ifdef serialOut
		Serial.print("i:");
		Serial.print(i);
		Serial.print(" ");
		Serial.println(buffer);
	#endif
	#ifdef ledOut
		if(pingRet) // Failure
			pingSuccess();
			pingFail();
	#endif
	i++;
	if(i >= numAddresses)
		i = 0;
		delay(delayMS);
Ok, so let's rephrase. Take a look at the blink without delay example to run the second function every 1 second and ensure that neither function are blocking.
svh1985:
If you want true multitasking, get a Propeller.
svh1985:
void pingDevice(){
  delay(delayMS);
The one-second delay there won't be helping.
Inside the library I guess you are using:
bool ICMPPing::waitForEchoReply()
	time_t start = millis();
	while (!W5100.getRXReceivedSize(socket))
		if (millis() - start > PING_TIMEOUT) return false;
	return true;
You may need to rework so that rather than looping until a timeout, you check and then return. In other words, handle timing-out a different way. Effectively this makes it asynchronous.
Thanks for your reply's.
I will try to implement these suggestions this weekeind and post my findings back here.
Cheers!
