Void loop() makes confuse me..
I want to execute these below two functions infintely in a void loop() function. But when first function execcutes and return back to void loop() function, it returns back to initial condition , and again first function is called.. compiler doesnot goto second function . What may be its solution??
my void loop() code goes here.. void loop() {
Vcheck(); delay(5000); Acheck(); delay(5000); }
I have a definition for both function ..
How do you know?
when i am checking in serial monitor , it executes first function and again it executes first function repeatedly...
Post your whole sketch, not just a snippet.
Jiggy-Ninja:
… in code tags please; it’s difficult to read otherwise.
It's much better
when it looks}
like this
We’ll see when you post, but have you got a serial print in Acheck?
Maybe Vcheck’s calling itself?
Your code will call Vcheck() and then Acheck() and then loop( ) will start again and call Vcheck( ) again.
If you think it is doing something else, you are probably mistaken.
How did you define the functions?
Post all your code.
michinyon:
Which is what prompted me to wonder this:
There is no issue with what you posted. If you post your definitions for VCheck() and ACheck(), I’m sure we’d be able to help.
